It is midnight (a good time for vampires to be working) and I need to record this before I forget how it is done.
1) Get the a.dsk off the first page of this thread
2) Run the qz80 and xmodem three files off the disk - LDRBIOS.MAC, MPMXIOS.MAC AND MPMD.LIB
3) rename them LDRBIOSJ.MAC, MPMXIOSJ.MAC AND MPMDJ.LIB
4) Find the reference to MPMD.LIB in both the mac files and change it to MPMDJ.LIB
5) Copy them using R into the SIMH
6) Use PIP to copy SYSMPM.SUB to SYSMPMJ.SUB
7) Use wordstar to edit SYSMPMJ.SUB to this
[code]
; build MP/M system
; needs to be executed under CP/M 2
; required sources: LDRBIOS.MAC, MPMXIOS.MAC, MPMD.LIB
; required programs: M80.COM, L80.COM, DDTZ.COM, LINK.COM, XSUB.COM
XSUB
M80 =LDRBIOSJ/M
L80 LDRBIOSJ,LDRBIOSJ/N/E
DDTZ MPMLDR.COM
FLDRBIOSJ.COM
R1600
G0
SAVE 26 MPMJ.COM
ERA LDRBIOSJ.REL
ERA LDRBIOSJ.COM
M80 =MPMXIOSJ/M
LINK BNKXIOS[noparse][[/noparse]OS]=MPMXIOSJ
GENSYS $$A
ERA BNKXIOS.SYM
ERA MPMXIOSJ.REL
PI
This is a quick post in case I accidentally delete a day's worth of coding.
This is an autoexec for MPM. I have tried many different solutions - the big problem with MPM is that you can't start feeding bytes straight away. You have to wait till the A0> prompt has been stable for a while. And polling can't take too many CPU cycles.
This is the main code for the autoexec. It is called from within the keyboard scan routine
autoexec:
ld a,(autofin)
cp 0FFH
ret z ; returnif has run once
ld a,(cnt50) ; counter decremented by mpm
cp 1 ; is it 1?
jp z,autores ; reset the flag (cnt50 decrements)
cp 2 ; is it 2
ret nz ; returnifnot2
ld a,(autolet) ; have we sent a letter out yet?
cp 0FFH ; FF if yes
ret z ; return
ld hl,autodat ; pointer totextstring
ld a,(autocnt) ; get the letter counter
ld d,0
ld e,a ; set up to add the two together
add hl,de ; add them
ld a,(hl) ; get the letter
cp 0
jp z,autoend ; if zero thenendofstring, finish up
out (21H),a ; send it out - port 11H for testing, port 21H or22H on propeller
ld a,(autocnt)
inc a
ld (autocnt),a ; increment the pointer
ld a,0FFH
ld (autolet),a ; flag pointer to say sent out a letter
ret
autores:ld a,0 ; reset the flag so ready fornext letter
ld (autolet),a
ret ; andreturnautoend:ld a,0FFH ; flag to say has finished
ld (autofin),a ; store flag o say all bytes sent, donothingfrom now on
ret ; returnautofin: db 0 ; 0 =running, FF=finished
autolet: db 0 ; 0=not sent a letter, FF=sent
autocnt: db 0 ; letter counter
autodat: db 'SUBMIT AUTOEXEC',cr,0
called from here
ptsti macro ?num
; Console#&?num input status routine, retuns 0ffh if ready, 00h if not
ptsti&?num equ $
call autoexec ; run autoexec on user 01 or 2 (port 20H 21H or 22H)
in a, (sts&?num) ; get status
and m_in ; check with input mask
ret z ; zero means that bit is not set meaning no input available
ld a, 0ffh ; otherwise indicate that input is available
ret
endm
ptsti 0
ptsti 1
ptsti 2
I've got a similar program working on the SIMH.
Many traps along the way. For some reason you can only run this on the machine you compiled it on. (it must write more files out than I can see).
What this means is a board can autoboot into the network program on user 2, and this can start directing packets automatically.
This has been a huge coding challenge - the final code is very simple but there were a huge number of dead ends along the way. And I'm sure it can be simplified - eg by calling autoexec from somewhere related to the clock tick/interrupt rather than the console input routine.
I'm still fixing a few minor things - eg just changed it from AUTOEXEC.SUB to AUTOMPM.SUB as CP/M is using the name AUTOEXEC.SUB
and GENSYS is defaulting to not using a Z80 so I need to change that.
I must say, it is very cool for the propeller to be able to recompile its own operating system. Soon, with the network, it will be possible to also transmit a new operating system wirelessly.
Attached is a zip of the 4 disks needed. Disk A has the fixed GENSYS file with Z80 enabled, ticks = 5 per second.
Note to myself - the attached disk may also not work. Somehow errors seem to sometimes creep into the gensys settings. So for posterity this is a record of settings that work:
A>gensysm
MP/M II V2.1 System Generation
Copyright (C) 1981, Digital Research
Default entries are shown in (parens).
Default base is Hex, precede entry with # for decimal
Use SYSTEM.DAT for defaults (Y) ?
Top page of operating system (FE) ?
Number of TMPs (system consoles) (#3) ?
Number of Printers (#1) ?
Breakpoint RST (06) ?
Enable Compatibility Attributes (Y) ?
Add system call user stacks (N) ? y
Z80 CPU (Y) ?
Number of ticks/second (#5) ?
System Drive (A:) ?
Temporary file drive (A:) ?
Maximum locked records/process (#16) ?
Total locked records/system (#32) ?
Maximum open files/process (#16) ?
Total open files/system (#32) ?
Bank switched memory (Y) ?
Number of user memory segments (#7) ?
Common memory base page (C0) ?
Dayfile logging at console (N) ?
RESERVED FF00H 0100H
SYSTEM DAT FE00H 0100H
TMPD DAT FD00H 0100H
USERSYS STK FB00H 0200H
XIOSJMP TBL FA00H 0100H
Accept new system data page entries (Y) ?
RESBDOS SPR EE00H 0C00H
XDOS SPR CC00H 2200H
Select Resident and Banked System Processes:
ABORT RSP (N) ?
SCHED RSP (N) ?
SPOOL RSP (N) ?
MPMSTAT RSP (N) ?
BNKXIOS SPR C400H 0800H
BNKBDOS SPR A100H 2300H
BNKXDOS SPR 9F00H 0200H
TMP SPR 9B00H 0400H
LCKLSTS DAT 9800H 0300H
CONSOLE DAT 9500H 0300H
Enter memory segment table:
Base,size,attrib,bank (95,6B,80,00) ?
Base,size,attrib,bank (00,C0,00,01) ?
Base,size,attrib,bank (00,C0,00,02) ?
Base,size,attrib,bank (00,C0,00,03) ?
Base,size,attrib,bank (00,C0,00,04) ?
Base,size,attrib,bank (00,C0,00,05) ?
Base,size,attrib,bank (00,C0,00,06) ?
Base,size,attrib,bank (00,C0,00,07) ?
MP/M II Sys 9500H 6B00H Bank 00
Memseg Usr 0000H C000H Bank 01
Memseg Usr 0000H C000H Bank 02
Memseg Usr 0000H C000H Bank 03
Memseg Usr 0000H C000H Bank 04
Memseg Usr 0000H C000H Bank 05
Memseg Usr 0000H C000H Bank 06
Memseg Usr 0000H C000H Bank 07
Accept new memory segment table entries (Y) ?
** GENSYS DONE **
More notes - recompiling MPM is proving an extremely difficult task. Many restarts from a clean disk. Gensys problem solved
; build MP/M system
; needs to be executed under CP/M2
; required programs: M80.COM, L80.COM, DDTZ.COM, LINK.COM, XSUB.COMMPMD.LIB
; gensys sometimes corrupts files so don't run gensys
; settings Y, FE, #3, #1, 06, Y, Y, Y, #5, A, A, #16, #32, #16, Y, #7, C0, N
; and N to adding RSPsXSUBM80=LDRBIOS/ML80LDRBIOS,LDRBIOS/N/EDDTZMPMLDR.COMFLDRBIOS.COMR1600G0SAVE26MPM.COMERALDRBIOS.RELERALDRBIOS.COMM80=MPMXIOS/MLINKBNKXIOS[noparse][[/noparse]OS]=MPMXIOSERABNKXIOS.SYMERAMPMXIOS.REL
; start MP/M with MPM
and I have sometimes found it works better without these two lines comment out in spin
'#define USER0_PS2_VGA
#define USER0_TO_PUNCH
but I'm still not 100% sure about this.
Next experiment - is the
#define TIMED_FLUSH
a factor.
Still only have about a 10% chance of a compilation working.
I might try compiling on the SIMH too.
...many false starts, but I seem to have a stable A disk. Need timed flush to be on (otherwise misses the last packet on an xmodem transfer), user0_to_punch must be commented (slows things down too much and sysmpm errors occ) and it does not matter if user0 is the serial port or the vga monitor.
Strangely, on this test, the ticks at 50x a second seems to be working. I even pushed it right to the limit by starting mbasic at the same time on two users and it worked.
I've attached this (a.dsk)
I'm learning a lot about mpm. For instance - one tiny error in gensys, and it still compiles, but you get the previous version. So you can have a mistake and it can creep in for many versions because gensys is failing, and it makes debugging very hard. Almost worth changing the version number on mpmxios.mac every time it is recompiled.
Accurate time delays are possible:
procedure doevents(milliseconds=integer)
rem pass control toother users for n ticks
var hl, de, bc, a_psw = integer
de = milliseconds/20 rem number of ticks eg 50 per second on the propeller emulation
bc=141 rem function call141call (0005H,hl,de,bc,a_psw)
end
rem ************ MAIN **************
print "One second delay"
doevents 1000
print "one second delay over"end
It is the previous code that has been damaged when porting to this forum (still ok on the archived old forum)
[ /code ] is ok but
[ code ] got replaced with [ quote ]
BTW - today I got an MPM version with 8 users working on the SIMH. Also autoexec in MPM. Big buffers inside the xios - big enough to handle an xmodem packet. Am working on the interface code but hopefully soon will be able to have something that looks like windows for the simh. Then will look at porting it over to the propeller.
pullmoll: All your quote/code tests in that last post work fine.
As Dr_A says it's all the code blocks, images and large attachments moved from the old forum that are mangled and chopped.
Apparently no one thought any of that data might be important.
Oh, and I have to say again I hate to have code blocks in scrollable little windows. Why for God sake? The page is scrollable already. It's annoying and it does not work in all browsers, like on mu Android phone.
A simple text version of windows is now running on the qZ80. Screenshot here http://www.smarthome.viviti.com/mp-m The second program is perhaps not as exciting to look at, but it is doing more in terms of being able to route data around the place. We can do a remote login now and run programs on a remote propeller board. Next step is more reliable file transfer - xmodem is fine for a phone line that stays connected all the time, but for wireless, with the really possibility of corrupted packets, something better than x/y/z modem is needed. I'm thinking about the bittorrent protocol, where you can disconnect for a day in the middle of a download and resume when a connection is reestablished. Hopefully soon it will be possible to demonstrate something practical, like sending a jpeg picture via a noisy wireless data link that has interference and disconnects at random times.
Hi Juergen, I hope you are not too busy with work!
I have a strange bug - I am not sure if it is with MPM or the qZ80. The keyboard occasionally will not read a character properly. This is my test code. The bug showed up in the middle of a huge 1000 line program, but I have narrowed it down to this
$lines
procedure ReadKeyboard
var c=bytewhile inp(10H)=3do
begin
c=inp(11H) rem get the byte
print asc(c); rem print the ascii valueendendrem *************** Main **********************
var a=integer
var b=integer
a=0
repeat
begin
readkeyboard rem read the keyboard
print "."; rem print a dot on the screenfor b=1to2000 rem delay loopnext b
enduntil a=1end
If I run this and type a character then about once every 15 characters it will not read the correct character. The character it does read is repeatable - eg typing zero (ascii 48) will occasionally return 69. Ascii a (97) occasionally returns 28.
This does not happen when running the same program in the SIMH.
Another intriguing clue - take out the lines "for b = 1 to 2000 next" and the error is not there. (These lines emulate the rest of the program).
So I am thinking that when a character arrives in the middle of that delay loop maybe it gets corrupted somehow.
I've tried looking in the qZ80 code but I can't see why it would do this. Any help would be most appreciated!
Further to the post above, the missing character bug has been fixed. It proved impossible to find in the end, though it seems to be in the keyboard.spin object (now modified to be only pasm). The workaround was to create a new buffer and to bypass the existing one. I have no idea why this works but I suspect something is overwriting the data somewhere (it corrupted bytes in the middle of the buffer, byte 8 and 9 of 16)
Further to this, I've been working on some major rewrite of the keyboard driver code so that the insert/home/pageup/delete/end/pagedown/arrowkeys/escape all work properly. The practical upshot of all this is a text editor for the propeller that is easy to use and is actually practical, in that it is quicker to open a file on the propeller, edit, and save/close, than it is to edit the file on a PC and download the new file.
The story behind this took a week of coding to find and fix (thanks ++ to Mike Green and Toby on another thread)
This major revision started because I wanted to run Wordstar on MPM. (Via wireless!) I kept getting "out of memory" errors, and changing the memory settings in WSCHANGE did not seem to help.
So I checked out an alternative text editor, VEDIT which is available over at the Altair SIMH. Check out Vedit http://www.vedit.com/ they are still going strong today, with modern software for many platforms. And buried in their website is a disclaimer saying that the legacy versions are available as freeware. This works on MPM and is quicker than Wordstar. But I could never remember the keycodes, and they are a little different to Wordstar (^X and ^C are swapped for instance)
I wanted to get the arrow keys and the home/end/insert/delete/pageup/pagedown keys working, as then you don't need to remember control characters (vedit does not have them at the top of the screen).
Indeed, the only command that is a bit strange that you have to remember is to hit escape twice, then up comes a command prompt, and you use EQ to quit without saving, or EX to save.
And this is where all the problems started, because the escape key would not work. After many tries, I found a solution that sent ascii 27 straight from the keyboard.spin object, rather than decoding CB in the io.spin object (which was receiving 02, not CB).
And the bonus is that this saved two longs in code.
So I tried Insert, and this failed too, so I changed keyboard.spin to send ^N and that worked, and saved another two longs in io.spin.
And so eventually I've changed all the wordprocessing characters so the keyboard object sends them as control codes, and saved about 20 longs overall.
Vedit is a pleasure to work with. It is the first word processor that is, in my opinion, not a toy, and is an entirely practical thing to use on a propeller. I'm using it to change some .INI files to alter the behaviour of a program, and this is proving quicker than recompiling code all the time.
Plus - I've got a new board being made that has a standard D25 serial port, and so it should be possible to configure this as a printer and so have a word processor and printer package all on the propeller.
Also, I made some minor changes to the vt100 object so it keeps the foreground and background colours.
As an aside I'm still selling about 3 boards a week. These work out at cost neutral but I get a real buzz with each sale. Hopefully some of the people buying these boards will post their projects here and maybe contribute something as well.
Now Chris you know where to get Zog from and the ZPU C compiler is here opensource.zylin.com/zpu.htm [noparse]:)[/noparse]
But ... my time is a little bit limited. My next project will be running the propeller code on an XMEGA
[code]
; build MP/M system
XSUB
M80 =LDRBIOSJ/M
DDTZ MPMLDR.COM
FLDRBIOSJ.COM
R1600
G0
SAVE 26 MPMJ.COM
ERA LDRBIOSJ.REL
ERA LDRBIOSJ.COM
M80 =MPMXIOSJ/M
GENSYS $$A
ERA BNKXIOS.SYM
ERA MPMXIOSJ.REL
PI
autoexec: ld a,(autofin) cp 0FFH ret z ; return if has run once ld a,(cnt50) ; counter decremented by mpm cp 1 ; is it 1? jp z,autores ; reset the flag (cnt50 decrements) cp 2 ; is it 2 ret nz ; return if not 2 ld a,(autolet) ; have we sent a letter out yet? cp 0FFH ; FF if yes ret z ; return ld hl,autodat ; pointer to text string ld a,(autocnt) ; get the letter counter ld d,0 ld e,a ; set up to add the two together add hl,de ; add them ld a,(hl) ; get the letter cp 0 jp z,autoend ; if zero then end of string, finish up out (21H),a ; send it out - port 11H for testing, port 21H or 22H on propeller ld a,(autocnt) inc a ld (autocnt),a ; increment the pointer ld a,0FFH ld (autolet),a ; flag pointer to say sent out a letter ret autores:ld a,0 ; reset the flag so ready for next letter ld (autolet),a ret ; and return autoend:ld a,0FFH ; flag to say has finished ld (autofin),a ; store flag o say all bytes sent, do nothing from now on ret ; return autofin: db 0 ; 0 =running, FF=finished autolet: db 0 ; 0=not sent a letter, FF=sent autocnt: db 0 ; letter counter autodat: db 'SUBMIT AUTOEXEC',cr,0
called from here
ptsti macro ?num ; Console #&?num input status routine, retuns 0ffh if ready, 00h if not ptsti&?num equ $ call autoexec ; run autoexec on user 0 1 or 2 (port 20H 21H or 22H) in a, (sts&?num) ; get status and m_in ; check with input mask ret z ; zero means that bit is not set meaning no input available ld a, 0ffh ; otherwise indicate that input is available ret endm ptsti 0 ptsti 1 ptsti 2
A>gensysm MP/M II V2.1 System Generation Copyright (C) 1981, Digital Research Default entries are shown in (parens). Default base is Hex, precede entry with # for decimal Use SYSTEM.DAT for defaults (Y) ? Top page of operating system (FE) ? Number of TMPs (system consoles) (#3) ? Number of Printers (#1) ? Breakpoint RST (06) ? Enable Compatibility Attributes (Y) ? Add system call user stacks (N) ? y Z80 CPU (Y) ? Number of ticks/second (#5) ? System Drive (A:) ? Temporary file drive (A:) ? Maximum locked records/process (#16) ? Total locked records/system (#32) ? Maximum open files/process (#16) ? Total open files/system (#32) ? Bank switched memory (Y) ? Number of user memory segments (#7) ? Common memory base page (C0) ? Dayfile logging at console (N) ? RESERVED FF00H 0100H SYSTEM DAT FE00H 0100H TMPD DAT FD00H 0100H USERSYS STK FB00H 0200H XIOSJMP TBL FA00H 0100H Accept new system data page entries (Y) ? RESBDOS SPR EE00H 0C00H XDOS SPR CC00H 2200H Select Resident and Banked System Processes: ABORT RSP (N) ? SCHED RSP (N) ? SPOOL RSP (N) ? MPMSTAT RSP (N) ? BNKXIOS SPR C400H 0800H BNKBDOS SPR A100H 2300H BNKXDOS SPR 9F00H 0200H TMP SPR 9B00H 0400H LCKLSTS DAT 9800H 0300H CONSOLE DAT 9500H 0300H Enter memory segment table: Base,size,attrib,bank (95,6B,80,00) ? Base,size,attrib,bank (00,C0,00,01) ? Base,size,attrib,bank (00,C0,00,02) ? Base,size,attrib,bank (00,C0,00,03) ? Base,size,attrib,bank (00,C0,00,04) ? Base,size,attrib,bank (00,C0,00,05) ? Base,size,attrib,bank (00,C0,00,06) ? Base,size,attrib,bank (00,C0,00,07) ? MP/M II Sys 9500H 6B00H Bank 00 Memseg Usr 0000H C000H Bank 01 Memseg Usr 0000H C000H Bank 02 Memseg Usr 0000H C000H Bank 03 Memseg Usr 0000H C000H Bank 04 Memseg Usr 0000H C000H Bank 05 Memseg Usr 0000H C000H Bank 06 Memseg Usr 0000H C000H Bank 07 Accept new memory segment table entries (Y) ? ** GENSYS DONE **
; build MP/M system ; needs to be executed under CP/M 2 ; required sources: LDRBIOS.MAC, MPMXIOS.MAC, MPMD.LIB ; required programs: M80.COM, L80.COM, DDTZ.COM, LINK.COM, XSUB.COM MPMD.LIB ; gensys sometimes corrupts files so don't run gensys ; settings Y, FE, #3, #1, 06, Y, Y, Y, #5, A, A, #16, #32, #16, Y, #7, C0, N ; and N to adding RSPs XSUB M80 =LDRBIOS/M L80 LDRBIOS,LDRBIOS/N/E DDTZ MPMLDR.COM FLDRBIOS.COM R1600 G0 SAVE 26 MPM.COM ERA LDRBIOS.REL ERA LDRBIOS.COM M80 =MPMXIOS/M LINK BNKXIOS[noparse][[/noparse]OS]=MPMXIOS ERA BNKXIOS.SYM ERA MPMXIOS.REL ; start MP/M with MPM
'#define USER0_PS2_VGA #define USER0_TO_PUNCH
#define TIMED_FLUSH
a factor.
procedure doevents(milliseconds=integer) rem pass control to other users for n ticks var hl, de, bc, a_psw = integer de = milliseconds/20 rem number of ticks eg 50 per second on the propeller emulation bc=141 rem function call 141 call (0005H,hl,de,bc,a_psw) end rem ************ MAIN ************** print "One second delay" doevents 1000 print "one second delay over" end
Post Edited (Dr_Acula) : 8/3/2010 3:30:18 AM GMT
Trying myself:
int pullmoll(int question) { return 42; }
And what about tab stops?
CON CMD_AES_SET_ENCRYPTION_KEY = 1 CMD_AES_SET_DECRYPTION_KEY = 2 KEY_ROUNDS = 10 EPARAM = 1 VAR long cog long command long params[8] PUB start : okay stop tbl_e0_ptr := @tbl_e0 tbl_e1_ptr := @tbl_e1 tbl_e2_ptr := @tbl_e2 tbl_e3_ptr := @tbl_e3 tbl_e4_ptr := @tbl_e4 tbl_d0_ptr := @tbl_d0 tbl_d1_ptr := @tbl_d1 tbl_d2_ptr := @tbl_d2 tbl_d3_ptr := @tbl_d3 tbl_d4_ptr := @tbl_d4 rcon_ptr := @rcon params[0] := @command okay := cog := COGNEW(@entry, @params) + 1 PUB stop if cog COGSTOP(cog~~) PUB set_encryption_key(key_ptr) bytemove(@params, key_ptr, 128/8) command := CMD_AES_SET_ENCRYPTION_KEY repeat while command == CMD_AES_SET_ENCRYPTION_KEY PUB set_decryption_key(key_ptr) bytemove(@params, key_ptr, 128/8) command := CMD_AES_SET_DECRYPTION_KEY repeat while command == CMD_AES_SET_DECRYPTION_KEY DAT org 0 entry mov t1, PAR rdlong command_ptr, t1 command_loop rdlong cmd, command_ptr wz if_z jmp #command_loop cmp cmd, #CMD_AES_SET_ENCRYPTION_KEY wz ' set encryption key? if_z movs aes_set_encryption_key_ret, #command_done if_z jmp #aes_set_encryption_key cmp cmd, #CMD_AES_SET_DECRYPTION_KEY wz ' set decryption key? if_z movs aes_set_decryption_key_ret, #command_done if_z jmp #aes_set_decryption_key command_done mov cmd, #0 wrlong cmd, command_ptr jmp #command_loop param_error neg cmd, #EPARAM wrlong cmd, command_ptr jmp #command_loop
Now, that looks ok! So I guess it's the posts that got screwed somehow?
Anyway: Hello everyone on the new forum.
[ /code ] is ok but
$lines procedure ReadKeyboard var c=byte while inp(10H)=3 do begin c=inp(11H) rem get the byte print asc(c); rem print the ascii value end end rem *************** Main ********************** var a=integer var b=integer a=0 repeat begin readkeyboard rem read the keyboard print "."; rem print a dot on the screen for b=1 to 2000 rem delay loop next b end until a=1 end
I love the Propeller chip!
Nice to see your progress. Unfortunately I have not had much time for actual prop code lately - I am hoping this will change shortly.
