Remote control snow plow
Hello everyone,
I thought you might like to see a photo of my R/C snowplow.
I've been using it for 2 seasons now with very little trouble. It was
originally used to crawl around on rough terrain just for fun. Then,I added
2 more deep cycle batteries[noparse][[/noparse]mostly for added weight to gain traction].Even with all that weight I sometimes drape an 80 lb. bag of salt across it to help push deep snow and ice.
By some miracle,it works perfectly and never breaks! It has a very long range due
to the use of a top quality radio system.Those of you who fly model airplanes would be right at home at the controls.It's been so far down the street that it's difficult to see what direction
and speed it's travelling,especially when I'm operating it from inside my home.
The machine is driven by 2 Invacare wheelchair motors[noparse][[/noparse]which I highly recommend for your projects].Current is supplied by a 100 amp pwm controller.Forcing the motors into a near stall condition requires lots of amps.Forward/reverse is operated by servo activated mechanical switches,taken from some heavy duty machines. Gaining reliability in
projects of this nature seems to be all about using the heaviest components practical.
Isn't it heartbreaking to see that glowing wire and smoke coming from your project?
Now,it's time to rebuild the R/C lawnmower! The poor machine suffered several
"accidents" last summer. That's another story.
Best regards to all of you,
Jim Richey
Thanks, Parallax!
Jim Richey
Thanks, Parallax!
Nice project! Is the chassis·from a snowblower or is it a built up?
Cheers,
Tom
Tom Sisk
http://www.siskconsult.com
I built the chassis basically from 3/4 inch square steel tubing.The drive cogs and
rubber tracks came from an old Craftsman snowblower.
Jim
Thanks, Parallax!
Nice practical project. I'd love to plow my driveway while sitting in the house too [noparse];)[/noparse]
I bet you could get kids to pay YOU to plow your driveway with it.
Just wondering what state you live in ?
Now you need to make it autonomous.
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
You're right about the kids.The boys down the street [noparse][[/noparse]and their dad] show a lot of interest
in the mysterious machine prowling around with no one in sight.I'd like to toy around with automating it somewhat.Maybe I should send for another homework board,huh?
I live north of Detroit,not too far from Batman as I understand!
Jim
Thanks, Parallax!
Nice Project!.... Now put a wireless video camera on the front end of it and "drive" it from the living room.
Beau Schwabe
IC Layout Engineer
Thanks for the nice compliment.
My wife came home with a wireless color camera from the supermarket a while back.
I mounted it on my remote controlled lawnmower. My neighbor and I had loads of fun,sitting on the couch,and
mowing the lawn from the living room TV.We wired up a cross hair to the steering that moved across the field of vision,pointing the way.It worked pretty good,but had it's limitations.The reception would blank out as the mower passed by parked cars and stuff.Kind of scary hearing the mower out there,not knowing just where it was! And I guess it would help to be able to see while going in reverse too! Maybe we'll duct tape the camera to the plow and have a little fun with it, hopefully nothing will get damaged too badly.
Jim
Thanks, Parallax!
I've been working for over a year on the PWM controller for a robot that uses 4 powerwheels gearboxes. Every time I declare I've finally gotten the circuit totally blow-proof, a MOSFET goes up in smoke just to mock me. One thing I found out was that even with current measurement built in, if you short the output even a 1 mSec pulse can conduct enough to blow a 17 amp MOSFET, just because the filter caps in the controller are so big that they can discharge a huge amount of current through a short faster than you can detect it and respond. I also gave up on H-bridges because of shoot through problems, and now use DPDT relays for all my direction control, kind of like you do with the mechanical switches and servos for direction control. So far the relays have been the only thing that have proven reliable! They are much more forgiving of power spikes and short circuits than semiconductors are.
I concur with your statement that it seems like the only way to make this kind of thing really reliable is to use the heaviest-duty components practical.
"When the government is afraid of the people there is liberty, when the people are afraid of the government, there is tryanny"
· Thomas Jefferson
"puff"...... Smile, there went another one.
This would be great to have here in Idaho.
I'd love to see more details on you hardware set up. Can you change the angle of the blade?
Thanks for posting this.
