Getting too old to remember passwords — Parallax Forums
LoopyBytelooseLoopyByteloose Posts: 12,537
edited 2010-08-10 15:36 in General Discussion
The internet keeps demanding harder and harder passwords, and I keep forgetting more and more. The day will come when no one will hear from me
    edited 2010-08-07 10:35
    Interesting new Forum format.
    I see that I last visited Jan 1st, 1970 at 7:00 am. That was before I had my first Radio Shack color computer, maybe before I took Fortran with keypunch cards on an IBM360.
  • P!-RoP!-Ro Posts: 1,189
    edited 2010-08-07 11:41
    Try making passwords that combine things you remember, such as the year you were married followed by the first two letters of your dogs name followed by the last three letters of your wife's maden name. Pretty hard password to guess, but easy to remember.
    edited 2010-08-07 11:52
    Loopy don't sweat it. The old age that is effecting your memory should also provide some nice arthritic pain to your fingers. The inablilty to type a password at all will leave you with dragging your fingers across the keyboard creating passwords which will be accepted. With any luck you'll lean consistency with that method after a while. :):)
    OBC
    ...or let your browser save them. That's what I do, and I just archive the browser directory once in a while, just in case.
    My favorite scheme is to use things that spell like they sound, and rotate through a few, depending on the level of security needed. Upside, is nice, long passwords are easy.
    "code.it, download.it, two.rivers, to.be.a.kid.again", etc...
    For a higher level, I keep the same idea, only insure that it's stuff that people won't type, and that they find difficult to remember. Memory requires an association to be made. The examples above are very easily remembered and typed.
    If the password scheme requires numbers, just toss a zero in for the "o", three for E, etc...
    "bringlesplats, dweeb.knob, fringl3.splick, grindlehob, bl33bus"
    Adding the dot between obvious sounds, and the number letter substitution gets these through any scheme.
    For very sensitive stuff, I generate something that types easy, and that is long, and I write the darn thing down and stuff it in with the other key info bits we all must maintain in "that file".
  • hippyhippy Posts: 1,981
    edited 2010-08-07 12:09
    My golden rule is to make passwords extremely offensive. Then you'll never be tempted to ever pass them to others.
    One service provider I had accepted "I do not have a password" as a password for use over the phone :-)
    edited 2010-08-07 12:11
    Never married, so forget that.
    The truth is that I have a 3-tier system of passwords.
    1. Must recall and must be secure (banking and so on)
    2. Useful to recall (visit often)
    3. Don't care about the security, just make it easy
    It work on an age old priority about information.
    A. Need to know
    B. Nice to know
    C. Garbage
    edited 2010-08-07 12:12
    "Save as yesterday's" is good one.
  • W9GFOW9GFO Posts: 4,010
    edited 2010-08-07 12:32
    A couple months ago I tried to log into BlueHost, I needed to pay them. I was unable to access the control panel until I created a more secure password. :mad:
    Their requirements were that the new password require both upper and lower case letters, a number AND a non alphanumeric character.
    It is frustrating to be locked out of a service that you are paying for until you create a new password when the old one was more than adequate.
    I feel that I lose security when I have to write passwords down in order to remember them.
    edited 2010-08-07 12:37
    Or you could make a password like W9GFO&(wife name, pet name or something else)
    edited 2010-08-07 13:34
    Well, using my username or other name with some personal meaning is not what I would consider a good practice for choosing passwords. I have a certain style of passwords that I use and the number of unique passwords that I must maintain continues to climb. A few years ago I began naming my bookmarks with hints as to what style of password was required. That's the closest I have come to writing down my passwords. If the password requirements continue to become more strict then my hints will be somewhat transparent.
    Rich H
    edited 2010-08-07 13:39
    The internet keeps demanding harder and harder passwords, and I keep forgetting more and more.....
    There are ancient techniques for remembering things, used back in the days when people didn't even have paper to jot things down. Some people call it "mental theater". There's a book about the history of it called "The Art of Memory." I'm sure there are geriatric versions of the same book somewhere...I just can't remember where.
    http://www.amazon.com/Art-Memory-Frances-Yates/dp/0226950018
    edited 2010-08-07 15:13
    W9GFO wrote: »
    Pass.W0rd1
    So far, variations on that one gets past the strength requirement. Doing something rule-based is generally easiest for those kinds of systems.
    @Hippy: Nice! And I'm going to try that next chance I get.
  • KMyersKMyers Posts: 433
    edited 2010-08-07 15:29
    Technology is much more exciting now that I am older and have trouble remembering thing like this!
    edited 2010-08-07 15:32
    Loopy, try one of those password managers, I've been using Roboform for years and find it excellent at remembering urls and their passwords, it also means one click to go to a website and one click to fill out large forms too.
  • John AbshierJohn Abshier Posts: 1,116
    edited 2010-08-07 16:13
    What burns me is the inconsistency. There is no minimum length requirement. Some have a fairly small upper limit. Some require shifted numbers (!@# etc.). Others will not accept shifted numbers. A site that I used to go to required lower case, upper case, numbers and shifted numbers. Passwords were good for only 150 days and it remembered your last 10 passwords and would not let you reuse them. And they wonder why there are yellow stickies on monitors.
    John Abshier
    edited 2010-08-07 17:31
    I have this on my office window. I do a little IT / Sysadmin work (as little as possible to make things go) still --enough to continue to stay connected to the humor.
    Check out the 500 most common passwords. I have used many of these, just like everybody else, who struggles to just plug in the minimum.
    http://realtimetricks.blogspot.com/2010/08/list-of-top-common-passwords-to-avoid.html
    Re: Inconsistency. Yeah. The best defense on that is just to adopt and get proficient at a longer system that is a super-set of all the rules. I'm slowly headed that way as many of the resources I use are ramping it up year after year. So... 12 characters, puncuation, numbers, lower alpha, upper alpha. I'm reducing it down to quick 'n dirty keyboard patterns.
    I second roboform. It's an excellent tool that I am considering adopting. Our ops manager uses it, and I've been impressed.
    edited 2010-08-07 17:51
    I may be "young" but i do have hard time with PW stuff
    I have a 3 tier system and its used on how much the data is worth
    EG here I use a Very simple one.. but the ones I use for lets say FCC or what not is MUCH more complicated ..
    one of my old ones was from a movie ..
    Peter KG6LSE
    edited 2010-08-07 18:04
    Re: Mental theatre.
    Yes!! We had this topic a while back on the old forum.
    One way to explore this, and gain a new skill at the same time, quite literally becoming a little bit smarter, or more capable in a day, is to pick something that doesn't make any sense like:
    glibbensplock
    , that is difficult to associate, tell it to somebody, once, and then ask them to recall it a few hours later, or the next day. No writing it down, or archiving it in any way, save for simple memory recall from your first vocalization of it.
    Unless they've done this game, it's very highly likely they won't be able to do so.
    When they fail, do it again:
    warblesplatkens
    ...and this time, have them associate the previous failure, the lesson: namely, that longer term, enduring memory requires one to make a hard link between that already remembered, and that to be remembered, with the item to be remembered.
    (on the word above, some common associations may be: warble is a sound made by birds, splat is what happens when water falls, TK is a part of the name of a programming environment, Ken works for Parallax, and a platkin is kind of like a platen, only it's got TK in it, etc...)
    The more solid and numerous the links are the better the overall capacity to remember generally is.
    One particularly potent link methodology beyond simple associations, is to use a circular association where the rule to generate the nonsense word is made clear. Combine phonetically familiar syllables, to form familiar sounding garbage words, is the rule, and using that for passwords, as in the case here, reinforces that link, and back to the greater discussion at hand. My post does this, given the context of this thread, BTW.
    That closes all the loops, with some of the associations being bi-directional.
    Finally, when associations are made to enduring things, primary things, rules, basic elements of life, they are the most robust. Many things actually operate in similar ways, and where that can be seen, the associations are very strong, covering many areas of understanding.
    An example of that is the problem of remembering passwords often involves the same skills needed to remember SPIN shortcut expression elements and operators.
    Repeat the same exercise, no writing, etc... after having had this conversation, and...
    Chances are, they will remember, and will use the whole meta-discussion as the link to build on, and that's the new skill! If it's used a few times, it solidifies. If it's used many times, it becomes habit, and the work is done, the person a bit better at this kind of thing for the longer term.
    Awareness of how the mind appears to work in this way, is damn cool, and I wish more things worked this way, because it's generally not difficult.
    The bizarre thing about this meta-discussion is those of you reading this post can improve your skill with just a few dry runs, playing the game with yourself, linking the things just as the other person would. It's a little less fun, and requires a bit more work solo, but it does, in fact, work. Better with another person though. The person to person interaction simply makes for better associations. We associate people, places, and things very well, in general, which is why that works the way it does.
    Some co-workers and I went down this road a long while back, and ended up here after just a lark on memory in general. It all worked well for us, and so...
    I've been sharing it off and on ever since, and introduce it in all of my adult learning classes. Those are your typical industry, "fire hose" type things, where a few days, or a week is spent ramping up on complex, usually higher end, software. I'm sure you've all been through those at some point. They are generally brutal, with so much compressed into so little time.
    Anecdotally, (is that a word?) where I don't spend some time on memory at the beginning, with a few reminders and examples sprinkled throughout the class time, the student pools generally struggle more near the end, or have more follow on questions after class is over, and they are applying what was thrown at them.
    I've received some very interesting comments and suggestions over the years too, as people toy with the idea, realize something intriguing to them, and share it back my way. (which I always encourage, just because it's nice to close the loop on that kind of thing)
    This kind of thing is best done with a side discussion containing a lot of sample ways to associate things, and the idea that multi-sensory input helps in every way. Links can be made with sounds, patterns, numbers, notes, colors, time lines of events (particularly good for the industry type training, as the job expectations and work flow can be linked to the items needed very well), people, mnemonics, etc... The multi-sensory approach is read it, write it, express it, say it, do it, move to it, etc...
    The product of that is kind of a memory tool box, where people can take those bits, apply them, finding ways and means that work for them. Enjoy!
    edited 2010-08-07 18:46
    I once lost my entire internet service for a few days because of something like this. The problem? On a DSL line, for which security is not much of an issue because I own the copper pair running between my house and the DSLAM, they changed operating systems and the new one required a 6-character PW, invalidating my existing 5-character one. It took two hours on the phone with customer service to sort that one out.
  • Jorge PJorge P Posts: 385
    edited 2010-08-08 00:05
    I have always chosen 8 to 16 random letters numbers and symbols, it is difficult to remember at first. It helps with remembering if you logout each time you leave the forum, that way you are forcing yourself to remember. It usualy takes about a week to remember a new password if you use the forum/site multiple times a day.
    I have also been forcing myself to not use the same user name and password for each site, I noticed a few weeks ago when I googled my email address's and user-names I used on other sites, that a few sites outside the US are publishing passwords with usernames, and one of mine were on it.
    Since I am now using different usernames on each site I use, If my passwords show up again, I know exactly which site is to blame.
    edited 2010-08-08 10:14
    Yes, security is a problem... always.
    I generally make a choice about the site that requires a password. If I am not really interested in commiting to the site, I use a spare Hotmail address and often the same password is shared by theme.
    If it is investment - 'moneyhoney'
    If it is electronics -'zapzapzap'
    And so on.
    But the problem is that some sites I visit very often I never key in the password and the browser doesn't show it too me. So I begin to have trouble recalling. And then something like this Forum change over happens and I have to make an effort to log in where I didn't before.
    I have a few important investment sites and a banking site, so I turned off the history in my browser and with that some of the retained passwords disappeared. So I am having to make a greater effort. But these are not wise to leave on a computer, even at home.
  • Ding-BattyDing-Batty Posts: 305
    edited 2010-08-09 11:21
    I use TrueCrypt to manage my passwords file for all credentials I need for various websites I visit. I use a very high security password for TrueCrypt: The source code to a small computer program. "Easy" for me to remember, but very hard to guess and get all the details right. It includes lots of punctuation and some nonsense text, and it is not a program anyone would really want to use.
    edited 2010-08-10 10:26
    Of course you all know that some hacker is going to enjoy using all these clues you have offer to your methodology.
    But I didn't even say what language I used!
    Oh, you may have been referring to earlier postings...:rolleyes:
