What is this electrical symbol?
Hello Everyone
I am trying to find the meaning of an electrical symbol.· It is a switch of some sort, and I am 99.99% certain that it is a pushbutton.· Furthermore, I am fairly certain that it is a double pole single throw pushbutton switch.· And considering it's application as shown in the partial schematic below, I am also fairly certain that it is not a momentary switch.· I have searched supply houses and other websites to try and identify this switch, because I intend·to duplicate the full circuit board with some minor modifications, but would like to keep the switches.· If you are interested, the full datasheet can be found at http://www.st.com/stonline/products/literature/an/8607/eval6208n.pdf.· Otherwise the symbol and it's use in a schematic have been attached.
Thanks in advance
Bruce
Thanks in advance
Bruce
Duane
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
want speed?·want·to use the Propeller?·want to stay with BASIC___www.propbasic.com___
You can feel stupid by asking a stupid question or You can be really·stupid by not asking at all.
In the picture on P 34, the switches in question are on the left side of the board, to the right of the header, and about half way up. The switch caps are tan, red, orange and yellow, and numbered 1, 2, 3 and 4. I believe these are each a "slide switch".
Boiled down, each pair is a SPDT switch to connect the appropriate resistor to either Ground or "pull up".
John R.
Click here to see my Nomad Build Log
Post Edited (John R.) : 8/2/2010 1:17:44 AM GMT
regards
adrian
All of these switches connect to control signals that come from an external source so I would guess that they are used to set the board up for whatever signals are controlling it.
Since the setup is usually done only one time and jumpers cost less than switches I would go with jumpers.
Obviously, it is 'ganged'. But how much is ganged together - pairs or all eight, would be revealed in a users manual (You would have 4 devices for selection or one).
Functionally, it appears that one contact slides to replace the role of another. In one position, both make contact, but it the other, one contact remains. This leads me to wonder why bother with opening and closing that remaining contact. It could just be poor design with excessive logic. Or, a bad drawing of a simpler switch.
John R. is likely right and it is just lousy graphic presentation.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Post Edited (Loopy Byteloose) : 8/2/2010 3:25:00 PM GMT
Andrew Williams
WBA Consulting
PowerTwig Dual Output Power Supply Module
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
I think you have the best answer so far, and you even included a pic of the switch [noparse]:)[/noparse]· I suppose I should have done that!·
I·agree·that it is a four gang spdt switch.· I should have paid better attention to the fact that it is listed as one switch (SW1 in the schematic)·having 16 pins.· Now I say it is a four gang spdt latching (non-momentary) pushbutton switch.
One·thing is·certain, it could be accomplished with jumpers, dip switches, toggles, etc...
I have put in a support request to ST Microelectronics asking them just what the heck it is and for a part number.· It is probably a custom made four gang switch just for that series of evaluation boards.
Once again, I thank everyone·for·their input.· If anybody has a part number for an inexpensive part that would accomplish the same task, I would be very appreciative.· Of course the part should have a small footprint and be pcb mount.
Bruce
Yes, that would be the cheapest, but you got to admit, that would change the whole versatility of the board.· I like the whole concept of changing a setting at the push of a button and using less pins on the uProcessor or logic.
Mouser has some nice buttons·at around $8 a pop X (14 boards X 4 buttons per board) = $208
My next choice would be DIP switches or slide switches.
However, I am beginning to think the best solution and cheapest solution for me is the 4X3 array of SIPs.· My only problem is that I hate jumper settings.
Bruce
Bruce
Even with the 3x4 header layout, you still have a switch option. For example, four of these will fit the same footprint.
LOL· I made a mistake in my math earlier.· It would be $448 for the nice buttons.··
Thanks Phil I definitely appreciate that.
Bruce
I am also thinking this DIP switch would work (Part #206-124ST) on this data sheet, http://www.ctscorp.com/components/Datasheets/206-208.pdf.· I wish I had one to do a continuity test on.
Bruce
