What are the requirements for OSC1?
I am considering the use of an external clock signal to be used for the SX48. I understand the signal is to be connected to OSC1.
What are the electrical requirements for this to work properly?
Thank you,
Gary
Thank you,
Gary
(I know, I have a batch of boards with 3.3V osc's. And they won't clock the SX! Have to manually modify each board for a 5V osc)· [noparse]:([/noparse]
-Dan
"A saint-like quantity of patience is a help, if this is unavailable, a salty vocabulary works nearly as well." - A. S. Weaver
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
I have a project that runs at 3.3 volts and has a 3.3 volt oscillator chip driving it and it all works just fine. Are you trying to use a 3.3 volt clock with a 5 volt SX project? The project in question is the 6 port RS-485 hub that I built. There's a two part article I wrote about it in Circuit Cellar a few months back. I use a pre-packaged clock chip and divide it by two using a 74LV74, which is basically the 74xx TTL parts designed to run on anything from 2 to 5.5 volts.
PeterM
