Method to switch to alternate DC source?
I have an AC transformer that outputs unregulated 26VDC. I want to add a batter backup that kicks in if the main supply fails. The back up supply will be an unknown 3rd party battery with it's own charging system. Just curious if anyone knows what would be the simplest way to implement the switch to battery without crashing the system with a gap. The backup will be a 24VDC battery backup.
- Stephen
DJ
I use 2 amp slo blo fuses on the motor driver board that has the unregulated 26VDC off the rectifier. On a rare occasion under unusual heavy load, the 2amp fuse will blo but it is rare, a 3 amp doesn't usually blow, but the current sense resistor on the input to the board will get super hot under unusual load with the 3amp fuse. That being the case that 3 amp is typically a good maximum fuse choice, would a 4 amp Schottky be a good option for the diodes to be safe? I am making the assumption that the diodes need to be rated higher than the maximum current that the fuse will burn up at.
Here is something I dug up online that I think represents your diode idea:
PS - make sure the 26VDC is a DC level and not just a rectified AC waveform, otherwise the battery will provide the current when the rectified AC voltage drops below the battery voltage. This will result in the battery being discharged.
Post Edited (kwinn) : 7/15/2010 1:33:30 PM GMT
When dealing with power-oriented subjects, 2X is not a bad rule-of-thumb.
DJ
