Highest clock speed
What is the highest clock speed for the propeller chip? Right now I got mine at 100mhz and I would want it to run faster, is that possible?
iPhone expert
iPhone expert
iPhone expert
Exceeding that might work great, with the chance of that happening dropping rapidly according to what you see in the data sheet.
At some point, it will appear to work great! That's the hard part. Some things will perform, others won't, and it will just appear buggy.
Then it doesn't work great.
Be sure and test everything at the known solid clock before advancing the speed of it.
8x8 color 80 Column NTSC Text Object
Wondering how to set tile colors in the graphics_demo.spin?
