Contigious writing using 1632C
                    Hi,
i am using 1632C. i am using 24X16 Led Matrix Display. i sent all the data in successive address writing. i can view the data that i am sending. when i keep the data in continous loop, i found that data is getting shifted. it is not periodical. it is Random. i kept 500ms delay for writing of data. there is no flickering. everything is fine. But only the thing is data is shifting in group of locations. the locations group is also random. the data which i am displaying is sent to hyper terminal. i found the data is correct. Can u please give me the suggestion. i am at the completion of the project.
rgds
srikanth.
rgds
srikanth.
- Stephen
void HT632Init(void) { ChipEnable(CS1); //Enable Chip/ IC 1 for configuration purpose ControlComndIssue(); ComandData(0x001); // master sysdis ComandData(0x048); //Nmos for 1632c ComandData(0x142); // PWM settings ComandData(0x030); // master mode ComandData(0x003); //system Enable ComandData(0x007); // LED on ComandData(0x011); //blink led off ChipDisable(CS1); // Disable IC for write protect DelaymS(1); DelaymS(1); }void ControlComndIssue(void) { WRLOW; DelaymS(1); DATAHIGH; //1 Data High issue as a First bit of command DelaymS(1); WRHIGH; //Make WR pin High DelaymS(1); WRLOW; //Make WR pin Low DelaymS(1); DATALOW; //Make Data Pin Low DelaymS(1); WRHIGH;//Make WR pin High DelaymS(1); WRLOW; //Make WR pin Low DelaymS(1); DATALOW; //Make Data pin low DelaymS(1); WRHIGH; //Make WR pin high DelaymS(1); }void ControlDataIssue(void) //This function is called before the data is placed. { WRLOW; DelaymS(1); DATAHIGH; //1 Data High issue as a First bit of command DelaymS(1); WRHIGH; DelaymS(1); WRLOW; DelaymS(1); DATALOW; //0 DelaymS(1); WRHIGH; DelaymS(1); WRLOW; DelaymS(1); DATAHIGH; //1 DelaymS(1); WRHIGH; DelaymS(1); }void ComandData(unsigned int CmdData) { int BitCount; for(BitCount=9; BitCount>0; BitCount--) { WRLOW; DelaymS(1); if(CmdData & 0x100) DATAHIGH; else DATALOW; DelaymS(1); WRHIGH; DelaymS(1); CmdData <<= 1; } }void HT1632AddresSend(unsigned char ADD) { // char AddressDataBit; unsigned char Addrs = ADD; for(AddressDataBit=7; AddressDataBit>0; AddressDataBit--) { WRLOW; DelaymS(1); //Send Address Bit by Bit , MSB first if(Addrs & 0x40) DATAHIGH; else DATALOW; DelaymS(1); WRHIGH; DelaymS(1); Addrs <<= 1; } } void HT1632DataWrite(unsigned char data) { char AddressDataBit; unsigned char DataNibble = data; for(AddressDataBit=4; AddressDataBit>0; AddressDataBit--) { WRLOW; DelaymS(1); // Send Data Bit by Bit to IC, LSB first if(DataNibble & 0x01) DATAHIGH; else DATALOW; DelaymS(1); WRHIGH; DelaymS(1); DataNibble >>= 1; } }void main(void) { HT632Init(); ControlDataIssue(); HT1632AddresSend(0); for (Addr=0x00;Addr<=0X5f;Addr++) //the size of the digit 5f { HT1632DataWrite(Data); } }Take a look at this and it will provide the coding changes between the HT1632 and the HT1632C
i am using the controller Luminary make LM3S3748
