Ensuring Propeller powers up
william chan
Sometimes when I plug the power supply to the board, the Propeller chip fails to start up.
I have to pull out the plug, wait a few seconds and then plug in the power again.
How to ensure the Propeller chip starts up every time correctly?
I've had a couple problems with a Propeller board not powering up consistently but it has always been my fault do to loose wires or not enough capacitors on the Vdd pins. These have always been homemade boards or breadboarded circuits.
Duane
I have a 470uF electrolytic cap on the 12v line, 10uF smd ceramic on the 5v line and one 10uF smd ceramic near the 78L33 3V regulator and another 10uF smd ceramic near the Prop D40.
Should I reduce the 470uF capacitance or change it to tantalum type to reduce the bouncing?
Powering up from the wall seems to work most of the time.
The only alternative is to fit a switch into the power supply line and leave the board plugged in.
