Controlling multiple servos. - Page 2 — Parallax Forums
2»
  • GrampsGramps Posts: 117
    edited 2010-07-22 22:22
    Don't have a 6 volt battery or a wire wound resister at the moment.
    'What is your life?"
    "It is even a vapor that appears for a
    little time and then vanishes away."
    Saint James 61 A.D.
    edited 2010-07-22 23:22
    I keep a long string of series silicon diodes handy to experimentally drop motor voltages. Each diode drops a fixed ~0.7 volt, so with a few alligator clips you can step up or down 0.7 volt at a time. They do heat up like a resistor, but they are far superior at high loads when the motor is near stalled, because the resistor drops more voltage as more current flows, and the motor torque drops off.
    You'll want BIG barrel diodes for the current you're pulling. Even the Shack has a pack.
    edited 2010-07-22 23:23
    How many amps!
    Saint James 61 A.D.
    edited 2010-07-22 23:39
    "How many amps!" Gramps
    Is that a question, or a statement, or a lamentation, or a way of life?
    6 amps: http://www.radioshack.com/product/index.jsp?productId=2062591
    edited 2010-07-22 23:42
    how many amps would the diodes in series have to be?
    I have some 1 amp.........
    Saint James 61 A.D.
    edited 2010-07-23 00:11
    All have the full current going through them, so whatever current your motor is pulling. When in doubt, go BIG!
    edited 2010-07-23 00:13
    2 amps moving and 8 amps stall..........
    Saint James 61 A.D.
    edited 2010-07-23 02:44
    That's at 12V, right? With 6-7 diodes in series, the motor voltage will drop 4-5 volts and your stall current will drop under 6A. Voila!
    Fewer diodes allows a higher stall current, obviously.
    edited 2010-07-23 12:00
    @erco,
    This is an excellent idea to use what most people would consider a defect in diodes to achieve a resistance drop without a resister.
    A 10 amp diode is sure cheaper then a 10 watt resister!
    Thanks for this tip!
    P.S. I’m going to start a new thread in the sandbox on signal wire routing.
    Gramps
    Saint James 61 A.D.
    edited 2010-07-23 15:22
    Diodes are a guy's best friend! They allow a fixed VOLTAGE (not resistance) drop of 0.7 volts. Schottky diodes only drop 0.3 volt, handy for finer voltage drop adjustment.
    A favorite trick of mine is to use 3 of them in series as a current sensor (two doesn't work reliably). If you just need to tell if an external circuit is on or off, insert the series diodes at the battery negative terminal. This assumes your circuit operates at ~6V or higher and won't miss 2 volts. Now attach ground wires between your circuit and stamp, and attach the anode end of the 3 series diodes to a stamp pin (a 220-ohm protection diode is wise). Now when your circuit has current flowing (headlights, battery charging, etc) your stamp pin reads high; and when no current flows, pin reads low.
