Graphics Driver plot/line 'units'
Are the 'units' for this driver in pixels, tiles, or what? I'm using Rayman's PTP board and 3.5" LCD trying to plot some points and lines. However, using info from the PTP Graphics Demo and Graphics Driver source files it seems vague whether 'plot' or 'line' x,y values are in pixels or tiles or something else. Nothing desired is displayed, my problem #1.
I am using 'plot_screen = $8000 - 9600' which places the upper left of the screen RAM at address $5A80, by my calculation: 320x240 pixels = 10 longs x 240 lines = 2400 longs or 9600 bytes = $2580; and $8000 - 9600 = $5A80, does that sound right? On the left in the photo, is some 'garbage' that shows up if the 'stack' is increased. If increased by '100' the the garbage shows up near the top left; by '200' then it is where the photo shows; by '300' it is near the bottom left. I would have expected such stack space to occupy one or more linex horizontally not vertically. And when the touchscreen is touched you can see the lower half of the 'garbage' bits varying. Presently my program uses: Program 2303 longs, Variables 569 and Stack/free 5316; 4 longs short of full 32K space. The 'garbage' on the right side is fixed and does not vary ever; I don't yet know what's causing that; I'm not concerned about that for the moment.
I copied from the the Graphics Demo the 'draw bouncing lines' (below, renamed 'waveform') for that to draw something on screen. The 'y' value is from an A/D and 'x' value runs from 1 to 320, the width of the screen. I'd expect something to appear on-screen. 'ADbuff' is a 320 long buffer for the A/D samples.
Am I using that incorrectly? I assume it uses pixels as units to plot points or lines, else it would be pretty crude plots if tiles. I must be missing something, right?
Harley Shanko
PUB waveform | i
gr.colorwidth(1,thickness)
gr.plot(0,ADbuff)
repeat i from 2 to 321
gr.line(i-2,ADbuff[i])
gr.line(0,ADbuff)
[/i]
Harley Shanko
Try half the horizontal resolution, changing number of tiles in the X to be half what you have now.
Then try some more lines.
8x8 color 80 Column NTSC Text Object
Wondering how to set tile colors in the graphics_demo.spin?
Time to put the DEBUG HAT back on.
Harley Shanko
BTW: That driver has scaling, so you can grow your screen resolution as you find room for it. That library also clips the graphics, if they don't actually appear on screen. Try plotting in all four coordinates, until you see stuff.
