Exceed maximum nested in SPIN?
MacTuxLin
Hi All,
May I know if there are any error msg when compiling if the number of nested block is more than 8 or will I just experience weird results including prop restarting in the mist of running the code?
Just done another test script that blinks the LED. If I have 9 repeat loops within a method, yes, compile error. But if I break into sub methods, it compiled without errors but had funny results. Reason I asked is because my main project has similar nesting process but I tend to get very weird results (e.g. prop hanging & restarting). Ruled out hardware as I've tried different prop & PC I'll continue debugging ...
This one is working:
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PUB Main dira[6..7]~~ dira[22..23]~~ outa[6..7]~~ outa[22..23]~~ waitcnt(clkfreq/2 + cnt) repeat repeat repeat repeat TryThis PRI TryThis repeat repeat repeat !outa[6..7] !outa[22..23] waitcnt(clkfreq/2 + cnt) repeat repeat TryThisAgain PRI TryThisAgain repeat repeat repeat repeat !outa[6..7] !outa[22..23] waitcnt(clkfreq/2 + cnt)But, this one is not working right:
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PUB Main dira[6..7]~~ dira[22..23]~~ outa[6..7]~~ outa[22..23]~~ waitcnt(clkfreq/2 + cnt) repeat repeat repeat repeat TryThis PRI TryThis repeat repeat repeat { !outa[6..7] !outa[22..23] waitcnt(clkfreq/2 + cnt) } repeat repeat TryThisAgain PRI TryThisAgain repeat repeat repeat repeat !outa[6..7] !outa[22..23] waitcnt(clkfreq/2 + cnt)
