Need help with Propeller and multiple ADC
I am new to microcontrollers and need some advice. I have an analog circuit for controlling dc loads using PWM from signals generated by thermistors. My analog circuit just seems to grow as I tweak and add in features that function demands. A crucial part of the design is scalability, there are multiple loads controlled by individual thermistors.
I first looked at the Basic Stamp but it seems to lack the capabilities to monitor multiple thermistor values and simultaneously control multiple PWM signals. The Propeller seems like a much better choice with its multiprocessor design.
I have been reading through the Spin and Propeller manuals looking for some signs that this is the right choice if I make the leap from analog to digital. I am excited by the prospect of learning to use the Propeller in my project, especially the ability to bring in GUI later in the project. What I need to know is whether I am barking up the right tree? Does Propeller meet the basic requirements to monitor multiple analog signals? If I have say twelve thermistors can I use the Propeller to get a value at a 60 Hz frequency.
I appreciate any help and feedback that you can provide.
and also create a nice GUI on a monitor and do the PWM. The idea to use external
ADC with a single Propeller might be easier though. Mike Green
is an excellent engineer and his recommendation is probably
the best way to go.
For instance the MAX1270 object has BS2 routines (I believe)
http://obex.parallax.com/objects/513/
There is also a MCP3208_fast for using the 8ch, 12bit microchip ADC.
I thought there was a MCP3208_fast_multi somewhere too, designed to talk to 3 of these at high speed (24ch)
