Programming Prop via FTDI and 4-pin header [SOLVED]
Similar subjects from me have come up in recent days, but I pose another odd question.
Attached is the wiring I am using. My problem is, once the FTDI chip (or possibly the SN74LVC2G07DBVR chip -- U8 -- I haven't tested which, maybe either one messes it up) is attached, the 4-pin header port doesn't work with the prop plug. You may be saying (in your head hopefully), "Hey dummy! Unplug the Prop Plug USB cord and plug into the on-board USB!"
Well, the answer to your silent question is, "I don't intend to use the Prop Plug." What I actually am wanting to do is to program the propeller via USB and alternatively from another Propeller (thus no USB cable available). So the question is, can the wiring be modified (on the receiving end or the transmitting end) to program the propeller using the standard header while keeping the FTDI functional?
I am wide open to other alternatives. I.E. completely different wiring schemes; program Prop B from a USB driver on Prop A (is this possible?); anything else you geniuses may propose is welcome.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
Post Edited (Bobb Fwed) : 7/21/2010 4:30:46 PM GMT
Some of my objects:
(a schematic with component values would make it easier to find the problem).
Andy
The Propeller transmit pin and the reset pin can go to both places since they're inputs for the transmit pin and the reset is open-drain / open-collector and two of those can be paralleled as long as the resting state is high (open)
Schematic with values attached. Sorry about that.
As for the "problem" I don't think it is a wiring problem or error, it is more so a conundrum, where the Prop needs to be able to receive programming commands from two different sources.
Some of my objects:
I think with such a series resistor and without something pluged in the 4 pin header, the FTDI will still be able to program the Prop.
If you plug in a PropPlug or another Prop in the 4 pin header, this device will be dominant, because of the lower resistance.
In case of a second Prop, it looks like the simplified attached schematic. You can program (or communicate with) the first Prop when the TXpin is an output and sends the serial data. Then when finished just make the TxPin an input, so the FTDI will be able to talk to the first Prop. As a benefit also the second Prop will be able to "hear" what the FTDI sends at his TXpin (as input).
The Reset output of the second Prop should have a diode, or your code need to use the ResOut Pin in a open collector way (only output a Low, and make it an input for a High).
Andy
Attached is the schematic I ended up testing (an old version of the FTDI circuitry I already have a PCB made of).
This is a SMT board, I didn't have anything except a 10K in the 0402 package to put in the R20 slot. The R60 resistor is on the opposite side of R20.
What I was expecting was the FTDI wouldn't be able to program the Propeller, but the header would. What actually happened was nothing. USB still works, Prop Plug does not.
I can see the FTDI still working with a tolerance or voltage difference between the two 10K resistors, but why doesn't the Prop Plug work?
Does this tell you anything. Do you think a Prop-to-Prop program may be more successful than the Prop Plug?
Some of my objects:
With R20 and R60 you will never have a Low at the PropRx Pin, only 1.65V or 3.3V. The Prop has a input threshold of ~1.45V so it never sees a Low.
Andy
Some of my objects:
Does your FTDI also work if you have the PropPlug connected (and powered)? This would be very strange.
The difference between a PropPlug and a second Prop is that you can make the TX pin of the Prop and input (=highZ), with the PropPlug this is not possible.
Andy
So, now I have both the Prop Plug and my FTDI powered and plugged in, and both can program the propeller! As soon as I unplug the FTDI USB, the Prop Plug stops working. As soon as I unplug the USB from the Prop Plug, the FTDI stops working.
I should probably breadboard a propeller to program this board and see if that works any differently.
Some of my objects:
EDIT: And even more lame (i.e. I should have tried the Prop-to-Prop thing a long time ago). The Propeller can program the other Propeller just fine with than 220 resistor in place (R20). I guess even with the SN74LVC2G07DBVR chip open collecting, the Propeller can provide enough juice to overcome 220-ohms of resistance (duh -- it's only a third of what the IO pin can output). So it is a bit wasteful, but it works with the 220. For my next version, I will likely put a 1K or 2.2K in place of R20.
Some of my objects:
Post Edited (Bobb Fwed) : 7/21/2010 4:40:47 PM GMT
