it took a little getting use to for me but I think it is better then the old in every way except 1. all old links are broken with this version and the redirect messages slow things down especially on a cell phone.
BTW I LOVE how the upper left Parallax Icon logo takes you to the main menu of the fourm .
Nah, that logo should take you to Parallax.com when clicked (IMNSHO). Just below that logo there already exists links to take you to the main forum menu, or higher up in the forum menus, which is more useful than always going to the main menu.
I miss the easy way to the Parallax site by clicking the icon which now directs to the forum
perhaps a link on each page?
It makes it easier to look up stuff when answering questions.
Rich H
I guess I am used to useiing said main Logo on all the other forums I am on .
Peter KG6LSE
The redirect page was put in place to provide a visual cue that something good happened with your post or other activity. It has been disabled. Let's see if it makes a difference.
The drop-down used to navigate to another forum is now near the bottom on the page. Now before the "scroll down = bad" crowd kicks in, we need to find out if that page element is mobile. We'll figure that out with the new supplemental skins.
We're working on a set of solutions to correct the broken link issue. It's complicated so it may take a few days.
So basically to fix this, you would need a redirect on the old page to the new page minus the /forums after parallax.com and with the new record number. Correct?
But I would not think the old record numbers would easily map to the new numbers. Not a simple add or subtract sort of thing!
Another way to handle this would be to write a program which would grab the subject line of the old post, then write a redirect link on the old page to a google.com exact phrase search of that subject with site:forums.parallax.com as a search parameter.
The above search does not find the post on the new site yet, but I imagine as google spiders the new site, the old posts will pop up.
The other option is to redirect to the new forum search, but it might choke on special characters like , > " etc. Or not use the entire name. Or not use an exact phrase.
Here are the search results for the above subject using the new forum search...
Sorry - no matches. Please try some different terms.
The following words are either very common, too long, or too short and were not included in your search : Best, for, a, "SettingsOBJ->EEPROM,"
Way to much female appeal.
Yes we might be nerds, But the lavender!. , I'm not a ****.
I know, I'm just trying to lighten the mood a little.
Well the "Beer, Body-odor and Butt-crack" theme is still in the works.
the lavnder is not bad as it kinda cool looking with my Super dark backround on linux . but I can see it needing a few more colors .
Peter KG6LSE...
Rich H
LMAO. That's hysterical.
OBC
Peter KG6LSE
aaaaaahhahahahaha!!! Aaaaaaahaaaaahahaha! Haaaaa!
Whew! Now, does anyone have any tips for removing spewed coffee off my laptop screen??
Yes, much better without it!
New format is great, working search tool is very nice. But what to do with all the dead links in the old forum...?
Then all of this would have been transferred to a new database and each thread would now have a new different record number...
For example the thread:Best solution for a Propeller Database: FSRW->SD, SettingsOBJ->EEPROM, ROMEngine->EEPROM"...
Old link "googalized"...
http://www.google.com/url?sa=t&source=web&cd=1&ved=0CBcQFjAA&url=http%3A%2F%2Fforums.parallax.com%2Fforums%2Fdefault.aspx%3Fm%3D448799%26f%3D25%26p%3D1&ei=09JiTKn0H4TmsQOz6JyvCA&usg=AFQjCNHe4x4LrvQQJaAUXVc5n0gEp_1KVw
Thread number 448799?
New link...
http://forums.parallax.com/showthread.php?t=122036&highlight=solution+Propeller+Database
Thread number 122036?
For example...
http://www.google.com/search?hl=en&as_q=&as_epq=Best+solution+for+a+Propeller+Database%3A+FSRW-%3ESD%2C+SettingsOBJ-%3EEEPROM%2C+ROMEngine-%3EEEPROM&as_oq=&as_eq=&num=10&lr=&as_filetype=&ft=i&as_sitesearch=forums.parallax.com&as_qdr=all&as_rights=&as_occt=any&cr=&as_nlo=&as_nhi=&safe=off
- Sorry - no matches. Please try some different terms.
Anyway solutions to this are quite possible!The following words are either very common, too long, or too short and were not included in your search : Best, for, a, "SettingsOBJ->EEPROM,"
some how I'm not remembered!!! poor me
Howard
