HELP!!! There are not enough inputs!
I need to find a way to give the BS2 more inputs. The inputs will be hooked to buttons only. I would like to find something that can buffer the inputs ( If I Can) (if the buttons get pushed between checks). I am trying to save as many BS2 pins as I can. If there is a way I would like to find something that is synchronous so I can share clock and data pins of other devices that I am using.
http://www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/230/Default.aspx?txtSearch=serial+to+
See this link:
http://www.emesystems.com/BS2rct.htm#switches
Loopy Byteloose- That is ironic, I am using a LCD. I am going to be sharing data lines just to keep my pin count low. Thank you
Rixter- I was thinking of doing it that way. I have seen many remotes using a resistor network like that. But the only reason I do not think that it would be my best option for this project is the amount of time it takes to find out that there is no button pushed. Thank you
I was looking around and I found this
http://www.maxim-ic.com/datasheet/index.mvp/id/3365/CMP/BTDT
I think it would work for what I need. My project requires the BS2 to control (4) dual-color LEDs, (6) buttons, (3)2 channel ADCs, a 4x16 LCD display, a digital pot (LCD contrast), (1) external input, and last but not least (1) external output. Please let me know if it might not work.
Ever since my accident, I have been trying to come up with a project that will push my mental capability (lost some of my long term memory). So I am making a smart bench top power supply.
So I would like to say to everyone, I apologize if I ask questions like a newbie, but I have to start over Thank you.
TC
You can use multiple chips for more pins...
MCP23016 and MCP23017 (I2C)
MCP23S17 (SPI)
http://www.savagecircuits.com/forums/showthread.php?164-Binary-Digital-Clock
