Serial Port information and software
Just found this site. Tried the BillSerialMonitor free software too. Very nice. Wow long link Links for serial software at bottom of linked page.
http://www.google.com/imgres?imgurl=http://www.siongboon.com/projects/2006-03-06_serial_communication/max232layout.gif&imgrefurl=http://www.siongboon.com/projects/2006-03-06_serial_communication/&h=776&w=660&sz=37&tbnid=5TMqqEyqciTwFM:&tbnh=142&tbnw=121&prev=/images?q=max232+datasheet&hl=en&usg=__3HfGYSXWLtos3NYcwwQzUGL4vV4=&sa=X&ei=Xk03TMKeC43CsAOKxqFS&ved=0CCkQ9QEwBA
Software site for BillSerialMonitor
http://www.billproduction.com/
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
The BillSerialMonitor allows you to for example monitor on the same PC a program that is communicating through a com port to a device connected to it.
It uses a virtual port as an intermediary port as com ports can only be opened by one program in windows.
So you would open the billserialmonitor and select a virtual port of com10. Your program running on the PC would open COM10.
The Billserialmonitor would feed the data it gets in on com10 to the actual com port your device is connected too.
The Serialportmonitor by http://www.eltima.com/products/serial-port-monitor/ is different as it allows you to simply monitor a com port without using a virtual port.
Say you have a PC program in VB communicating with a stamp over com1. Simply open a session and monitor com1.
The dump screen looks just like the DEBUG output dump in real time so monitoring and designing software for serial com is made easy as cake.
This one has a 14 day trial.
Basically any language you program with that can open a serial port can now communicate through tcpip.
This site also has a port data logger for parallel and serial ports it can monitor on your PC even when they are opened from another program so it monitors
both incoming and outgoing signals and stores the data for future analyses.
http://www.hw-group.com/products/hw_vsp/index_en.html
· Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
