Which display driver?
Hi,
I just bought a screen like this one:
http://www.parallax.com/Store/Accessories/Displays/tabid/159/CategoryID/34/List/0/SortField/0/Level/a/ProductID/337/Default.aspx
And I'm wondering which screen driver has been used for what is displayed? I looked at Obex and found many objects. So not sure which one to take.
What I want to build is a graphical interface for a MP3 player. So I want to display mainly text, but also, if possible, scroll bars, etc.
Also, there is 115 200 pixel on this screen. How many colors for each? If it's 256, which mean 8 bits, I will never have enought memory on the propeller to store that. Should I had an external memory to handle that? Even with 16 colors, it's still 56K that I will need.
I took a look at the 1pin driver (http://forums.parallax.com/forums/default.aspx?f=25&m=366805) but I still have a lot to learn because I don't understand anything [noparse];)[/noparse]
JM
JM
Propeller Pages: Propeller JVM
JM
Linux? There is worst, but it's more expensive.
http://cvs.shoplocal.com/cvs/Default.aspx?action=browsepagedetail&storeid=2416029&rapid=942075&pagenumber=7&listingid=-2086469025
Potatotext is very good, but limited in that only two colors per 8x8 pixel cell. The upside is the characters are easily redefined, and text density on the screen is good. For that display, the 32 column or 40 column displays will provide plenty of text, and good resolution for widgets.
The Parallax driver, that I commented, has a bit more coarse text capabilities, but the included graphics library is sweet.
If you use the Parallax driver, consider drawing all the screen tiles and predrawing graphical elements, like scroll bars and such. You can use color palette changes to animate them, and avoid a double buffer display. This might all happen in as little as 8-12K.
If you use potatotext, take a good look at the font table. There are 127 undefined characters in there. You can define the shape of those, then "print" them to the screen, using their character values, just like you would text strings. A few common shapes can be used all over the screen. This is how it was done on older 8 bit computers, and it can be pretty efficient. You could get down to a few K, maybe 5, if you write over the HUB memory locations used to start the drivers up.
Have fun!
8x8 color 80 Column NTSC Text Object
Wondering how to set tile colors in the graphics_demo.spin?
The parallax driver can place any 4 of them within a 16x16 tile. Potatotext can place any two of them, in a 8x8 tile.
Then slowly but surely, I moved to Turbo Pascal where there was "Turbo Vision", you know? The API which provided ways to draw windows using text characteres made for that. From 176 to 223 in the old ascii table. So I think I should be ok to apply the same idea on the propeller. I will just have to define the 127 remaining characters with what I need. I order to save some memory, I will put my charactere tables in the SD.
http://thomasjensen.com/software/buchfink/buchfink.gif
Regarding the scroll bars, if I use characteres also, will I still need 8-12K? Because it's a bit to much for my application. I already need memory for OGG buffers, menus content, etc.
Will the memory required be based on the driver I will use? Or the use I will do of the driver?
Regarding the screen, it's 480x240px. Does it mean I can do 30x15 chars with 16 by 16 tiles (Parallax), and 60x30 chars with 8 by 8 (potatotext)?
In a perfect world, I would like to have a 8x8 tiles with 3 colors [noparse];)[/noparse] Because 2 is a bit small. But maybe I can deal with that. Do you know why there is a 2 color limitation? Is it something realistic to add a 3rd one? Or there is some limitations like speed of memory?
I will receive my screen today, so I will do some testing soon...
JM
Message Edité (jmspaggi) : 7/30/2010 4:14:02 PM GMT
It's possible to do 4 color with the 8x8. It just hasn't been done. Modding that driver involves ripping out the font conversion code, stripping down the waitvid loop, VSCL frame timing adjustment, and font tweaks to render properly in 4 colors.
Anyone feel free to rip into that. I can answer questions, but I've kind of got to stay on the course I'm on right now.
Honestly, if you want more colors, I think I would use the Parallax driver. If you are creative with it, a whole lot can be done with the tiles and color capability it has. IMHO, that's probably easier than tearing into potatotext right now.
[noparse][[/noparse]quote]
The only word I understand here is "the" [noparse];)[/noparse] So I guess I'm better use something already done until I'm able to understand how it works.
When you are talking about the Parallax driver, are you talking about TV_Text.spin? I looked into the code, and seems that it's for 40 cols, 13 rows. Can I "simply" change those values to have 30x15? Or I will also have to do thing I even don't understand the name? [noparse];)[/noparse]
I also looked at the TV.spin, but it's all PASM and a bit to hard for me for now. I think I understand how to use it, how to put information in the screen, but I'm not able to find where it's taking the tiles definition. Is it on the Propeller ROM where we have the charactere table? But this one is 16x32, and I want to do 16x16...
I will continue to dig the source, but if you can point me to the right direction, that will help.
JM
Which mean it's using the 16x32 tiles so I will have to point it on my own tiles definitions.
I will start to play with it, do some update and see the results.
The more I read, the more I understand [noparse];)[/noparse] A chance [noparse];)[/noparse]
JM
You've got a wide variety of options. Take a look at the post in my signature, "having trouble with.,.." Colors, tiles and tile addresses are explained in the comments.
· Mike B.
