Question about PCB copper trace protection
I have made a few circuit boards for projects before, and one of my most useful projects uses a circuit board I etched. Sadly, the copper traces are starting to corrode, and since a few of them etched a little too long, they are dangerously thin. Is there a way to "laminate" the boards with a protective coating so the boards won't corrode? I do have some polyurethane that I got from home depot -- would that do the trick?
Thanks.
MCU Projects·- my new site where I will be posting all projects, code, etc.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
SD Card Adapter·- Add extra memory to your next Propeller project with ease!
Thanks.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
ITW Chemtronics CircuitWorks Overcoat Pen (this is the correct stuff to use to coat exposed copper by hand)
http://forums.parallaxinc.com/webvia.techni-tool.com/VIA/products/237CH206 $19 for a pen, comes in clear and green (we use green at work when we do PCB repairs like replacing pads or traces)
ITW Chemtronics Konform SR Conformal Coating Spray, aersol can, (good to coat everything on the board for protection from moisture, etc)
http://forums.parallaxinc.com/webvia.techni-tool.com/VIA/products/237CH012 $30 a can, but good coverage.
For normal hobby use at home, I tried an old bottle of my wife's Nutra Nail Nail Hardener that she was going to toss . It's like a very hard clear nail polish available at Walgreens, Amazon, Rite-Aid, etc, for about $4. Any clear nail polish will work, but the nail hardener type seems to caot better and be more resilient (doesn't chip or flake away as easily)
www.amazon.com/Nutra-Nail-Green-Tea-Hardener/dp/B000EGMBM0/ref=sr_1_1?ie=UTF8&s=beauty&qid=1280163293&sr=1-1
Andrew Williams
WBA Consulting
PowerTwig Dual Output Power Supply Module
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
W9GFO, this is kind of an off-topic question, but do you use aluminum very often? If so, do you have any idea where I can get 1/4" inner diameter aluminum pipe for a reasonable price? If so, send me a PM so this thread doesn't get way off track.
Andrew@WBA Consulting, thanks for the links. I'll see if I can take an old bottle of my mom's nail polish.
I'm going to test polyurethane shortly on a test pcb and see if it can withstand ferric chloride afterwards.
Andrew Williams
WBA Consulting
Leon Heller
Amateur radio callsign: G1HSM
This is the Sandbox after all, I have used Online Metals a few times but my best source was Boeing Surplus in Kent, WA. Too bad it closed. [noparse]:([/noparse]
Rich H
Now that's a use for beer that I haven't heard before!
en.wikipedia.org/wiki/India_Pale_Ale
Rich H
India Pale Ale (the other IPA) was so-called because it was the only beer that could be shipped to India in the time of the British Raj that would still be drinkable when it got there. It was basically the same as the bitter that is still quite popular today. I remember being told that on a student visit to the Bass brewery in Burton-on-Trent, over 50 years ago. Following the visit we were given as much Worthington E as we could drink in 30 minutes. It was straight from the barrel, and even nicer than the E served in our favourite pub, which was pretty good.
Leon Heller
