IR sensor application
I am wondering if it is possible to use the BASIC Stamp with an IR sensor to send a command to a program (for example, send the play command to media player).
Currently, I am using this code from Parallax:
What I want to do (in pseudocode):
IF P0=1 THEN play_music()
I looked at www.lirc.org/ and that gives an idea of what I want to do, but is much more advanced. Does anyone have any ideas on how to implement this?
' ========================================================================= ' ' File...... PIR_Simple.bs2 ' Purpose... Show Output State Of PIR Sensor ' Author.... Parallax, Inc. ' E-mail.... support@parallax.com ' Started... 12-14-2005 ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' This program displays the current state of the PIR Sensor connected to P0 ' on the DEBUG screen. ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: DO DEBUG HOME, BIN1 IN0 ' Display Status Of P0 At Home Pos. PAUSE 100 ' Small Delay LOOP ' Repeat Forever
Whether you can control your media player depends on what kind of media player you have. There are several MP3 players that can be controlled directly by a microcontroller like a Stamp. The Vinculum VMusic2 is one example (Google "Vinculum VMusic2") that I've used for a sequenced sound player. You can also take other MP3 players, take them apart, solder wires across the play button switch (and possibly other buttons), and use a reed relay to close the switch contacts with the relay controlled by the Stamp.
