Experiment #33 in StampWorks Manual (DS1307 RTC) need code for updating Year an
Friends:
I have set up and run Experiment #33 in the StampWorks Manual involving the Professional Development Board and the DS1307 Real Time Clock, a BS2P40 Module and software SW21-EX33-DS1307.BSP
1. Does anyone have modified code for displaying and updating with the complete 4 digit year? (and the wiring schematic?)
2. Does anyone have code for writing this information to the 7 Segment LED display on the Professional Development Board?
I remain most grateful,
Migs
"Sometimes we forget that the world itself is paradise." Douglas Coupland, 'Microserfs'
"If the doors of perception were cleansed every thing would appear to man as it is, infinite" - William Blake
"We either make ourselves miserable, or we make ourselves strong. The amount of work is the same." Carlos Castaneda
"One single grateful thought raised to heaven is the most perfect prayer. " G. E. Lessing
“How much of human life is lost in waiting.” Ralph Waldo Emerson
"Men often mistake notoriety for fame, and would rather be remembered for their vices and follies than not be noticed at all.” Harry Truman
My website: www.intoku.net my e-mail:mreznicek@pretensa.com me:Miguel Reznicek
Post Edited (Migs) : 7/17/2010 10:45:41 PM GMT
' File....... SW21-EX33-DS1307.BSP
' Purpose.... Real-time-clock interfacing
' Author..... (C) 2000 - 2005, Parallax, Inc.
' E-mail..... support@parallax.com
' Started....
' Updated.... 16 AUG 2006
' {$STAMP BS2p}
' {$PBASIC 2.5}
' -----[noparse][[/noparse] Program Description ]---------------------------------------------
' This program demonstrates the access and control of an external real-
' time-clock chip, the DS1307.
' -----[noparse][[/noparse] I/O Definitions ]-------------------------------------------------
SDA PIN 0 ' I2C serial data line
SCL PIN 1 ' I2C serial clock line
BtnBus VAR INB ' four inputs, pins 4 - 7
' -----[noparse][[/noparse] Constants ]-------------------------------------------------------
Ack CON 0 ' acknowledge bit
Nak CON 1 ' no ack bit
DS1307 CON %1101 << 4
' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
secs VAR Byte ' DS1307 time registers
mins VAR Byte
hrs VAR Byte
day VAR Byte ' weekday
date VAR Byte ' day in month, 1 - 31
month VAR Byte
year VAR Byte
control VAR Byte ' SQW I/O control
btns VAR Nib ' debounced button inputs
btnBack VAR btns.BIT3 ' roll back
btnDay VAR btns.BIT2 ' +/- day
btnHr VAR btns.BIT1 ' +/- hours
btnMn VAR btns.BIT0 ' +/- minutes
idx VAR Nib ' loop control
pntr VAR Byte ' ee pointer
char VAR Byte ' character for display
' -----[noparse][[/noparse] EEPROM Data ]-----------------------------------------------------
DayNames DATA "SunMonTueWedThuFriSat"
' -----[noparse][[/noparse] Initialization ]--------------------------------------------------
Reset:
#IF ($STAMP < BS2P) #THEN
#ERROR "Please use BS2 version: SW21-EX33-DS1307.BS2"
#ENDIF
Setup:
DEBUG CLS,
"DS1307 Demo", CR,
Reset_Clock:
GOSUB Get_Buttons ' scan buttons
idx = btns & %0011 ' isolate hrs & mins
IF (idx = %11) THEN ' if both pressed, reset
secs = $00
mins = $00
hrs = $06 ' 6:00 AM
day = $07 ' Saturday
date = $01 ' 1st
month = $01 ' January
year = $05 ' 2005
control = 0 ' disable SQW output
GOSUB Set_Clock ' block write clock regs
ENDIF
' -----[noparse][[/noparse] Program Code ]----------------------------------------------------
Main:
GOSUB Get_Clock ' read DS1307
hrs = hrs & $3F
DEBUG CRSRXY, 0, 2,
HEX2 hrs, ":", HEX2 mins, ":", HEX2 secs, CR
GOSUB Print_Day
PAUSE 100
GOSUB Get_Buttons
IF (btns > %0000) THEN ' button pressed?
IF (btns <> %1000) THEN ' ignore back only
hrs = hrs.NIB1 * 10 + hrs.NIB0 ' BCD to decimal
mins = mins.NIB1 * 10 + mins.NIB0
IF (btnBack = 0) THEN ' increment values
day = ((day - 1) + btnDay // 7) + 1 ' keep 1 - 7
hrs = hrs + btnHr // 24 ' keep 0 - 23
mins = mins + btnMn // 60 ' keep 0 - 59
ELSE
day = ((day - 1) + (btnDay * 6) // 7) + 1
hrs = hrs + (btnHr * 23) // 24
mins = mins + (btnMn * 59) // 60
ENDIF
hrs = (hrs / 10 << 4) + (hrs // 10) ' decimal to BCD
mins = (mins / 10 << 4) + (mins // 10)
secs = $00
GOSUB Set_Clock ' update DS1307
ENDIF
ENDIF
GOTO Main
' -----[noparse][[/noparse] Subroutines ]-----------------------------------------------------
Get_Buttons:
btns = %1111 ' enable all four inputs
FOR idx = 1 TO 5
btns = btns & ~BtnBus ' test inputs
PAUSE 5 ' delay between tests
NEXT
RETURN
Print_Day:
pntr = DayNames + ((day - 1) * 3) ' point to 1st char
FOR idx = 0 TO 2 ' print 3 letters
READ (pntr + idx), char ' read letter
DEBUG char ' print it
NEXT
RETURN
' Do a block write to clock registers
Set_Clock:
I2COUT SDA, DS1307, 0, [noparse][[/noparse]STR secs\8] ' update clock registers
RETURN
' Do a block read from clock registers
Get_Clock:
I2CIN SDA, DS1307, 0, [noparse][[/noparse]STR secs\8] ' retrieve clock registers
RETURN
Migs
- Stephen
Here is an application from another post that explains why the year is not dealt with in the listing above:
http://forums.parallax.com/forums/default.aspx?f=5&m=461713
' ========================================================================= ' ' File....... Date & Time.BSP ' Purpose.... Real-time-clock interfacing ' Author..... ' E-mail..... ' Started.... 09 June 2010 ' Updated.... 14 June 2010 ' ' {$STAMP BS2p} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' ' This program demonstrates the access and control of an external real- ' time-clock chip, the DS1307. ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- SDA PIN 0 ' I2C serial data line SCL PIN 1 ' I2C serial clock line Spkr PIN 2 ' speaker output BtnBus VAR INH ' input pins 8 - 15 ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- DS1307 CON %1101 << 4 ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- control VAR Byte ' SQW I/O control DecConvert VAR Byte DateArray VAR Byte(9) ' DateArray(0) = Seconds ' DateArray(1) = Minutes ' DateArray(2) = Hours ' DateArray(3) = DOW ' DateArray(4) = Date ' DateArray(5) = Month ' DateArray(6) = year ' DateArray(7) = control btns VAR Byte ' debounced button inputs btnProg VAR btns.BIT7 ' enable programing the clock btnbk VAR btns.BIT6 ' Back button (not enabled/intrgrated) btnYear VAR btns.BIT5 ' +/- year btnMonth VAR btns.BIT4 ' +/- month btnDate VAR btns.BIT3 ' +/- date btnDay VAR btns.BIT2 ' +/- day btnHr VAR btns.BIT1 ' +/- hours btnMn VAR btns.BIT0 ' +/- minutes pntr VAR Byte ' ee pointer cntr VAR Byte ' Counter char VAR Byte ' character for display Dirty VAR Bit ' control set_clock occurances ' -----[noparse][[/noparse] EEPROM Data ]----------------------------------------------------- DayNames DATA "SunMonTueWedThuFriSat" ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- Reset: #IF ($STAMP < BS2P) #THEN #ERROR "This code requires BS2P or greater" #ENDIF Setup: DEBUG CLS, "DS1307 Clock set up and control", CR, "-----------", CR 'First deteermine if the clock was previously set I2CIN SDA, DS1307, 08, [noparse][[/noparse]decconvert] ' retrieve clock registers IF decconvert < 20 THEN ' clock not set I2COUT SDA, DS1307, 08, [noparse][[/noparse]20] ' write 2 MSB for year ' DTMFOUT Spkr, 100, 100, [noparse][[/noparse]1, 2, 3] ' simple alert for debugging Reset_Clock: GOSUB Get_Buttons ' scan buttons ' load the date array with the clock defaults to be used datearray(0) = 00 ' sec datearray(1) = 50 ' min datearray(2) = 13 ' 13:00 hours datearray(3) = 07 ' DOW datearray(4) = 12 ' DOM datearray(5) = 06 ' MOY datearray(6) = 10 ' year (Lower byte) datearray(7) = 0 ' initialize the control bit datearray(8) = 20 ' SRAM Address. This byte is ' has 2 uses, 1. indicates the ' clock has been set and 2. ' it is the upper byte for ' setting of the year GOSUB set_clock ELSE 'clock already set DTMFOUT Spkr, 10, 10, [noparse][[/noparse]1, 2, 3, 4, 5, 6] 'Simple alert for debugging ENDIF Dirty = 0 ' clear the flag ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: GOSUB Get_Clock ' read DS1307 'line 1 prints th time and line 2 prints the date DEBUG CRSRXY, 0, 12, DEC2 datearray(2), ":", DEC2 datearray(1), ":", DEC2 datearray(0), CR, DEC2 datearray(5), "/", DEC2 datearray(4), "/", DEC2 datearray(8), DEC2 datearray(6), CR DEBUG CRSRXY, 0, 14 GOSUB print_day ' turn DOW # into text GOSUB Get_Buttons ' check if buttons pressed SELECT btns CASE = %10000001 ' adjust minutes datearray(0) = $00 ' set seconds back to 0 DateArray(1) = DateArray(1) + 1 ' Increment the array IF DateArray(1) >= 59 THEN ' if more than 59 sec DateArray(1) = 0 ' set back to 0 ENDIF Dirty = 1 ' set the flag CASE = %10000010 ' adjust hours DateArray(2) = DateArray(2) + 1 ' increment the value IF DateArray(2) >= 24 THEN ' if more than 24 hrs DateArray(2) = 0 ' set back to 0 ENDIF Dirty = 1 ' set the flag CASE = %10000100 ' adjust DOW DateArray(3) = DateArray(3) + 1 ' increment the value IF DateArray(3) >= 8 THEN ' if more than 7 DateArray(3) = 1 ' set back to 1 ENDIF Dirty = 1 ' set the flag CASE = %10001000 ' adjust DOM DateArray(4) = DateArray(4) + 1 ' increment the value IF DateArray(4) >= 32 THEN ' if more than 31 DateArray(4) = 1 ' Set back to 1 ENDIF Dirty = 1 ' set the flag CASE = %10010000 ' adjust MOY DateArray(5) = DateArray(5) + 1 ' increment the value IF DateArray(5) >= 13 THEN ' if more than 12 DateArray(5) = 1 ' set back to 1 ENDIF Dirty = 1 ' set the flag CASE = %10100000 ' adjust the year datearray(6) = datearray(6) + 1 ' increment the value IF DateArray(6) >= 100 THEN ' if moe than 99 DateArray(6) = 0 ' set back to 0 datearray(8) = datearray(8) + 1 ' increment the upper byte ENDIF Dirty = 1 ' set the flag ENDSELECT IF Dirty = 1 THEN ' a button was pressed and Dirty = 0 ' date or time has changed GOSUB Set_Clock ' so update DS1307 ENDIF GOTO Main ' -----[noparse][[/noparse] Subroutines ]----------------------------------------------------- Get_Buttons: btns = %11111111 ' enable all eight inputs FOR cntr = 0 TO 7 btns = btns & ~BtnBus ' test inputs NEXT RETURN Print_Day: pntr = DayNames + ((datearray(3) - 1) * 3) ' point to 1st char FOR cntr = 0 TO 2 ' print 3 letters READ (pntr + cntr), char ' read letter DEBUG char ' print it NEXT RETURN ' Do a block WRITe To clock registers Set_Clock: FOR cntr = 0 TO 8 IF cntr < 8 THEN 'Don't convert Ram Data DecConvert = (datearray(cntr) / 10 << 4) + (datearray(cntr) // 10) ' decimal to BCD I2COUT SDA, DS1307, cntr, [noparse][[/noparse]DecConvert] ' update clock registers ELSE I2COUT SDA, DS1307, 08, [noparse][[/noparse]datearray(8)] ' update year upper byte ENDIF NEXT RETURN ' Do a block read from clock registers Get_Clock: FOR cntr = 0 TO 8 I2CIN SDA, DS1307, cntr, [noparse][[/noparse]DecConvert] ' retrieve clock registers IF cntr < 8 THEN ' Don't convert Ram Data datearray(cntr) = DecConvert.NIB1 * 10 + DecConvert.NIB0 ' BCD to decimal ELSE I2CIN SDA, DS1307, 08, [noparse][[/noparse]datearray(8)] ' get year upper byte ENDIF NEXT RETURNMigs
Post Edited (Migs) : 7/18/2010 1:41:08 AM GMT
should print out the four digit date.
- Stephen
Thanks for your help!
Migs
