Smoking Electronics Parts, Procrastination, and a Six Segment Display
I was breadboarding a circuit this morning and managed to turn a seven segment led into a six segment led when I accidentally bypassed a resistor. Which raises two interesting issues/questions.
What do you do with a six segment display?
The other is after smoking a part I become noticeably more reticent to power on and test the repaired circuit. Being careful turns into procrastination and I need to force myself to over come it. Does this happen to anyone else?
Leon Heller
Amateur radio callsign: G1HSM
If your working with anything above 36 volts that has high amps, wear non conductive gloves or your muscles may cunvulse at 50-60hz depending on your local, lmao.
http://WhatsAvailable.org Software and Gadgets for Windows 7.
In the case of things like 7-segment displays and uCs, I generally use a socket and verify all the voltages before I insert them.
And now I am considering committing to using bridge rectifiers on all power inputs so I never have to deal with reverse polarity - at least on things I tend to plug and unplug alot.
In sum, it does get easier and we do work smarter - for me it has been a slow process as I sometimes take a day off to think about what to do next.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Loopy Byteloose, using a socket on the breadboard is a good idea. I test continuity all the time and it's a snap to test voltages too.
The bottom four for 0
The bottom three for C
Bottom two for 7
etc.
Leon Heller
