Durable Small Temp Sensor Wanted
I am working on my senior college project and I am in need of a temperature sensor which is small enough to fit into a 1/4" hole, but it need to be durable enough to handle high heat and air flow. The use is to monitor air flow at different point inside an air intake tube on a car. I also want to use it to measure the heat under the hood in various locations. The accuracy needs to only be +- 1 degree but I want to be able to take sample data every 0.1 sec especially while in the air intake stream. Let me know what sensor you guys would recommend for using with my Basic Stamp or if I need to upgrade to a different unit.
Thanks for the help.
The National Semiconductor LM34 is good from -50F to 300F and has an output voltage proportional to the temperature. The BS2 doesn't have a built-in analog to digital converter (ADC), but works nicely with a variety of ADCs including the MCP3202 that Parallax sells. There's sample code and documentation on Parallax's webstore page for the MCP3202.
If you are willing to change to a BS2p/pe/px Stamp, you could use a 1-Wire temperature sensor from Maxim/Dallas like the DS18B20 which is good from -55C to +125C and does its own ADC internally.
Both are available in TO-92 packages which should fit in a 1/4" hole
Thanks for the recommendation and I will check into those.
Apparently it had slid in there somehow when he had done some previous work, and was sitting in the pipe where it bent to the main pipe at the bottom of the engine. The plastic was completely melted away!
So, yeah, engine exhaust gets hot.
- Stephen
Chevy 350 sheet metal body panels and plastic hood the engine makes around 700HP top speed of around 180 MPH on top of manifold I have seen temps of over 300 F at speed under 90MPH 275 F at over 100MPH and by the exhaust manifolds about 4 inches away right near the spark plugs I have seen temps of over 600 F now I know why I melt so many spark plug wires
I have EGT's for the exhaust 6 inches from heads in pipes I regularly see 1375 F we have to use radiator shrouds so the air just flows over the radiator and then down under the engine
I have seen my poly hood actually deform from the heat when we are bunched up in a group I hope that helps . Depending on where you are going to mount your Temp Sensor under your hood you might end up needing more temp range than you think .. I also wanted to know what the carb temperature is under my Holly 1050D we can not use spacers I routinely see 240F idle is much higher
I did not realize I was not posting my signature.
The car is a 1991 Mazda Miata. The class I am building it for is SCCA Spec Miata. As far as I know no one ever did a study on the engine bay temps like I will. Thanks for the info on what your engine temp under hood.
The car will see outside temperatures as high as about 110F and as low as about 40F. The 300F sensor might be a good start but like you said I may have to go up from there.
Mikediv's post demonstrates your project so clearly, and how temps near your intake could torpedo your horsepower and jack-up the fuel air ratio.
After reading your rules, they would allow Water Wetter from Redline instead of coolant. http://www.redlineoil.com/product.aspx?pid=74&pcid=10 Race Gas is a curious topic (If they do not provide you with a spec fuel). As air temps go up and air density drops, the EFI may go beyond it's normal map, and run rich as a result. And at what point does the ignition go into full retard for a given load. How far will the engine rev past peak horsepower, and how fast does engine accelleration fall off. Through testing you could develop a set of "ideal parameters".
With Ideal Parameters, you could discover just how much octane really necessary. Unleaded fuel with increased octane only (no oxygenation), will provide less horsepower. You could create your own mixture of pump gas mixed with race gas that best suits your car and driving style.
Good Luck
Bill M.
