A newbie question
I am totally new to micro controllers. I stumbled upon the Propeller while researching something for work.
Before I dump a lot of time in learning how to program/use the Prop Chip, I have a question on its capabilities.
I need to make a video "Analog" guage for a project at work. I need to feed it a 0-10 volt analog output and have it deflect a central pointer around a dial with numerical graduation. I also need this to output to a standard TV. Color is not required, but would be nice.
The display needs to resemble a vector generated display. Below is an image of a clock that looks pretty close to what I need. Just imagine it with just the hour hand, about 250 degrees of sweep, and static text where the digial time is.
I am not looking for "how" to do it (yet, anyway), but just if it could be done with a suitably designed and programed Propeller circuit.
Thanks!
Tim
Thanks!
Tim
Welcome to the forums.......
Watch this video
http://www.youtube.com/watch?v=_MMAMRoURcI
Then check out this thread
http://forums.parallaxinc.com/forums/default.aspx?f=25&m=223961
Enjoy
Coley
prop really shines.
Look at this demo!
http://www.youtube.com/watch?v=ef7ZAb5fOv8&feature=related
What can you tell me about those clocks? They look cool!
Bill
I have a big old round CRT, actually a radar display for use in aircraft, always wondered how well the Prop would drive it with it's ADC outputs.
Bill
I wonder how they made the P.D.A. voltage safe?
http://www.sparkfun.com/commerce/product_info.php?products_id=9306
It is a good model for the display you are looking to generate. I bought one because it has a mode that lets you use the oscilloscope as an serial terminal display, which is a good use for an old analog scope.
Anyway, the propeller would be a great tool to use because:
-It has built in NTSC video capabilities,
-The IDE is a free download and includes display are graphic objects that will make this project a simple programming exercise.
Now to do some serious research. I read the post that Coley referred to, but I must admit its a bit over my head right now. I am a controls/automation engineer, and I could easily do this with a PLC based system, but I'd never get management to cough up the bucks for a PLC system for this project.
Next Step:
Which Propeller to buy? Doc, you mention the IDE is a free download, I'm not sure I understand what that is.
Starting Monday, I will really tear into this, because if I can pull this off on the cheap (And soon), I will earn a real feather in my cap at work (Read: CA$H!).
I want to learn how to use the propeller, but right now I"m on a time constraint. I'd be most grateful on what I would have to Buy/do next.
tim
For some projects, the Prop Demo board is it; for others a Prop Protoboard is usable, For some it is 'at the beginning' and maybe it is the breadboard level that is needed (I don't recall the Parallax name for it - experimenters kit?)
Read many of the recent posts to get a flavor for what people are doing with their Props.
Ask a more detailed question and the help will pour in from many of us on this forum.
