WAITPEQ returns unexpectedly — Parallax Forums
trevormstrevorms Posts: 7
edited 2010-08-10 21:50 in Propeller 1
I have an application which instantiates a state machine (SPIN code) into two different COGs. At one point the following line of code is called in COG 1:
waitpeq(0, |< awake_in[unit_instance], 0)
In this case unit_instance=0, awake_in[unit_instance] = 9.
This function returns unexpectedly when COG 2 executes this code:
outa[relay[unit_instance]]~~
outa[ign[unit_instance]]~
In this case unit_instance= 1, relay[unit_instance] = 5 and ign[unit_instance] = 7.
The awake_in input is pulled high with a 10k resistor and I confirmed with an oscilloscope that it does not change state either.
To work around this problem I call this code after the WAITPEQ function:
delay(1) ' Wait 1 second
awake_state := ina[awake_in[unit_instance]]
if awake_state == 0
unit_state[unit_instance] := STATE_WAIT_TIMEOUT
In this case awake_state is 1.
It seems that WAITPEQ when waiting on one COG can return if another COG writes to its output pin registers.
Has anyone else experienced this problem or is there something wrong that I am doing?
I have attached the full spin code for my application. It depends on VGA_Text which can be found in the object exchange.
Cheers,
T.
  • T ChapT Chap Posts: 4,224
    edited 2010-08-10 21:15
    Hello Trevor.
    Is this as you intended it to be, seems either your comment is wrong or the use of ~~ should be ~?
    dira[relay[unit_instance]]~~ 'Set relay pin to output
    outa[relay[unit_instance]]~ 'Make relay output low
    dira[ign[unit_instance]]~~ 'Set ignition pin to output
    outa[ign[unit_instance]]~~ '<<<<<Make ignition output low
    edited 2010-08-10 21:18
    Indeed, it is possible for output pin changes in one cog's register to affect a WAITPEQ active in another cog. This reason this happens is that there's only one set of I/O pins and the input I/O circuitry reads the actual state of the I/O pins. If an I/O pin is set to output mode, the state of the output is what's read. If this satisfies a WAITPEQ condition, then the WAITPEQ instruction terminates.
  • trevormstrevorms Posts: 7
    edited 2010-08-10 21:19
    Sorry, my comments are not accurate and may be the result of copy-paste errors. The SPIN code does what I want.
    The relay outputs are active high while the ign outputs are active low.
    trevorms wrote: »
    waitpxx is very sensitive, a single clock pulse is enough to trigger it (e.g. 12.5ns @80MHz). How is the signal on this input pin generated?
    edited 2010-08-10 21:21
    kuroneko wrote: »
    The pin is pulled high with a resistor. An open drain transistor pulls the line low. In my test the input remained high with no glitches.
    edited 2010-08-10 21:25
    Mike Green wrote: »
    My code is writing to different pins than the input pins, with the OUTA call, so I am confused as to why WAITPEQ should return.
    edited 2010-08-10 21:26
    trevorms wrote: »
    Also once the pin directions are set in my code, they are not changed.
    edited 2010-08-10 21:27
    trevorms wrote: »
    For the sake of it, can you connect an edge counter to the pin in question and monitor phsx just before and after the offending code sequence?
    edited 2010-08-10 21:29
    Sure I could do that with an oscilloscope. Given the time I may simplify the spin code to reproduce this specific problem and wait on a pin that is tied high. When I do this I will post the results.
    edited 2010-08-10 21:33
    trevorms wrote: »
    Please use a cog internal counter, it sees what waitpxx sees.
    edited 2010-08-10 21:38
    kuroneko wrote: »
    Please excuse my ignorance but could you post example code to read the internal COG counter as I am not sure what you mean.
    if unit_instance == 1
        ctra[30..26] := %01000      ' POS EDGE detector
        ctra[$5..$0] := awake_in[0] ' monitored pin
        frqa := 1
        phsa := 0                   ' before
      outa[relay[unit_instance]]~~  ' offending code which seems
      outa[ign[unit_instance]]~     ' to trigger waitpeq()
        temp := phsa                ' after
    Place this somewhere around the code which you think triggers the waitpeq. It is guarded so it's only active for unit 1 (but monitors the pin from unit 0). What I'm after is whether temp stays 0 or not.
    Hope this makes sense.
