Recovering code from stamp
Unfortunately I can't seem to get the forum·search to work with queries that contain more than one word.
Is it possible to retrieve code from a Basic Stamp? I expect the short answer is 'no' but figured I would ask out of desperation.
It seems my source code did not make the transition with the rest of my data when my desktop got re-imaged. The only upside is that since the BS2 doesn't hold that much code the program wasn't too big.
·The downside being I wrote it 11 months ago so I don't even remember how everything works.
At least I still have the pinouts listed on a whiteboard from way back then. I just need to remember how to change memory pages, deal with IO and LCD screens. [noparse];)[/noparse]
It sounds like a good opportunity to refresh your programming skills. Oh, and as soon as I learned that the automatic backup software on my external hard drive cannot be set to automatically backup Stamp and Spin source files, I made a new directory there and backed all of them up by hand, to avoid exactly the kind of situation you're in now.
I know it is compiled code on the Stamp. I was just hoping there might be a reverse compiler. I wouldn't even mind if the variables were v1, v2, v3. The plus side is that it will probably be better code this time around. I just need to get out of the Flex/Java mindset I've been in the last few months and remember how the Stamp works.
It wouldn't be a big deal normally except I needed to fix one bug on that old code in preperation for a trip next week. I have a PTU that I'm controlling with the Stamp and wanted to do some timelapse photography with motion while in Great Basin. That just means I'll have some serious coding to do over the next several evenings. ;^)
The weather we have been having lately is more of a concern... I sure hope it clears up in time for the meteor showers.
And this is just another example of the old proverb: There are two types of computer users: Those who have lost data and those who are about to lose data.
Thanks for the reply.
As much as rewriting your program from scratch after nearly a year's absence will be a real pain, you will probably end up with a better program
May it all work out and enjoy the showers.
takes i stumbled over a link about
a guy who apparantly is able to recover code.
But it is probably not that simple as that sounds.
As he needs access to the stamp, and needs to do some work.
http://home.earthlink.net/~parkiss/recovery.txt
Buttons, LCD and serial IO should be easy enough given the examples in the book. I remember several nights having issues with the communications. I don't recall if that was on the PTU side or the Stamp side.
Ah well, it will all come back to me. :^)
If it sounds too good to be true, it probably is ...
There's really no way to recover all the contents of the EEPROM without an EEPROM reader and a hardware jig that makes contact with the pins of the EEPROM. The guy at the link you found may have the hardware needed. EEPROM programmers (readers) are not that hard to get and someone could build a jig to make the right contacts with the EEPROM, but it's not simple.
Once you have the EEPROM contents, it's a lot of work to decode and there is no way to recover labels, variable names, or constant declarations. They simply don't exist in the EEPROM.
- Stephen
I use to collect everything in·ring binders, like pbasic code, drawings, pcb-layout, datasheets and all other kind of stuff for each project I'm working on.
KjellO
