I see that if you hover your mouse cursor over the 'EDIT' button, the balloon text says Edit/Delete Message, however I do not see a way to delete. Has that been disabled?
After you start editing a post, if you click on the "Go Advanced", I beieve you'll see the delete options.
The appear in a separate "delete" space above the edit window.
Also note that you cannot delete the original post of a thread. This may be an option for the team to explore. Basically, if I inadvertatnly start a new thread (or think better of it after the fact) there is no way that I found to delete the thread, even if there were not any replies.
I was trying to delete the entire thread, no delete option for that.
Thanks Again!
