possible bot base
Gramps
Two of these scooters might make a very nice and powerful robot base for a total price of $125............
http://cgi.ebay.com/Razor-E150-Electric-Scooter-Red-/320575532203?pt=LH_DefaultDomain_0
Gramps
Gramps
I see balancing robot here...
OBC
http://www.youtube.com/watch?v=eYh2JaHsdak the wife can't keep up on her stock Giant electric bike!
Here in Norway, they're only allowed to run as a 'supporting engine,' that is, they only run as long as the rider actually pedals. And they're required to cut off entirely at speeds over 25Km/h.
Anything more and you're talking about an electric MC, with all the paperwork that entails.
Oh, and(again, here in Norway) the scooters themselves may be illegal if they have a top speed over 8Km/h. Then they're classed as a motor vehicle and suddenly comes under road-traffic laws. (Which means type-certification and a lot of other mess.)
One TV-host was careless enough to use a gasoline-powered model on his show once.
Ouch...
It may not hurt to check up on local laws before doing anything to bicycles, or even just driving one of those scooters anywhere. (Note that road-traffic laws may also cover usage on private roads. It does here.)
And the 'supporting engine' mod is a really good idea. You don't want to arrive at an intersection, miss the off-button and... well... panic...
The motor is rated at 24V 135Watt (Model: MY6812)
The 'original' batteries are two generic SLA batteries rated at 12V 4AH wired in series. I would seriously consider a LiFePO4 battery here.
The brake is a clamp style friction brake connected to a hand cable. <- they sorta work, but not great
10 mph is a fast robot, too!
Looks like fun.
Really?
Sounds like a good project to learn about regenerative braking...
(May also be speed-controlled, so that it automatically begins braking whenever the kid gets it over 15mph when going downhill... )
So, unless I'm wrong about the speed controller or the motor voltage (I probably am) we would have to find one of the many speed controllers that is better suited. (i just realized that the stock peed controller wouldn't be best suited anyway, as there is no reverse for the "see object in close proximity to front of robot, stop, back up, turn away, and continue driving" maneuver.
Beau, do you happen to know what chain size this uses? Also, with a chain drive, do you feel there would be too much backlash for a balancing robot? I just noticed a way that with minimal welding and no cutting I could mount some motors and up high and bearing supported shafts where my current motors are.
I was looking at some NPC motors on a battlebots site, but these scooters are cheaper than the individual motors.
"Friction brake?..Really?" - I'll try to take a picture tomorrow ... basically a rotating cylinder attached to the wheel with a metal strip/band that encompasses most of the cylinder ... one end of the metal strip is anchored while the other end is attached to the brake line cable. As the cable is pulled the metal strip applies pressure/friction equally around the cylinder causing a braking effect.
Jay Kickliter,
"Beau, do you happen to know what chain size this uses? Also, with a chain drive, do you feel there would be too much backlash for a balancing robot?" - mine is timing belt driven rather than a chain.
Edit:
Gadgetman,
Attached is an image of the brake housing(I apologize for the dirt)Brake.jpg. You can see the metal band that would surround the metal cylinder. You can see the metal cylinder in the Back.jpg image and the 4-hole screw pattern that matches the wheel. Notice some 'polishing' effect due to use on the brake cylinder.
Jay Kickliter,
The difference between belt vs. chain on a scooter from the same manufacturer is just a model difference, I feel that the same motor is used. The dimensions I have on the belt/ wheel/sprocket give it about a 1:6.5 ratio from the motor to the wheel.
Motor Reference:
Chain Drive
Belt Drive
Belt:
15.5 inches
Wheel(gear):
3.25 inches diameter
Sprocket:
0.5 inches diameter
tncscooters.com and electricscooterparts.com have some motor controllers with reverse function in the $25-40 range for 24-36-48V motor apps.
