Forums Search
I am having trouble with the search part of the forums.
For instance I am interested in seeing others wading's through I2C.
So, I search for I2C and I come up with nothing. Also in lower case.
Something needs improvement here. A general search should show up K's of strings on this subject I would imagine.
Does any one else find this problem or am I doing something wrong???
Unfortunately, the number of TLAs (Three Letter Acronyms) we deal with makes this a challange.
Adding a wild card (or two) is a decent work around in most cases.
I beleive (based on other threads in the support forum) that once some of the bigger migration issues are resolved, this may get revisited.
res fit 496 available buffer cog ram
guess how many words the engine uses...1.."buffer'. Apparently "available" is too common, and everything else too short. Grrr.
Jonathan
