CogInit doesn't — Parallax Forums
CogInit doesn't
steprogsteprog Posts: 227
edited 2010-07-26 06:01 in Propeller 1
Hi Guys,
Trouble with coginit.· I was trying to load assem routines in all 8 cogs, but doesn't seem to work.· Mainly I need to load assem into the cog 0 where the main program is working.· I thought that should work, but it seems to ignore me.
Perhaps this is too general a question, but I thought an assem could be loaded on the same code asking for it. True?
Gre
  • w8anw8an Posts: 176
    edited 2010-07-26 00:04
    Normally the first response to this type of question is..
    Can you post a code example?
  • steprogsteprog Posts: 227
    edited 2010-07-26 00:07
    Yes I know I just hate bothering people with my silly problems, but I must admit Im stuck. Let me figure out how to cut and past and I will. Thanks, Greg
    edited 2010-07-26 00:15
    This shows that the method has been defined
    ·obj
    · FreqLast······ : "mixerLast"
    This code basically gets a command from the gui and starts loading the cogs
    ··· if strcomp(@RunCLK, @command)
    ······ Freqlast.start(LO2,Fo2A,Fo2B,Frequency2,delay2,deg180_2,1)
    ······ Freqlast.start(LO3,Fo3A,Fo3B,Frequency3,delay3,deg180_3,2)
    ······ Freqlast.start(LO4,Fo4A,Fo4B,Frequency4,delay4,deg180_4,3)
    ······ Freqlast.start(LO5,Fo5A,Fo5B,Frequency5,delay5,deg180_5,4)
    ······ Freqlast.start(LO6,Fo6A,Fo6B,Frequency6,delay6,deg180_6,5)
    ······ Freqlast.start(LO7,Fo7A,Fo7B,Frequency7,delay7,deg180_7,6)
    ······ Freqlast.start(LO8,Fo8A,Fo8B,Frequency8,delay8,deg180_8,7)
    ······ Freqlast.start(LO1,Fo1A,Fo1B,Frequency1,delay1,deg180_1,0)
    This code that resides in "mixerlast" calls the coginit command and loads up the assembly
    PUB start(LO,FA,FB,Period4,dely,deg180,cognum)
    · D180 := deg180·
    · LOpin := |< LO
    · FApin := |< FA
    · FBpin := |< FB
    · Delay := dely
    · Per4:= Period4
    · Phase1:= 1
    · Phase2:= 0
    · If Delay > Per4
    ··· Delay:= Delay - Per4··
    ··· Phase1:=0
    ··· Phase2:=1
    ··· coginit(cognum,@entry,PAR )
    · return
    edited 2010-07-26 00:25
    With that indentation coginit is only ever executed when Delay > Per4. Is that the idea? Also - out of curiosity - why do you pass par as a parameter?
    edited 2010-07-26 01:00
    The indentation was it. I must of moved the code without thinking earlier.
    Thanks for the help.
    Greg
    edited 2010-07-26 01:48
    There is a show indentation function in the Prop tool. It has helped me big with this issue.
    8x8 color 80 Column NTSC Text Object
    Wondering how to set tile colors in the graphics_demo.spin?
    Hi potatohead,
    I use it I just boneheaded it.
    Greg
