IR sensor application
I am wondering if it is possible to use the BASIC Stamp with an IR sensor to send a command to a program (for example, send the play command to media player).
Currently, I am using this code from Parallax:
What I want to do (in pseudocode):
IF P0=1 THEN play_music()
I looked at www.lirc.org/ and that gives an idea of what I want to do, but is much more advanced. Does anyone have any ideas on how to implement this?
' File...... PIR_Simple.bs2
' Purpose... Show Output State Of PIR Sensor
' Author.... Parallax, Inc.
' E-mail.... support@parallax.com
' Started... 12-14-2005
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[noparse][[/noparse] Program Description ]---------------------------------------------
' This program displays the current state of the PIR Sensor connected to P0
' on the DEBUG screen.
' -----[noparse][[/noparse] Program Code ]----------------------------------------------------
Main:
DO
DEBUG HOME, BIN1 IN0 ' Display Status Of P0 At Home Pos.
PAUSE 100 ' Small Delay
LOOP ' Repeat Forever
Whether you can control your media player depends on what kind of media player you have. There are several MP3 players that can be controlled directly by a microcontroller like a Stamp. The Vinculum VMusic2 is one example (Google "Vinculum VMusic2") that I've used for a sequenced sound player. You can also take other MP3 players, take them apart, solder wires across the play button switch (and possibly other buttons), and use a reed relay to close the switch contacts with the relay controlled by the Stamp.
