Simple IRL530 Driver -- Am I Crazy (Loaded question, I know....)
JonnyMac
I want to experiment with some high-current LEDs for Christmas lighting and have whipped up the following circuit to buffer the 3.3v output of the Propeller to the gate of an IRL530; am I nuts or should I proceed to prototyping without worry of making a big cloud of smoke?
Jon McPhalen
Hollywood, CA
Jon McPhalen
Hollywood, CA
search.digikey.com/scripts/DkSearch/dksus.dll?vendor=0&keywords=irf3708pbf
Try an IRF3708 instead. You can drive the gate directly from the Prop.
Jon McPhalen
Hollywood, CA
Andy
Graham
Hi Phil, what do you mean by not fully characterized?
If possible, increase the gate voltage to 9-12v to reduce the heating on the mosfet.
The pull up resistor to V33 is unnecessary if the prop pin is set to output.
The pull up resistor to V50 could be changed to 5k-10k to save current if the load is on for long periods.
I use this circuit all the time.
www.fd.com.my
www.mercedes.com.my
There's no data for RDS(on) for gate voltages that low. Moreover, VGS(th) can be as high as 2.0V, which is too close to 3.3V for comfort.
As Phil points out, the Propeller takes quite a long time to boot up, so I have to make sure the FET doesn't come on when the pins are not configured, hence the pull-up.
Jon McPhalen
Hollywood, CA
I would at least provide 12V to what you have labeled V50 ... either through a zener diode off of the VIN supply or a voltage regulator off of the VIN supply.
What you will need to watch out for is when you turn the IRL530 'OFF'. It will spend more time in the linear region because you are not driving the signal High and relying on a pull-up resistor to do the job. Under heavier current loads this will cause heat buildup that could otherwise be avoided or reduced if the IRL530 was driven instead of pulled-up.
Beau Schwabe
IC Layout Engineer
