concatenate a string
RESOLVED!!
FIXED and working:
pin connections:
THANKS
Post Edited (laser-vector) : 7/30/2010 8:20:00 AM GMT
FIXED and working:
pin connections:
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
cols = 80
rows = 64
tiles = cols * rows
spacetile = $220
mousespeed = 10
scale = 10
OBJ
vga : "VGA_1280x1024_Tile_Driver_With_Cursor"
mouse : "mouse"
num : "numbers"
VAR
long col, row, color
long boxcolor, boxptr
long array[noparse][[/noparse]tiles/2]
long cursor[noparse][[/noparse]1+32]
long cursor_x, cursor_y, cursor_col, cursor_def
long changeme
long var1
long var2
byte temp[noparse][[/noparse]80]
PUB start | i, j, k
'start mouse and set bound parameters
mouse.start(24, 25)
mouse.bound_limits(0, 0, 0, 1279 / mousespeed, 1023 / mousespeed, 0)
mouse.bound_scales(1, 1, 0)
mouse.bound_preset(640 / mousespeed, 512 / mousespeed, 0)
'start vga tile driver
vga.start(16, @array, @vgacolors, @cursor_x, 0, 0)
menu4
PUB menu4 | update
update := -1
dira[noparse][[/noparse]3..0]~ {sets pins 3..0 to inputs}
print($100) {clears the screen from the last menu}
var1 := string("Temperature:")
var2 := string("°C")
repeat
box(2, 58, 0, string("MAIN MENU"))
bytemove(@temp, var1, strsize(var1) + 1)
bytemove(@temp + strsize(@temp), num.tostr(changeme*100, num#dec) , strsize(num.tostr(changeme*100, num#dec))+ 1)
bytemove(@temp + strsize(@temp), var2, strsize(var2) + 1)
box(28, 30, 0, (@temp))
cursor_x := mouse.bound_x * mousespeed
cursor_y := mouse.bound_y * mousespeed
if cursor_y => 30 and not cursor_y => 100 and cursor_x => 25 and not cursor_x => 210
cursor_def := 0
cursor_col := $ff
else
cursor_def := 1
cursor_col := $ff
if mouse.button(0) and cursor_y => 30 and not cursor_y => 100 and cursor_x => 25 and not cursor_x => 210
menu1
quit
changeme := ina[noparse][[/noparse]3..0] {changeme now = the value of pins 3..0}
repeat while not update == changeme {loop only executes if changeme is updated/changes}
print($100)
print($110)
print_string(string("BINARY ="))
print_string(num.tostr(changeme, num#bin))
print_string(string(" ... HEX ="))
print_string(num.tostr(changeme, num#hex))
print_string(string(" ... DEC="))
print_string(num.tostr(changeme, num#dec))
update := changeme {update is set to the value of changeme so the loop waits untill their values differ}
PRI box(left, top, clr, str) | width, height, x, y, i
' Draw a box
boxcolor := $10 + clr
color := clr + 5
width := strsize(str)
height := 2
boxptr := top * cols + left
boxchr($0)
repeat i from 1 to width
boxchr($C)
boxchr($8)
repeat i from 1 to height
boxptr := (top + i) * cols + left
boxchr($A)
boxptr += width
boxchr($B)
boxptr := (top + height + 1) * cols + left
boxchr($1)
boxchr($D)
boxchr($9)
col := left + 1
row := top + 1
print_string(str)
PRI boxchr(c): i
array.word[noparse][[/noparse]boxptr++] := $200 + c + boxcolor << 10
PRI print_string(ptr)
repeat while byte[noparse][[/noparse]ptr]
print(byte[noparse][[/noparse]ptr++])
PRI print(c) | i, k
'' Print a character
'' $0D = new line
'' $20..$FF = character
'' $100 = clear screen
'' $101 = home
'' $108 = backspace
''$110..$11F = select color
case c
$0D: 'return?
newline
$20..$FF: 'character?
k := color << 1 + c & 1
i := $200 + (c & $FE) + k << 10
array.word[noparse][[/noparse]row * cols + col] := i
array.word[noparse][[/noparse](row + 1) * cols + col] := i | 1
if ++col == cols
newline
$100: 'clear screen?
wordfill(@array, spacetile, tiles)
col := row := 0
$101: 'home?
col := row := 0
$108: 'backspace?
if col
col--
$110..$11F: 'select color?
color := c & $F
PRI newline | i
col := 0
if (row += 2) == rows
row -= 2
'scroll lines
repeat i from 0 to rows-3
wordmove(@array.word[noparse][[/noparse]i*cols], @array.word[noparse][[/noparse](i+2)*cols], cols)
'clear new line
wordfill(@array.word[noparse][[/noparse](rows-2)*cols], spacetile, cols<<1)
DAT
vgacolors long
long $3C043C04 'lt grey on dk grey
long $3C3C0404
long $C000C000 'red
long $C0C00000
long $30003000 'green
long $30300000
long $0C000C00 'blue
long $0C0C0000
long $FC00FC00 'white
long $FCFC0000
long $FF80FF80 'red/white
long $FFFF8080
long $FF20FF20 'green/white
long $FFFF2020
long $FF28FF28 'cyan/white
long $FFFF2828
long $C0408080 'redbox
long $3010F020 'greenbox
long $3C142828 'cyanbox
long $FC54A8A8 'greybox
long $3C14FF28 'cyanbox+underscore
long $F030C050 'graphics colors
long $881430FC
long $8008FCA4
byte 0
THANKS
strings are BYTE-sequences not long-sequences
{removed this code because it was junk...}Post Edited (laser-vector) : 7/30/2010 8:20:58 AM GMT
propeller.wikispaces.com/Strings
Massimo
you are creating a string which is bytes - why is temp where yo are putting the string longs?
You are putting the temperature of 100 is TEMP but this is where you are putting the string so overwriting the 100
longmove - you are moving a string which is bytes so you are moving 4x the bytes
the longmove of TEMP into he string doesnt' convert a number which is a number of 100 into a string which is '1', '0', '0' you get a character which is a value of 100 - look at the routine you are calling with num.tostr that is convrting a number to its string
This is hard one to explain.·
var1·:=·string("Temperature:·")
var1 now contains the location where the string of bytes "Temperature:·" is stored.· Hense the @var1 in the bytemove commands.· The @ means "location of."
One of your first problems is you fill the first 32 longs of your array TEMP with zero with the longfill command after you set Temp[noparse][[/noparse]0] to 100.
StefanL38 is correct, strings are sequences of bytes and it would be a lot easier to keep track of your strings if you used arrays of bytes.· You do want to continue to use longs for memory location addresses.
I recognize print and print_string commands from some of your other posts, but again StefanL38 is again correct, you want to at least inform us what methods you are using.· I assume you're modifying one of the VGA objects.
Read through some of the objects in the library and demos to find examples of dealing with strings.· It takes some getting used to.
Duane
Note: Timmoore posted as I was writting this.· Amen to what he says.
Edit:· I only saw Timmoore's post.· I started writting after StefanL38 comments.· laser-vector, thanks for adding you full code.· Your longfill (or is it bytefill now, I can't see the thread while editing) is still setting Temp to zero (which is actually a minor part of what is wrong here).
Post Edited (Duane Degn) : 7/30/2010 6:27:55 AM GMT
I just looked through Numbers.spin.· I found if rather difficult to understand.· I copied a method I use to check the a string from a balance to·pull out the weight.· Hopefully you can follow some of it and gain a better understanding of string.· I don't think the method calls any other methods but there are a couple of global variable so the rest of the program has access to the weight.· This method checks for the letter "g" (upper or lowercase) because any characters after the "g" are not part of the weight.
PUB StrToPseudonumber(rawBufferPointer, bufferPointer) | character, afterDecimalFlag, localNumber, size, endFlag leftDecimalMass := 0 rightDecimalMass := 0 positiveMassFlag := 1 afterDecimalFlag := 0 endFlag := 0 size := strsize(rawBufferPointer) repeat size character := byte[noparse][[/noparse]rawBufferPointer++] localNumber := 999 ' if localNumber is still 999 I know the character read wasn't a numeral. case character 43: positiveMassFlag := 1 ' + 45: positiveMassFlag := 0 ' - 46: afterDecimalFlag := 1 ' . byte[noparse][[/noparse]bufferPointer++] := character 48..57: localNumber := character - 48 ' 48 is the ASCII value for zero (see character chart in help menu) byte[noparse][[/noparse]bufferPointer++] := character 71, 103: endFlag := 1 ' g if localNumber < 10 and endFlag == 0 ' localNumber will be 999 still if no numeral was found this loop if afterDecimalFlag rightDecimalMass := (rightDecimalMass * 10) + localNumber ' I want the weight in both a string and in decimal form in a variable. else leftSize++ leftDecimalMass := (leftDecimalMass * 10) + localNumber byte[noparse][[/noparse]bufferPointer] := 0 ' Strings are supposed to end in zero, so I add on to make sure it does.Edit:· Fixed spelling and added additional comments in code.
Post Edited (Duane Degn) : 7/30/2010 6:52:30 AM GMT
Answering questions on this forum is just for the person asking the orignial question.· Many people search these forums for thread relating to a topic they are having trouble with.· Having old posts online serve as a resource for others in the future.· I myself have not asked many questions here.· I've used Google advanced search to find treads that discussed the problem I'm having and, more often than not can find the answer I'm looking for.· What I'm getting at is . . .
I don't think it is helpful to others to remove the original post where the question is asked.· You could have better served the community buy posting your thanks as a reply to previous posts.
Duane
Edit: removed "<!-- Edit -->."· How'd that get there?· I think it's a tag from part of a comment I was quoating but decided to remove and it left behind invisible text.
Post Edited (Duane Degn) : 7/30/2010 7:53:40 AM GMT
