78L05 troubles
LoopyByteloose
For years I've used the larger 1amp 7805 regulators, but I began to think they were a waste of space for many projects, so I bought some little 100ma 78L05s.
But I can't seem to make them work well.. At first I figured that I got a defective one, but replacement seemed not to solve the problem. I had used two 0.1mfd tantalum caps with them.
Finally due to voltage seeming to wander, I removed the tantalum caps and the readings have gotten more consistent. Any comments? At this point, I am thinking the tantalum caps were doing something odd.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
I tend to use a 0.1uF ceramic capacitor in parallel with a 1uF to 10uF tantalum capacitor on the output of these regulators since that's what I would use at the input supply terminals of a small board without a regulator on-board anyway.
Leon Heller
Amateur radio callsign: G1HSM
Having let the unpopulated board 'burn in' for 24 hours without caps, the voltage regulation now appears stable.
I still like the 78L05s, after all it seems the BasicStamp does fine with them in an SMD form.
Leon Heller
As always, it is best to power up your bare board with regulator before you populate. Solder bridges and defective parts occasionally happen. Right now I have it loaded with an LCD display and it has settled down to a perfect 5.00VDC. I suppose part of the problem is that there is no heat sink included.
Now I am ready to insert an SX18 without risk of damage.
Leon Heller
And so, I have learned to make sure that I have stable +5 VDC (or whatever required) before I bother with fill IC sockets with chips. Quite often the first attempt gets bad results due to a solder bridge somewhere. Some voltage regulators - like the 2940 series - are quite sturdy and will tolerate momentary direct shorts and reverse polarity. The 78xx series do okay too.
I've given up on the 78L05 for this project as the voltage drops to 4.6VDC when I insert the SX18 and the 2X16 LCD. I switched to a regular 1 amp 7805. I presume that I am over my 100ma limit, though I don't quite see how ( LCD without back light is supposed to be 4ma, the SX18 maybe 50ma, and then 3 or 4 pull up and pull down resistors).
Anyway, when I really have abused what I am building, I let the device run without ICs for 24 hours to assure that it is stable. Electrolytic capacitors may suffer the most and take time to fail.
I also check all my IC connections for voltage, circuit continuity and leaks to adjacent pins. Sometimes I goof and +5 shows up where it isn't supposed to, other times a solder bridge will tie two pins together or I will have a pull up instead of a pull down.
I know this all sounds rather tedious, but it is even more tedious to try to figure out what has gone wrong after everything is assembled and something burns up.
