How does one determine if code is being stepped on by own program?
I'd submitted (twice) a thread titled "Why dec, hex, or decn NOT displaying properly?" which no one responded to.
I now think maybe the code is being corrupted somehow, but HOW to determine that? I've increased stack from 30 to 200+ in steps and that does not help.
Most of the Objects are spin, so few cogs are used but RAM is mostly due to the LCD screen buffer.
Now here's the problem, how to get the Spin file from Windows to iMac? I tried all sorts of things but none work. Cant Copy from Windows and Paste on iMac desktop, can't drag from Windows to iMac, tried emailing to self but that doesn't work either.
Any suggestions (be nice, now)?
Another way to transfer the file is to use a USB memory drive. Plug it into your Windows machine and copy the file to it. It'll mount fine as a disk drive on the Mac as well and you can copy the file off it. It'll still need to be run through TextWrangler to fix the line endings.
Finding out how and why a program scribbles over itself is one of the toughest debugging tasks. I tend to embed debugging statements that let me know where the program is executing, so I know that the program seems to work fine to a certain point, then fails beyond that, then I start looking at what the program was doing just before that point and work backwards in the program using simple debugging statements to display status messages and values for a few variables.
Without actually looking at your code, it's difficult to tell what is going on, and there are a number of things that could cause the symptoms that you describe.
Sounds like you are having troubles with communicating across different platforms also. I'm not familiar with iMac, so I don't really have a basis here other that what I can find out on-line. Have you tried an external USB plug, or an FTP server/client, can you see the iMac on a network?
To add to what Mike just said... even though it is a Mac ... There is a utility called dos2unix and also unix2dos that comes with most Linux style and OS-X operating systems that will properly translate files from one to the other.
Too hot here to 'think' properly. I tried emailing, but yes there was some sort of format problem. And I forgot the USB module transfer method. So here is the attachment.
This runs on a PTP board of Rayman's and uses his 3.5" LCD neat display. I tried using ViewPort, but compiled OK but program wouldn't init the LCD. May not have enough RAM. I was hoping to use the SD card to save waveforms, but is way too big.
Anyway, using the dec, decn, and hex for debugging I get large values usually; like 15xx hex when it should be no more than maybe 320. Even small values like a 1-digit hex can range from 0..F, even though the program only uses 0 or 1 in the program!
Thanks in advance for any hints to why this is happening. At one time everything was OK for the numerical display. I've worked around it since but need better control which means getting this 'bug' out of it.
I think I know what the problem is. I have seen this sort of thing before especially dealing with printing numbers and using the graphics.spin object. It usually happens when you print two or more consecutive numbers, but I have seen it in other places.
The simple fix, and this was added in the early stages of the graphics.spin object is to issue a gr.finish after printing any kind of number.
Just a note:
When attaching a file, use the File-->Archive-->Project within the SPIN IDE and attach that file to your post.
I noticed once that the curs1, curs2 values came up '0' once, but after a short moment reverted to 4 digits varying around 1600 decimal. And one thing that bothers me is once it has displayed 4 digits, that space is never 'cleaned up' even if the value is near 0. I'm saying the last 4th digit remains there!
Now, for some reason, the touchx, touchy, AD[0], AD[1] and BL values always seem to be proper; the first two is pixel position of touch, the next two are hex values of the two longs prior to the AD buffer, and the last is the backlighting value (1..32). Now, this might be a clue: after selecting Hold, the values are displayed properly, but after selecting Sweep the values are again varying around 1600!!! Has been driving me nuts for several weeks now while trying to work out this problem.
What is the purpose to do a File-->Archive-->Project? What is the advantage of doing that? Seems that would just create another file to maintain or dispose of.
Hope this helps to find something that's wrong. I suppose the need for a gr.finish is due to Spin vs. PASM code running? Lots to learn on this Prop. And I love all the things it can help one accomplish. Yeah, some limitations; who ever has really ENOUGH RAM beyond simple programs like Flash a LED.
http://forums.parallax.com/showthread.php?t=124539
None if the values then should have been that large. The lower left s/b only a 0 or a 1. And upper left normally less than 200 decimal Hope this helps.
I don't have an LCD so it's difficult to 'see' on my end. However in my attempt to use your code with a TV display instead of an LCD, in it's simplest form, the PrintStr doesn't seem to display the character from the ROM table correctly (double high and double wide with pixel garbage at the top) which could be a possible issue. <-- I could be totally wrong, the LCD may 'see' it just fine. Using the gr.text function the TV at least displays the character correctly.
What I would do is strip down your code to a bare minimum. Omit the i2c touch controller for a moment and all other objects not related to the LCD graphics and if there are would-be variables returned from various objects, substitute them with a hard coded values just to get the graphics portion working the way you feel comfortable with it.
I figured that no one without the LCD and much of the PTP board circuitry could do much to try much of my program.
I don't have spare pins for TV_text or I would have used a DVD reader as a monitor for this program. The graphic driver has all the ASCII characters using up lots of RAM and provides nice, small text which works out quite well. Just wish it had dec, decn, hex, etc. to also display small sized values instead of what probably is fetched from ROM. Displays very nice on the LCD. Bummer is that to erase those characters the graphics has to be re-initialized, else it won't 'go away'.
I'll try the 'stripping down' to isolate things differently than I've been doing. Again, thanks.
Found that after using Beau's suggestion of disabling Touch IC and forcing fixed values for the Variables normally used. That began to show something that really didn't involve the i2c touch IC. In fact, I used the IRQ signal to write whether a touch had occurred or not. No effect. Good.
Thanks Mike, Beau, Leon for your suggestions. I probably should have used a CON to define how many A/D samples to store. Stumble and learn, huh?
I'm hoping to also add SD card storage, but that may just require way too much RAM to work. I would only need a simple file recovery scheme; not a full blown system. But that is to be looked into after all the basic other details get resolved.
