Propeller Backpack video circut question
Hello everyone,
I'm working on a video overlay circuit for an ROV controller I'm building. I saw that the propeller backpack can be used for video overlay, so I put the circuit onto my Protoboard. I built the video generator first so I could make it generate video, which I believe is a step in the right direction. However, on both my little NTSC lcd here and my parents big tv, the text from the demo (I think it was the one that said how the program or characters could fit into so much space of memory and than listed a bunch of characters, but i cant find it) was very fuzzy and drifted to the right and came back around. I have attached the circuit as built.
Thanks in advance
Post Edited (legoman132) : 8/4/2010 10:40:21 PM GMT
Thanks in advance
The text is blurred AND drifting
Bill
When I look at the backpack circuit and his circuit, there is a difference. He's not using the two additional pins that the backpack is using.
Are they doing anything special?
Bill
Which two pins are you talking about?
@Phil Pilgrim:
The scope trace has a time scale WAY smaller than what would show the best info (2ms is more helpful).
Update: I took the cap out and it works perfectly:). I just want white text, nothing else, so I wont need gray-level filtering (for now...). Now I have to order the right mosfet from mouser and work on the sync extraction portion.
Thanks to all persons involved (including my dad)
