Configure two XBEE's pro V2
Tumbler
Hello,
I have some questions about to configure the XBEE's with the X-CTU software.
When i click the Test/Query button (PC settings tab) i get a window says:
Modem type:XBP24-B
Modem firmware version:2264
When selecting the modem (modem config tab) i see only versions versions 1141 and 1147
So i tried to upgrade new versions. without succes.
When i click the read button, it selects automatic the XPB24-ZB modem in the dropdown.
Version number is ok also.
Is this the proper modem selected?
And second:
I can't find examples for the pro v2 versions. Need help here.
Modem type:XBP24-B
And second:
On the comparision page i see that it has adjustable power. Wich it's not true.
These are not adjustable. (XBP24-Z7WIT-004)
Answer from digi support:
No, the modules you are using are not software selectable with respect to the transmit power level. Which means to be legal, you need to either purchase the standard 1mW version or the international version of the radio.
Do i have an international version? I can't find it in the documentation.
