Blind spot warning
On my wife's Audi A8L, there are substantial blind spots.· I am looking at possibly using regular parking sensors to make a blind spot warning device for the A8 (or any other car for that matter).· The Ping is not weather proof, so that is excluded. I have several sensors from one of the e-bay back-up warning kits that I bought but never installed and would like to put one on each side of the back bumper to act as a blind spot warning when I turn on the directional signal.
I do not have a scope, which makes it difficult to move forward.·Does anyone have experience using these type of ultrasonic transducers?
Thanks in advance for your feedback
Chet
Chet
I think I have seen the bare transducer at sparkfun or futurlec. The data sheet should be on the page for that item. Good luck!
Tom Talbot
New Market, MD, USA
Tom Talbot
New Market, MD, USA
That said, we have the same sort of sensors (Weatherproof Ultrasonic Sensors) on our Chrysler(2007 Pacifica), but the only time I have heard them go off with a warning was when someone was standing at the back end and the lift gate was about to open or close.
Inside the car we have a backup camera, which often I have thought would be a good idea to have two additional cameras aimed in the "blind spots" on either side of the vehicle. That way when going forward and engaging a turn signal, the appropriate camera would provide the blind spot video feed to the dash inside the car.
Beau Schwabe
IC Layout Engineer
Andrew Williams
WBA Consulting
PowerTwig Dual Output Power Supply Module
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
Andrew, I do have wireless cameras (from the plate mounted back up cameras) that could go that route. The problem is the estetics aspect of having an extra screen planted somewhere. The Audi electronics are pretty extensive so hooking it into the MMI (screen) would be a pretty formidable challange.
Tom mentioned he retrofitted and add on kit from Mopar. Maybe I can have a look into that.
Back to the hunt.....
Chet
These were on sale for $70 a few days back: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390216396478
Not as cool as erco's suggestion, but he's just a cool guy!
"Let's not bicker and argue about who killed who."
Post Edited (K2) : 7/16/2010 2:47:20 AM GMT
The laser approach, even IR is going to create an interference issue if someone else incorporates the same idea on their vehicle.
I wonder how differential 'ambient noise' detection would work? Essentially two microphones that 'listen' all the time in close proximity to one another. In a differential configuration either through software or hardware, any common mode noises are rejected so that only the difference in the two mics are looked at. Under 'normal' driving circumstances the ambient noise level from the road would be somewhat predictable, even at different driving speeds ... add another vehicle within earshot of the mics and there should be a detectable shift or difference in what the microphone picks up. This method eliminates any possible interference from other vehicles that might have a similar detection system.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 7/16/2010 4:11:34 AM GMT
MOORE'S LAW: The capabilities of electronics shall double every 18 months.
cloyd's corollary: Hardware is easy, software is hard.
One flick of a switch and it's amazing how courteous people can get.
DoD and military vans have cameras placed on the roof in the back - one on either side. They are inclined to look at the blind spot. Presumably (and if I knew I probably couldn't say anyway) for checking security before entering or exiting the van, but I imagine they can be used just as effectively as blind spot cameras.
http://www.pyleaudio.com/itemdetail.asp?brand=&cat1=Car%20Security&cat2=Rear%20View%20Camera%20Systems&model=PLCM103
