Build your own small VGA
Has anyone looked into salvaging the screens out a dead netbook for use with the Propeller? My netbook just reached the end of its useful life, but it has quite a few interesting parts. I can get a WiFi card and an SDcard slot, and a few other things.
But that screen looks the most appealing. It seems that if this is possibly, there are tons of these on EBay as the first generation of netbooks is about 3 years old.
Maybe netbooks are different?
Rich H
There is hope however.. I'm told by a friend who does laptop repair that there are some standards emerging in laptop screens. This means there is possibility for someone to design (a redesgn) an interface to talk to these.
Perhaps the answer will be different soon, but for now.. Afraid not.
OBC
Based on another thread, I expect you are talking about an old Asus EEE (7" ?). There should be old threads on www.eeeuser.com with the pinout since a lot of people were modding these and adding additional usb-based stuff internally.
http://www.rapidonline.com/productinfo.aspx?tier1=Electronic+Components&tier2=Optoelectronics&tier3=LCDs+And+Accessories&tier4=LCD+Graphics+controller&moduleno=75869
Rick
One hint is that the computer is all Intel chips, including video. And there is a VGA plug to the outside. That has to lead somewhere. Internally, it is capable of switching between the internal screen and the external VGA plug.
I concluded it is a difficult but not impossible task to repurpose notebook screens.
The pin outs are in the ballpark. But it becomes essentially a low level programing task in Propeller Assembler. At this point, I've too many other things to think about. But I suspect that some limitations can be imposed on the video quality and it can get done by who-knows-who.
http://www.harbaum.org/till/dvi2par/index.shtml
One might both save some costs and be able to get the 7" or 9" screens from an old EEEpc for Propeller projects.
If you can't find the datasheet on the lcd, and control chips, then its a worthless lcd.
There is always "reverse engineering" using many logic channels on a scope, if the lcd is operational.
http://www.youritronics.com/laptop-lcd-display-to-vga-interface-project/ Here is somebody that is getting somewhere.
For instance, I used to by old HP terminals for $5 broken and repair them without schematics. In some cases, I could just swap things to make them work. But buy carefully examining the power pins of the CPU chips, it because very obvious that they were using an 8080 cpu with HP markings. Eventually, more and more things became clear and more and more units were sold as refurbished for $150-200 USD.
I do have the interface with the LCD on the EEEpc motherboard and I can back-track the context. These days it is getting harder and harder to find anything informative on the internet - search engines are more and more into positioning advertisement than really providing thorough searches.
The two things that came up with the most recent link I posted are AND are why I posted it:
1. One doesn't have to use all 24 bit of the color inputs that are offered. The Propeller provides what seems like 2 bits of scale per color for a total of 6, rather than the 8 bits per color for a total of 24. It looks as though some of the pins can just be pulled high or low. Standards beyond 24 bits of color (ala M$ are about transparency and not really in hardware).
2. The chip posted does provide substantial clues to what an LCD is looking for in i/o and and the chip itself is still available from TI. So this may well be a good interface example between a 'raw' LCD and the Propeller.
BTW, Back-lighting for the LCD may be entirely separate.
More DIYers
Also I found (but I haven't read yet) an app note for connecting micro-controllers to a Sharp lcd monitor.
What I really need is a good oscilloscope to verify pins. I have been getting by on using a 'sound card' software scope that is up to about 40Khz.
I suspect that getting the RGB pins mixed up may not do much harm to the LCD and can be later sorted out by trial and error (the highest bits are most important), but one does have to locate the Vdd, Vss, and the Hsync and the Vsync.
Vdd and Vss are usually no brainers. A Propeller Scope might just assist with finding the syncs. Engineers being what they are, the colors are likely to be grouped together is groups of 8 and in RGB order.
I guess it is time for me to see if I can really do some reverse engineering on the EEEpc as the video is working. And I need to read the Propeller Hardware PDF again in detail. Also the VGA driver. These really decide how directly I can drive it all.a
Of course, there is the option to write another Propeller video driver for a lower level of interface,
http://www.google.com/search?hl=en&source=hp&q=USING+OLD+LAPTOP+SCREEN&aq=o&aqi=&aql=&oq=&gs_rfai=
One point of interest is that hackers have put the EEEpc 900 LCD in an EEEpc-701. That means that they are the same pinout even though they differ in real estate.
http://jkkmobile.blogspot.com/2008/05/asus-eee-pc-900-screen-on-701.html
I suppose that a database of which screens require what would be in order.
And, there are two goals:
1. Retrofit a generic VGA interface
2. Fit to a specific Propeller driver if this is any easier.
http://www.adwiens.com/projects/electronics/11/index.html
Here is a pin layout i found ...
EEE-PC LCD Pin-outs
1 lvdsvcc
2 ??? 0.1v
3 ??? 0.3v
4 ??? 2.2v
5 ??? 0v
6 ??? 2.25v
7 lvds ground
8 a0-
9 a0+
10 a1-
11 a1+
12 lvds ground
13 a2-
14 a2+
15 clock-
16 clock+
17 back light ground
18 back light adj
19 back light on/off
20 back light vcc
BTW - all of the LCD panels I looked at from old laptops conform to the signal description in the above PDF. The oldest panel from a 486 was 6 BPP (262,144 color), the rest were 8 BPP (16,777,216).
