Why is the Old Forum Failed? — Parallax Forums
HumanoidoHumanoido Posts: 5,770
edited 2010-08-15 12:37 in General Discussion
The previously attached images do not show up in the text posts in the old forum. They worked fine before. Why doesn't that work now? So both forums don't work? Why would the old forum, which worked before, not work now? Let's get that old forum back up and running!!!!!!!!!!
Humanoido
    edited 2010-08-15 08:29
    What do you mean? For example the attached images on this old forum page are fine http://forums.parallaxinc.com/forums/default.aspx?f=25&m=473136
    edited 2010-08-15 08:43
    He's referring to the inline images. They fail because the links still point to forums.parallax.com. This, too, shall pass. Once the new forum gets repaired, any idiosyncrasies resulting from the old one getting moved will be mooted.
    edited 2010-08-15 11:42
    He's referring to the inline images. They fail because the links still point to forums.parallax.com. This, too, shall pass. Once the new forum gets repaired, any idiosyncrasies resulting from the old one getting moved will be mooted.-Phil
    It's making me panic. Yes, the inline images. AND how to make an inline image on the new forum?
    Humanoido,
    You're where I was a week or so ago: "AAAH! My preciousssss possstssses! The forum is wrecked! It's the end of civilization as we know it!" But don't panic. None of this is magic, it's all logical, and the problems, though surely acute, are neither terminal nor chronic. If you want to provide some assistance, your help is welcome. See my sticky post at the top of this forum.
