usb - rs232 long term usage and debugging
The software I have been working on here is still a work in progress - aercon.net/index.html
This forum seems to have a number of people who have done this type of thing. The target framework for the software is dotnet 2.0.
I have a win 7 64bit computer running the software , and using a Cables to go usb - serial adapter, that has to have the program shut down and restarted periodically, because there seems to be some miscommunication somewhere. The communication does not stop, but seems corrupted. Has anyone run into any issues using the dotnet serial port or usb-serial adapters that are similar to this? The problem shows up 2-3 times a week.
I have also been puzzling to figure out a way to properly log problems like these on customers machines.
Hmm, is it the cable or vb.net?
One answer might be to log all the bytes with a serial port sniffer. If you go to my webpage www.smarthome.viviti.com/propeller near the bottom just above the last two photos is a link 1) to a serial port sniffer program.
I could not have built half the propeller things I've build without this.
At least then you could see if the data is corrupted by the USB to serial device, or whether it is corrupted in .net
I've seen something similar after streaming constant data at 115200 bps for several hours into VB. Only worse - I get a blue screen of death (windows XP). I put up with it as it doesn't happen every time. I suspect its due to having too many applications & drivers etc running, but haven't had a chance to try a clean installation.
All I could suggest is trying a different family of converter IC. There are devices based on FTDI and also devices based on Silabs CP2102 and maybe Prolific PL2303. 4D systems sell TTL converters based on the first two, but you'd still need a MAX3232 or similar if you need true rs232. I have tried a different USB-RS232 dongle with same results, but suspect it just has the same chip inside.
A lot of the blue screen of deaths that I have heard about are attributed to a defect in the .net framework and the serial port, basically because it keeps trying to read from a port when it gets removed. the "legacy unhandled exception" xml bit takes care of that one, with unknown side effects.(exceptions that should be handled are not?)
I am not streaming data at it, but I am using it at 115200.
One thing I have contemplated is to close and reopen the port periodically, or close and dispose the serial port, and start over. A person has to be careful though, or you create a new problem, or don't really figure out the problem in the first place.
I'd be a little interested to see what type of code and what type of serial port you used to get this to happen (the BSOD)
If you can get me either, I can analyze it and tell you what is going wrong. I can tell you that it would never be because your are running too many apps or drivers... you'd get an out of memory or just plain poor performance due to that, but never a blue screen.
BTW... I work for Microsoft, not in technical support, but I'm a developer and know quite a bit about the framework, etc.
Bill
The application I have just spools data from a big file out to the serial port at 115200. But it uses VB98, not .NET, so I realise this is the likely cause. I can dig up the code if anyones interested, but I figure I should porobably try VB .Net first.
Bill I have another Prop/VB questions you may be well placed to answer, I'll PM you regarding it
