AMD Chipsets
Does anyone here have it in over at AMD? I can't seem to get through to anyone that knows the chipsets and I'm looking to use one of the phenom CPU's and an array of Radeon video processors in a motherboard project I'm doing with a propeller bio's. If anyone has any pinout info please let me know. Thanks
Leon Heller
Amateur radio callsign: G1HSM
The northern portion of the processor looks to be dedicated to the Northbridge; Northbridge controls the PCI bus and onboard video. And heads to the southbridge. Southbridge looks like it controls the SATA. . . I can't really pinout without pulling the chips but I'll try.
I don't have a hot air work station or a magnifying glass and that would help.
These chips look like QFN surface mount, does anyone know where I can get SIP/DIP socket conversion boards?
I'm already working on the multiphase PWM power plant for my board and I can picture peltier cooling my bus.
Anyone care to challenge the video card I mentioned? Maybe someone has a broken one to play with?
If you guys are interested in Realtek audio, I have the blueprint layout for their latest chips that all these motherboard companies are using.
Post Edited (Forst) : 8/3/2010 4:13:53 AM GMT
Oh, you are in for such a shock. They are BGA, and usually on 6-12 layer boards.
"I mean, if I went around sayin' I was an emperor just because some moistened bint had lobbed a scimitar at me they'd put me away!"
BGA, I'll look to see if I can find any boards, do you know how many pins they are?
Post Edited (Forst) : 8/3/2010 4:23:22 AM GMT
http://www.advanced.com/pdf/AIC_BGASktAdpt_revSept07.pdf
I guess 5 rows of pins would explain that crazy amount of layers.
These guys over at advanced make some serious stuff.
The flip-top even has a heatsink, pretty neat.
Post Edited (Forst) : 8/3/2010 4:55:47 AM GMT
http://forums.parallax.com/forums/default.aspx?m=456710&f=15&p=1#m456803
The adapters you quote in the pdf's have 5 rows of pins. The unit's I've seen on PC motherboards don't have free space, they are all pins. Have a look at the underside of the motherboard and you will often find a via for every pin of a BGA.
Cheap Chinese hot air rework stations will do an adequate job, but if you plan on scrapping chips of old boards and re-using them you'll need a re-balling kit also.
