FemtoBasic with 4GB uSD card?
zappman
Will FemtoBasic work with a 4GB uSD card?
My demo board and 4GB uSD card work with the FAT16/32 Full File System Driver by Kwabena W. Agyeman, the version that works without a clock. I can even play wave files off the card.
When I try to access the card in FemtoBasic, by typing 'files' then return, I get a message 'Can't Mount SD Card'
I think this is a FAT16/32 problem?
Thanks in advance for your help,
zappman
Visit Zappman's Blog at Savage Circuits
zappman
The object contains fsrwfemto.spin with the comment v2.6a 3 June 2010 Modified to make compatible with FemtoBasic.
I am using the Parallax micro-SD Card Adapter (#32312)
The program below works perfect so I think my wiring is OK.
SD2.0 FATEngine Demo
¦ Author: Kwabena W. Agyeman
¦ Updated: 6/2/2010
¦ Designed For: P8X32A @ 80Mhz
¦ Version: 1.0
I could buy another (smaller) card I guess.
The card was formatted on a laptop if that makes any difference.
You could support SDHC only just by eliminating the block number to address shift in the old driver.
