Okay, so this is what I will do. I'm going to post the current code in the obex. That will let people use my driver.
Next, I'll update the block driver to support card detect mode so that it can see if the card is inserted.
Card detect will work like this. When you start the driver you will need to pass it the card detect pin number. This pin number can overlap with another pin. The card detect feature will see no card is inserted when the pin is high and a card is inserted when the pin is low.
This allows Rayman's circuit to work but also allows you to have the CD and WR pins on seperate prop pins if you want.
I'll be doing the same thing for write protect but that has to be built into my driver more... I plan to implement a more generalized caching technique to make my code cleaner and faster.
I'd be very appreciative if you added support for my circuit. But, it's not totally necessary, because it's pretty trivial to just test those pins before starting up the SD card driver...
Running command: test
Creating test file "testfile" ... Success
Wrote 131,072 bytes at 0000005170 bytes per second
Running byte stride write test...
Wrote 32,768 bytes at 0000002969 bytes per second
Running byte stride read test...
Read 32,768 bytes at 0000004262 bytes per second
Running word stride write test...
Wrote 65,5536 bytes at 0000004472 bytes per second
Running word stride read test...
Read 65,5536 bytes at 0000008350 bytes per second
Running long stride write test...
Wrote 131,072 bytes at 0000006009 bytes per second
Running long stride read test...
Read 131,072 bytes at 0000016350 bytes per second
Running speed writing test (512 bytes at a time)...
Wrote 131,072 bytes at 0000008944 bytes per second
Running speed reading test (512 bytes at a time)...
Read 131,072 bytes at 0000250432 bytes per second
Running append test... Success
Running seek test... Success
Deleting test file "testfile" ... Success
Hi,
I'm hoping to use Kye's SD code in my project but I'm still a newbie on SPIN so I think I used the openFile wrongly. I think anyone could catch my mistake.
From the original program, the parameter for str.tokenizeString is always "0". Does this means it points to the first variable declared in VAR (which is charactersPointer)?
Thanks in advance.
Ken
Post Edited (MacTuxLin) : 7/29/2010 3:18:50 AM GMT
Thank you Dr_Acula! I did removed the tokenize but initially it didn't work. But re-looking at your example, I removed the ".txt" extension & now it worked! I don't know why so the openFile cannot work files with .3 extensions?
That is odd as my code does work with extensions. Anyway, if you can create a file and open it and close it then you can start testing things more thoroughly.
The tokenize string function is a special version of the standard C strtok function that is used to break strings up into pieces. My tokenize string funtion looks for white space characters to break the string up on. Unless you have use input that needs to be toeknized don't use it.
Open file should have no problems with the .txt extension. I've used this function all the time to play .wav files and read .txt files. Since opening "test001" worked and not "test001.txt" this means that your file was not named "test001.txt" but "test001". The exension matters and is part of the name of the file. "stuff' and stuff.txt" can be two completely different files in one directory.
Also note that my functions abort when they cannot process a request and return an error string. That said, you have no way to catch those failures in your code.
I don't know what the DS1302 needs to operate. You will need to find a driver for that thing yourself. If you look through the FATEngine you'll find a function called "readClock". Just replace all the references to the DS1307 there.
Also, you'll need to remove the references to the DS1307 code in "FATEngineStart" and FATEngineStop" functions.
Don't know what VFAT is. If its not FAT32 or FAT16 my driver will refuse to mount the SD card an throw and erorr about the file system not being supported.
From Q/A Wiki:
(Virtual File Allocation Table) The file system used in Windows for Workgroups and Windows 95/98. It provided 32-bit Protected Mode access for file manipulation. VFAT was faster than, but also compatible with, the DOS 16-bit File Allocation Table (FAT). In Windows for Workgroups, VFAT was called "32-bit file access." In Windows 95/98, it supported long file names up to 255 characters.
Right now opening two files is not supported seemlessly. Unless you understand what you are doing to have two files open at once you will corrupt your SD card file system if you try to have two files open at once.
Way faster? Wow. I have some EEPROMs linked to my propeller to store Strings I want to display, so look like I'm beter to move them on the SD...
Regading the 2 files, will I corrupt the system even if everything is only on READ-ONLY mode? I just want to read an OGG file, and at the same time the catalogue to display the directory (or any other directory) content. Anyway, since you made the option to move in a file, I still can close one the time I look at the other, but I was just trying [noparse];)[/noparse]
When I use it on my main loop, it's working perfectly. But when I'm trying to use it from a cog, listName call is never returning.
Here is my code:
CON
_cardDataOutPin = 7
_cardClockPin = 6
_cardDataInPin = 5
_cardChipSelectPin = 4
_clockDataPin = 25
_clockClockPin = 24_clkmode = xtal1 + pll16x_xinfreq = 5_000_000VARlong sd_stack [64]
long volumeLabel
OBJ
fs : "SD2.0_FATEngine"
sx : "FullDuplexSingleton"
rtc: "DS1307_RTCEngine.spin"PUBstart(lf_number)
sx.start(31,30,0,115200)
ifnot(rtc.RTCEngineStart(_clockDataPin, _clockClockPin))
sx.str(string($d,"Not able to start the RTCEngine",$d))
reboot
ifnot(fs.FATEngineStart(_cardDataOutPin, _cardClockPin, _cardDataInPin, _cardChipSelectPin, _clockDataPin, _clockClockPin))
sx.str(string($d,"Not able to start the FATEngine",$d))
reboot
volumeLabel := fs.mountPartition (0, 0)
sx.str(string("Volume label: "))
sx.str(volumeLabel)
sx.str(string($d))
sx.str(string("Changing directory to : "))
sx.str(fs.changeDirectory(string("\")))
sx.str(string($d))
cognew (process, @sd_stack) ' Comment to run outside of the cof'process ' Uncomment to run outside of the cogPUBprocess | index, fileName
sx.str(string("Listing files...", $d))
index := 0
fs.listName("T")
repeat
fileName := fs.listName(0)
sx.str(string("Read "))
sx.str(fileName)
sx.str(string(" Index="))
sx.dec(index)
sx.str(string(" strsize="))
sx.dec(strsize(fileName))
sx.str(string($d))
until fileName == 0repeat' Comment to run outside of the cog
When I run that from a cog, I get a respons from fs.listName("T") then the next listName call never return. If I run that from the main, it's working fine.
So I think I'm doing something wrong, but I'm working on that for 3 hours now with no result
Its probably working now because you made the stack larger.
My stack size estimates included in my code are only estimates on about how many longs each function call takes. I base these estimates off a question I asked Chip back in a video fourm chat thingy last year.
With the file system driver the stack needed gets very large for all the function calls.
Oh, and are you usign the code from the OBEX? Its slightly better in handling wierd stuff like this.
I'm not sure it's coming from the stack. Because it was not working, then I move the engine start into the cog and it was working. I just retried and figured that the issue is coming from the serial output I'm using. If I put it on the start method, it's not working. If I put it on the cog, it's working. All you Engine can be put in the start or in the cog and easy working fine in both cases
Also, I will only use read functions from your object. Do you think it's easy for someone quite new in SPIN to do some clean-up to remove all what is write related to save some space?
You can comment out any function that doesn't cause the object to complain about compiling. If you get a compile error after commenting out a function then put that function back in.
So, I included locking in the lowest level detail of the driver so that two or more cores won't have problems reading and writing sectors off the SD card. However, this doesn't protect the file system.
So... if all your doing is reading... Then just avoid closing two files in the same directory at the same time or calling the disk free and used space functions.
A freak accident can happen where if you close two files at the same time that are in the same directory... one of the files will have its last access time stamp corrupted.
So, reading isn't really that bad. But if you were writing... oh boy. Stuff can go really wrong.
I'm working on a new release that will solve this problem.
Also, I don't need to time stamp for the file. I'm doing an OGG reader so this information is not required for me. I will probably comment that too.
So if I remove the last access time stamp, and all the write methodes, does it mean I can keep 2 files opened at the same time?
Because I need to open 2 files in the same directory. The catalogue where I have the translation ShortName <=> LongName, and the musique file itself... I will try, and see if it's working, else, I will wait for the V2 of the driver anyway, I took me the whole day just to find how to send the list of files from one cog to another one, you will be at the V99 when I will be ready to open the musique file
You just read the input state of two SD pins that are normally outputs...
This feature is not important at all for most hobby work, but essential for "real world" apps.
My Prop Apps:· http://www.rayslogic.com/propeller/Programming/Programming.htm
My Prop Info: ·http://www.rayslogic.com/propeller/propeller.htm
My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
Nyamekye,
Nyamekye,
Thank you all.
Nyamekye,
Here are the results for my 4GB PNY Card.
Running command: test Creating test file "testfile" ... Success Wrote 131,072 bytes at 0000005170 bytes per second Running byte stride write test... Wrote 32,768 bytes at 0000002969 bytes per second Running byte stride read test... Read 32,768 bytes at 0000004262 bytes per second Running word stride write test... Wrote 65,5536 bytes at 0000004472 bytes per second Running word stride read test... Read 65,5536 bytes at 0000008350 bytes per second Running long stride write test... Wrote 131,072 bytes at 0000006009 bytes per second Running long stride read test... Read 131,072 bytes at 0000016350 bytes per second Running speed writing test (512 bytes at a time)... Wrote 131,072 bytes at 0000008944 bytes per second Running speed reading test (512 bytes at a time)... Read 131,072 bytes at 0000250432 bytes per second Running append test... Success Running seek test... Success Deleting test file "testfile" ... Success
Visit Zappman's Blog at Savage Circuits
Nyamekye,
The perfect system for rapidly switching between hardcore MPM network programming and games. (Not necessarily in that order *grin*).
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 _SD_DOPin = 0 _SD_DIPin = 2 _SD_CKPin = 1 _SD_CSPin = 3 OBJ FAT : "SD2.0_FATEngine" NUM : "Numbers" STR : "C300M_STREngine" COM : "RS232_COMEngine" PUB Main com.COMEngineStart(31, 30, 115_200) waitcnt(clkfreq + cnt) ifnot(fat.FATEngineStart(_SD_DOPin, _SD_CKPin, _SD_DIPin, _SD_CSPin, _clockDataPin, _clockClockPin)) reboot com.transmitString(fat.mountPartition(str.decimalToInteger(str.tokenizeString(0)), byte[noparse][[/noparse]str.tokenizeString(0)])) com.transmitString(string("Disk 0x")) com.transmitString(str.integerToHexadecimal(fat.checkDiskSignature, 8)) com.transmitString(string(" with volume ID 0x")) com.transmitString(str.integerToHexadecimal(fat.checkVolumeIdentification, 8)) com.transmitString(string(" a.k.a ")) com.transmitString(str.trimString(fat.checkVolumeLabel)) com.transmitString(string(" ready", _newLineCharacter)) waitcnt(clkfreq + cnt) '----------------- 'It Mounted OK. '----------------- 'Trying to open file com.transmitString(fat.openFile(str.tokenizeString(string("test001.txt")),"R")) '----------------- 'com showed nothing. Seems to be wrong? '-----------------
Thanks in advance.
Ken
fat.openFile(fat.newFile(string("testfile")), "W")
and for a file that already exists
fat.openFile(string("testFile"), "R")
see if one of those helps?
also I don't think it is related as you say it mounts, but my mount code is shorter
fat.mountPartition(0,0) ' mount the sd card
though I think yours still has the same effect of producing zeros
Ken
http://www.cplusplus.com/reference/clibrary/cstring/strtok/
Nyamekye,
Ken
I checked the code and the DS1307 needs only two pins and the ds1302 needs 3.· Is it safe to leave out the extra pin o the 1302?
Thanks for the replies in advance.
http://WhatsAvailable.org Software and Gadgets for Windows 7.
Nyamekye,
When I look at my card, it says VFAT. Is VFAT the same thing as FAT32? Or should I format it un FAT32 if I want to use it with your driver?
JM
Linux? There is worst, but it's more expensive.
Nyamekye,
From Q/A Wiki:
Wow! what a fantastic job you did developing all of this. I look forward to using it in a project. I like the recording features you added as well.
Thanks!
Bob
@Kye:
Also, is it possible to open 2 files at the same time? Or do I have to close the first one before opening the second one?
I'm just waiting for the SD reader from Parallax [noparse];)[/noparse] I really hope it will arrive soon. I want to test that?
Also, regarding performances, is that faster that an EEPROM? Or is an EEPROM faster than the SD?
JM
Nyamekye,
JM
I tried your driver and I have one small issu.
Here is my code:
CON _cardDataOutPin = 7 _cardClockPin = 6 _cardDataInPin = 5 _cardChipSelectPin = 4 _clockDataPin = 25 _clockClockPin = 24 _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long sd_stack [64] long volumeLabel OBJ fs : "SD2.0_FATEngine" sx : "FullDuplexSingleton" rtc: "DS1307_RTCEngine.spin" PUB start (lf_number) sx.start(31,30,0,115200) ifnot(rtc.RTCEngineStart(_clockDataPin, _clockClockPin)) sx.str(string($d,"Not able to start the RTCEngine",$d)) reboot ifnot(fs.FATEngineStart(_cardDataOutPin, _cardClockPin, _cardDataInPin, _cardChipSelectPin, _clockDataPin, _clockClockPin)) sx.str(string($d,"Not able to start the FATEngine",$d)) reboot volumeLabel := fs.mountPartition (0, 0) sx.str(string("Volume label: ")) sx.str(volumeLabel) sx.str(string($d)) sx.str(string("Changing directory to : ")) sx.str(fs.changeDirectory(string("\"))) sx.str(string($d)) cognew (process, @sd_stack) ' Comment to run outside of the cof 'process ' Uncomment to run outside of the cog PUB process | index, fileName sx.str(string("Listing files...", $d)) index := 0 fs.listName("T") repeat fileName := fs.listName(0) sx.str(string("Read ")) sx.str(fileName) sx.str(string(" Index=")) sx.dec(index) sx.str(string(" strsize=")) sx.dec(strsize(fileName)) sx.str(string($d)) until fileName == 0 repeat ' Comment to run outside of the cog
Any clue?
JM
I found a way to have it working.
I moved all my code into the cog instead of initializing the objects outside of the cog.
Don't ask me why it's working that way, and not the other way, because I don't understaing anything here
Do I have a way to size the stack correctly?
JM
CON _cardDataOutPin = 7 _cardClockPin = 6 _cardDataInPin = 5 _cardChipSelectPin = 4 _clockDataPin = 25 _clockClockPin = 24 _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long sd_stack [256] long volumeLabel OBJ fs : "SD2.0_FATEngine" sx : "FullDuplexSingleton" rtc: "DS1307_RTCEngine.spin" PUB start (lf_number) cognew (process, @sd_stack) ' Comment to run outside of the cog 'process ' Uncomment to run outside of the cog PUB process | index, fileName sx.start(31,30,0,115200) ifnot(rtc.RTCEngineStart(_clockDataPin, _clockClockPin)) sx.str(string($d,"Not able to start the RTCEngine",$d)) reboot ifnot(fs.FATEngineStart(_cardDataOutPin, _cardClockPin, _cardDataInPin, _cardChipSelectPin, _clockDataPin, _clockClockPin)) sx.str(string($d,"Not able to start the FATEngine",$d)) reboot volumeLabel := fs.mountPartition (0, 0) sx.str(string("Volume label: ")) sx.str(volumeLabel) sx.str(string($d)) sx.str(string("Changing directory to : ")) sx.str(fs.changeDirectory(string("\"))) sx.str(string($d)) sx.str(string("Listing files...", $d)) index := 0 sx.str(string("Moving to the first entry.", $d)) fs.listName("T") repeat sx.str(string("Reading next entry.", $d)) fileName := fs.listName(0) sx.str(string("Read ")) sx.str(fileName) sx.str(string(" Index=")) sx.dec(index) sx.str(string(" strsize=")) sx.dec(strsize(fileName)) sx.str(string($d)) until fileName == 0 repeat ' Comment to run outside of the cog
BTW, did I already thanked you for this object?
JM
I will try to make a "lite" version of it
JM
