Open Source Cardboard Robot
What is the interest in this? a cardboard robot project - one that walks using cardboard legs and body. I did some experiments a while back and determined the more rigid cardboard found in bulk vitamin boxes and promotions will take a servo with either no or minimal reinforcement. I have the design, just need the time to complete it. It would be cool to release open source plans for a robot like this. The idea is to update the plans from time to time. The released software could be printed with the plans for updating too and pdf distributed.
humanoido
humanoido
www.instructables.com/id/simpleWalker-4-legged-2-servo-walking-robot/
create bitmap data tool: 1uffakind.com/robots/povBitMapBuilder.php
resistor ladder tool: 1uffakind.com/robots/resistorLadder.php
convert images to ascii art: 1uffakind.com/apptoys/convtoascii/
humanoido
Zoot, that walker is exactly the kind I've had in mind for a cardboard robot project. I built a similar one for the MoBoStamp-pe from G10 fiberglass sheet material, but I think the right cardboard would make a very nice construction material, too. Those robots can climb over things that get in their way. Their major shortcoming is lack of traction on a smooth surface.
Cardboard/foamcore/sintra seems like a nice alternative, and would be inexpensive and easy to reconstruct in the case of catostrophes. Also I like it because with templates it's something that could be assembled with nothing more than X-acto knives and glue, and in a short time. And of course, it would be easy to experiment with various feet/toes for good traction, etc.
Construction board is nice as well.... I like it. In fact one trick for constructing model railroad building is take photos for texture, doors, windows, print them out on an inkjet, glue the sheets to construction board and then cut and assemble. Foamcore/board 'bots would be open to similar radically cool aesthetic customization.
(e.g. -- http://www.scalescenes.com/ which also has some nice tips for construction with heavy card stock in 1mm-2mm thicknesses)
Post Edited (Zoot) : 7/24/2010 5:12:01 PM GMT
The parts for the MoBug were cut on my CNC mill. I didn't have the laser cutter at that time. If I were to do it again, I'd probably use plywood, construction baord, acrylic, or acetal (Delrin) instead of G10, so I could cut it with the laser. It's so much easier to set up than the CNC and cuts more quickly with no mess to clean up afterwards. (G10 can be laser-cut, too, but it leaves a nasty ash on the cut lines.) One really nice aspect of the laser is that you can also cut the servo splines, so you don't have to rely on the horns that come with the servo.
BTW, to anyone contemplating cutting Sintra with a laser: don't. It contains PVC which, when vaporized by the laser, releases chlorine gas. That will not only make you sick but also destroy the laser cutter via extreme corrosion. I'm not sure about foam-core. I would assume it also contains PVC until proven otherwise.
In the super low-budget, low-tech realm, a good way of cutting thick card or foamcore is to print the templates out and use craft spray adhesive to fix the templates to the foamcore, then cut on the lines and voila. This is what gave rise to the idea of printing cool textures, or the name of the 'bot, and LED holes and the like on the template before affixing -- it becomes the skin. For a shinier more durable "finish" the templates could be printed to gloss photo paper before being affixed.
Thinking out loud, actually, if we presume slot engineering, then it would be good to put several cut lines for the slots on the template, so that a given set of cut lines could be used for different thicknesses of chosen material, without the user having to manually adjust cuts, etc. Or provide alternative templates.
I build a lot of stuff, I have taught classes in building stuff. I get that you're after quick construction techniques, but those usually diverge from "east-to-replace" building techniques. Build it right, build it once, and liberally use reinforcing hot melt glue or CA & baking soda. You DO know about CA & baking soda, right? Try it. You can make rock hard reinforcements or parts out of them.
It's not much more work to make the mission-critical parts out of something more durable than cardboard. It would be a shame for a bent cardboard leg to end the proper function of the robot.
My two cents.
···································Fix it, if it ain't broke!
D Rat
Dave Ratcliff N6YEE
D Rat
Dave Ratcliff N6YEE
You can "rapid prototype" a small part on wax paper this way, alternating layers. A link, a cam, anything. I have seen entire mechanisms made this way.
JUST BUILD IT!
D Rat
Dave Ratcliff N6YEE
Few people seem to have DIY art hobbies in China so I'll have to forgo the idea about foamcore due to lack of hobby stores, though I can get lots of nylon, silk and polyester kites..
humanoido
Thanks for the tip!
- cheap (huge bonus)
- fast/sloppy construction with common household items (knife, glue) is OK (ideal esp. for younger kids where longer focus over multiple sessions just isn't possible
- relatively big "creatures" possible without huge weight and motor requirements
- along same lines -- bigger constructs not as dangerous when they go awry
- everyone liked the idea of 'bots that would bonk into each other a lot (trust me, the kids love it when stuff crashes)
- easy to keep raiding old platforms for servos, parts
So that got us to thinking about possible scenarios. If, for example, you have a 12"-24" platform, vaguely bug- or humanoido-like, you could have some 'bot wrestling/demolition derbies -- since the platform is soft, it'll absorb impacts and the platform should still be able to hack along until it's just too crumpled to move.
So that got us thinking about some easy simple ways to let the 'bot detect that one of it's legs had crumpled to the point of being unusable. The best I've come with so far is something like taking very thin tinfoil and tacking it down as a strip along each leg with just a spot of hot glue here and there. The idea is that as the leg crumples, eventually the foil will tear enough to break a circuit.
Those of you with children -- like us -- who frequent children's science museums may have seen a really common method for introducing young children to electronics with no soldering or wire cutting or anything. The kids lay down strips of tinfoil on cardboad with glue, punch holes all the way through, and then insert wire and loop it around a few times to make circuits. They're printed-circuit-ish in a way. Simple, and lets them wire up leds and motors to big cardboard Rube Goldberg-esque constructions. Would be a nice way to put LEDs on the ends of legs and such as well (sharing circuit with the crumple detector).
I think that a bug like PhiPi's or the sample I linked to above would work up to a certain size with two servos; bigger platforms I think would need to have three or four.
Just throwing some ideas out -- I will like to try out a few experiments along these lines -- given rapid construction time and the inexpensiveness of the material, I should be able to cycle through some designs in short order. Probably won't have time to kick that down until the second week of August, unfortunately. I have two big work projects that need to be dealt with before I can get some serious time in the 'bot lab
Last thought -- my partner really likes the idea of TALL 'bots.... given how light and how tall this kind of construction could be, I think a Hobbit-sized construct would be doable
www.graphicdisplayusa.com/prod_fome-cor_board
Leon Heller
Amateur radio callsign: G1HSM
Post Edited (Leon) : 7/26/2010 7:45:41 PM GMT
For those in the states:
www.elmers.com/products/foam-and-display-boards/foam-sheets?Page=All
Most of these are available at craft houses like Michael's. I've generally seen thicknesses from 3/16" to whopping 1/2". 3/16" or 1/4" is good for a lot of purposes and isn't too expensive (the thick stuff is more expensive, but a single sheet might yield quite a number of the small number of pieces that might require a size like that.
Post Edited (Zoot) : 7/26/2010 7:58:27 PM GMT
www.parallax.com/dl/mm/video/mobug_movie.zip
humanoido
There's a hardened gray cardboard which is very strong and would be ideal for forming humanoid legs and arms. It's thin enough to drill and bolt yet strong enough to support a good amount of weight. I have some of this material, and purchased some rolls of pure aluminum, gossamer thin, for possible light weight covering.
humanoido
Humanoido
http://en.wikipedia.org/wiki/Foamcore
"Foam core or Foam board is a very strong, lightweight and easily cut material used for the mounting of photographic prints, as backing in picture framing, in 3D design, and in painting. It consists of three layers an inner layer of polystyrene clad with outer facing of either a white claycoated paper or brown Kraft paper."
Humanoido
