storing data in EEPROM
Hey All,
I'm using Mike Green's Minimal_I2C_Driver (Basic_I2C_Driver - http://obex.parallax.com/objects/26/ . (Thanks Mike!)
I'm trying to understand it, but I'm not sure how to handle devSel or addrReg. What would I put in those variables?
I have the microchip 24LC256 - so, is that device 2 for devSel?
And, addrReg is anywhere from $0000 (0) to $3FFFF ((26000)?
Am I understanding this correctly?
Shmow
Shmow
here's an attempt to store the value 255 in an EEPROM address (not really sure if it works).
And, an attempt to retrieve what may be in that address too...
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 SCL = 28 StoreData = 255 'VALUE TO BE STORED IN EEPROM Ack = 0 DevSel = $00002 'THE NUMBER TWO IN HEX AddrReg = $3FFFF 'ADDRESS LOCATION IN EEPROM count = 32 VAR byte buffer[noparse][[/noparse]32] byte retrievedData OBJ i2c : "Minimal_I2C_Driver" sio : "FullDuplexSerialPlus" PUB Main sio.start(31,30,0,115200) i2c.initialize(SCL) dira[noparse][[/noparse]16..17]~~ ' INDICATOR LIGHT TO SHOW PROGRAM WILL START IN 4 SECONDS ' GIVES ME TIME TO OPEN PARALLAX SERIAL TERMINAL outa[noparse][[/noparse]17]~~ waitcnt(clkfreq*4+cnt) outa[noparse][[/noparse]17]~ repeat ' WHEN BUTTON IS PRESSED, VALUE OF 255 SHOULD BE STORED IN EEPROM (HOW, I DON'T KNOW) if ina[noparse][[/noparse]0] == 1 StoreVal waitcnt(clkfreq*3+cnt) else ' WHEN BUTTON IS NOT PRESSED, RETRIEVED DATA IS DISPLAYED ON PST (PARALLAX SERIAL TERMINAL) RetrieveVal PRI StoreVal ' NOT EVEN SURE HOW TO MAKE THIS WORK TO STORE DECIMAL 255 (IN storeData VARIABLE) ' I2C.WritePage(SCL, devSel, addrReg, @buffer, count) PRI RetrieveVal ' VARIABLE IS ASSIGNED VALUE FROM DEVICE 2 (MICROCHIP 24LC256) AT BUFFER LOCATION 32 retrievedData := I2C.ReadPage(SCL, devSel, addrReg, @buffer, Count) ' SHOW DATA ON P SERIAL TERMINAL sio.dec(retreivedData) sio.Str(string(13," ",13,13)) waitcnt(clkfreq+cnt)If you can decipher what I'm trying to do here then throw me a line cause I'm way in over my head!
Cheers,
Shmow
In Mike's driver there are read/write examples in the comments.
An EEPROM device id is $A0 ... that's what you get with i2c#EEPROM.
The address range of a 24LC256 is $0000 to $7FFF ... Not sure what $3FFFF will give you.
To store 255 in location 0 you say buffer[noparse][[/noparse]0] := 255 ... but you should read the buffer first.
So a call to Mike's readIt method would preceed that.
Here's a simple, but untested example that should work barring syntax errors, etc....
Hope this helps some way.
--Steve
PRI readIt if i2c.ReadPage(i2c#BootPin, i2c#EEPROM, eepromAddress, @buffer, 32) abort ' an error occurred during the read PRI writeIt | startTime if i2c.WritePage(i2c#BootPin, i2c#EEPROM, eepromAddress, @buffer, 32) abort ' an error occured during the write startTime := cnt ' prepare to check for a timeout repeat while i2c.WriteWait(i2c#BootPin, i2c#EEPROM, eepromAddress) if cnt - startTime > clkfreq / 10 abort ' waited more than a 1/10 second for the write to finish▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Propeller Pages: Propeller JVM
thanks a'plenty for the helpful reply. I'll run with this to see if I can get things in order.
Cheers,
Shmow
I tested out what you gave me, and I actually got the EEPROM to store my value.
The problem is that when the power is lost and restored, the value is not there in the EEPROM.
Isn't there a way to store a value that won't be lost when the power is interrupted?
Shmow
Here's my code with your suggestions:
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 SCL = 28 StoreData = 255 'VALUE TO BE STORED IN EEPROM eepromaddress = $0000 VAR byte buffer[noparse][[/noparse]32] byte retrievedData OBJ i2c : "Minimal_I2C_Driver" sio : "FullDuplexSerialPlus" PUB Main sio.start(31,30,0,115200) i2c.initialize(SCL) ' i2c.readit dira[noparse][[/noparse]16..17]~~ ' INDICATOR LIGHT TO SHOW PROGRAM WILL START IN 4 SECONDS ' GIVES ME TIME TO OPEN PARALLAX SERIAL TERMINAL outa[noparse][[/noparse]17]~~ waitcnt(clkfreq*4+cnt) outa[noparse][[/noparse]17]~ repeat ' WHEN BUTTON IS PRESSED, VALUE OF 255 SHOULD BE STORED IN EEPROM (HOW, I DON'T KNOW) if ina[noparse][[/noparse]0] == 1 StoreVal waitcnt(clkfreq*3+cnt) else ' WHEN BUTTON IS NOT PRESSED, RETRIEVED DATA IS DISPLAYED ON PST (PARALLAX SERIAL TERMINAL) RetrieveVal PRI StoreVal buffer[noparse][[/noparse]eepromAddress // 32] := 255 PRI RetrieveVal ' VARIABLE IS ASSIGNED VALUE FROM DEVICE 2 (MICROCHIP 24LC256) AT BUFFER LOCATION 32 retrievedData := buffer[noparse][[/noparse]eepromAddress // 32] ' SHOW DATA ON P SERIAL TERMINAL sio.dec(retrievedData) sio.Str(string(13," ",13,13)) waitcnt(clkfreq+cnt) PRI readIt if i2c.ReadPage(i2c#BootPin, i2c#EEPROM, eepromAddress, @buffer, 32) abort ' an error occurred during the read PRI writeIt | startTime if i2c.WritePage(i2c#BootPin, i2c#EEPROM, eepromAddress, @buffer, 32) abort ' an error occured during the write startTime := cnt ' prepare to check for a timeout repeat while i2c.WriteWait(i2c#BootPin, i2c#EEPROM, eepromAddress) if cnt - startTime > clkfreq / 10 abort ' waited more than a 1/10 second for the write to finish▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
I did the same thing for the readit method too, and it works!
Thanks for your help.
Here's the final sample code for anyone else following:
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 SCL = 28 StoreData = 255 'VALUE TO BE STORED IN EEPROM eepromaddress = 0 VAR byte buffer[noparse][[/noparse]32] byte retrievedData OBJ i2c : "Minimal_I2C_Driver" sio : "FullDuplexSerialPlus" PUB Main sio.start(31,30,0,115200) i2c.initialize(SCL) ' i2c.readit dira[noparse][[/noparse]16..17]~~ ' INDICATOR LIGHT TO SHOW PROGRAM WILL START IN 4 SECONDS ' GIVES ME TIME TO OPEN PARALLAX SERIAL TERMINAL outa[noparse][[/noparse]17]~~ waitcnt(clkfreq*4+cnt) outa[noparse][[/noparse]17]~ repeat ' WHEN BUTTON IS PRESSED, VALUE OF 255 SHOULD BE STORED IN EEPROM (HOW, I DON'T KNOW) if ina[noparse][[/noparse]0] == 1 StoreVal waitcnt(clkfreq*3+cnt) else ' WHEN BUTTON IS NOT PRESSED, RETRIEVED DATA IS DISPLAYED ON PST (PARALLAX SERIAL TERMINAL) RetrieveVal PRI StoreVal buffer[noparse][[/noparse]eepromAddress // 32] := 255 writeIt PRI RetrieveVal ' VARIABLE IS ASSIGNED VALUE FROM DEVICE 2 (MICROCHIP 24LC256) AT BUFFER LOCATION 32 readit retrievedData := buffer[noparse][[/noparse]eepromAddress // 32] ' SHOW DATA ON P SERIAL TERMINAL sio.dec(retrievedData) sio.Str(string(13," ",13,13)) waitcnt(clkfreq+cnt) PRI readIt if i2c.ReadPage(i2c#BootPin, i2c#EEPROM, eepromAddress, @buffer, 32) abort ' an error occurred during the read PRI writeIt | startTime if i2c.WritePage(i2c#BootPin, i2c#EEPROM, eepromAddress, @buffer, 32) abort ' an error occured during the write startTime := cnt ' prepare to check for a timeout repeat while i2c.WriteWait(i2c#BootPin, i2c#EEPROM, eepromAddress) if cnt - startTime > clkfreq / 10 abort ' waited more than a 1/10 second for the write to finishCheers,
Shmow
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 SCL = 28 eepromAddress = 0 VAR byte buffer[noparse][[/noparse]32] byte retrieveData OBJ i2c : "Basic_I2C_Driver" sio : "FullDuplexSerialPlus" PUB Main sio.start(31,30,0,115200) i2c.initialize(SCL) dira[noparse][[/noparse]6]~~ outa[noparse][[/noparse]6]~~ waitcnt(clkfreq*4+cnt) outa[noparse][[/noparse]6]~ RetrieveValue sio.str(string("retrieved",13,13)) sio.str(string("starting transfer",13)) StoreValue sio.str(string("Stored",13)) waitcnt(clkfreq*4+cnt) RetrieveValue sio.str(string("retrieved",13)) PRI readIt if i2c.ReadPage(i2c#BootPin, i2c#EEPROM, eepromAddress, @buffer, 32) sio.str(string("A Read Error Ocurred",13)) ' an error occurred during the read abort PRI writeIt | startTime if i2c.WritePage(i2c#BootPin, i2c#EEPROM, eepromAddress, @buffer, 32) sio.str(string("A Write Error Ocurred",13)) abort ' an error occured during the write startTime := cnt ' prepare to check for a timeout repeat while i2c.WriteWait(i2c#BootPin, i2c#EEPROM, eepromAddress) if cnt - startTime > clkfreq / 10 sio.str(string("Waiting Failed",13))' waited more than a 1/10 second for the write to finis abort PRI StoreValue buffer[noparse][[/noparse]eepromAddress // 32] := 128 writeIt PRI RetrieveValue readIt retrieveData := buffer[noparse][[/noparse]eepromAddress // 32] sio.dec(retrieveData) sio.str(string(13," ",13,13)) waitcnt(clkfreq+cnt)Just be careful with that:
repeat ' WHEN BUTTON IS PRESSED, VALUE OF 255 SHOULD BE STORED IN EEPROM (HOW, I DON'T KNOW) if ina[noparse][[/noparse]0] == 1 StoreVal waitcnt(clkfreq*3+cnt)Let's say it takes about 40 instruction to execute it. 20 instructions is 20*12.5ns = 0.25us.
If you keep your finger for 1sec on the button, you will execute this loop 4000 times.
An EEPROM can write about 1 000 000 times a value. Then you can have failures and you will have to replace it. So 1 000 000 / 4 000 = 250...
So if you try your program more than 250 times, you will burn your EEPROM.
Just update your code with that:
repeat ' WHEN BUTTON IS PRESSED, VALUE OF 255 SHOULD BE STORED IN EEPROM (HOW, I DON'T KNOW) if ina[noparse][[/noparse]0] == 1 repeat while ina[noparse][[/noparse]0] == 1 ' Add this line to wait until the button is released to store the data only one time. StoreVal waitcnt(clkfreq*3+cnt)Just be aware that this will old this cog until you release the button. For my onw project, I have a single cog to handle the inputs, so it's not olding anything on the other cogs.
JM
Linux? There is worst, but it's more expensive.
