Where is Everybody?
I was sure that·UPEW (no, I couldn't go) would have galvanized people into running home·and building cool things.·I keep checking in to see new robots people have been building, but it seems even quieter than before. Sure, maybe·some people are·on vacation and traveling. But surely·others are home·near their·soldering irons!
OK, I'll lead the charge and hope others follow suit. I'm gonna work on·my latest little robot·this week and post some info & videos here later. It's built from a plastic Sterilite trash can, and will have a nifty walking gait. Lots of bling on it. Just a fun little remote-controlled·bot with LEDs, an MP3 player and every cheap Chinese gizmo I can find on Ebay, but it's something...
I combined elements of Robbie, Knight Rider, the Silent Running drones Huey Dewey & Louie, Wall-E, and the 2001 Space Pod. Here's an early video of·some LEDs and some·spinning "sensors"·(those arms are bogus, but a real one's coming): http://www.youtube.com/watch?v=u1Qo1_uF8CE
So what·HAVEN'T you·been building and why not git·something going ASAP? Jump in here, or start your own thread.··Time's a-wasting!··Summer is half over!
I am presently working on my version of Steve Norris' BDS that appeared in the Completed Projects Forum and in the latest issue of Robot Magazine.
I already had the Parallax Motor Mount and Wheel kit mounted on a development chassis, so I purchased one of the Robot Base kits and transferred the Motor Mount and Wheel kit to it. I have already mounted the HB25s and a power relay to turn the HB25s on and off. I have also built the IR beacon sensor. I am using three PING))) sensors in the front for obstacle avoidance.
My version is about 32" tall with the IR beacon sensor mounted above the motors and then two shelves for beverages and snacks. The top level houses a Servo City power servo that opens and closes a curved sliding door infront of the shelves. The main body is a 12" dia concrete pillar form. I plan to start wiring up the motors and the Parallax Propeller controllers this coming weekend.
I will include some pics from the coming weekend's build effort.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
“How much of human life is lost in waiting.” Ralph Waldo Emerson"
@wjsteele: No step climbing, just a cute left/right walking action.
With some added bogie detail, they'll look like Wall-E's triangular tank treads, but actually they are simply triangular wheels that rotate 120 degrees at a time, then index flat against the ground. 3 magnets around the wheel trip a reed switch for indexing. Ordinary "walking" is alternating left/right wheels, and I also have "sprint mode" which rotates the wheels together in sync to drive straight ahead.
I built this a while ago and had it walking quite nicely, but never made a video. DOH! Then I took it apart to add the LEDs, and then the twins came and only now am I getting back to it. The girls·have started to crawl now and I need something fun for them to follow around...
http://www.youtube.com/watch?v=haFMPAjVJ-g· Another "proud papa" video, pardon!
http://forums.parallax.com/showthread.php?p=650217
meow, i have my own topic now? (sorta)
90 * 2 = Pi
As for me, I was at UPEW and am totally motivated to build stuff. But I am new to robot building(and I have a newborn), so things are going pretty slowly. There is much for me to learn even before I can get started building. I'm really hoping to get faster at it soon.
I did put my Cylon Princess on top of a Stingray last weekend.
Generally speaking, are starting new threads discouraged here at all? For some reason I was under that impression.
John
But having built MP3s into projects before, I know they have very good audio quality, much better than conventional sound recording chips. So besides playing Lady Gaga's latest, they can spout canned audio from Robby, B-9, Hal 9000, etc...
PLUS, I'm hoping that the voluminous plastic trash can I used for a body might be subdivided into lightweight chambers that act as reasonable speaker enclosures. They won't be extremely rigid, but I don't need 1000 watts of audio, either!
My next hardware project is a hybrid Lego/Basic Stamp robot arm. I'm using the Technic beams to build the structure, RC servos for motion, and the basic stamp to control the servos. Out of the box the NXT brick can't control enough servos for a decent arm, and adding a servo controller to it is not cost effective. The arm control circuit is also going to have an LCD which is my other recent purchase.
I plan to have an IR sensor on the gripper so it can detect objects and try to pick them up. I've been thinking of getting a line scan camera as well. If I do the objects will have a bar code on them and the robot will bring them to the line scan camera for identification. I plan to try and have it sort the objects or do a tower of Hanoi.
So far I've been building the arm structure which has truss sides, but a frame top and bottom (not enough of the right pieces). I'm attaching the servos by hot melt gluing Technic beams and a plates to them. The idea is to them pin and stud them in place with the structure around them taking the load, not the glue. The hard part is going to be finding a way to connect a servo to the Lego turntable for rotation. Lego purists would scoff at using glue, rc servos, and a stamp, but I'm not a purist.
A ten inch Technic truss weighs about two ounces and is surprisingly strong. So far the gripper and wrist servos are going to contribute most the arm load. Attached is an image of a truss someone else built. Mine is similar, but I don't have enough pieces for the side bracing which is why I ended up using plates for the top and bottom. Not quite as strong though.
I don't disagree, but it's common enough that I'm looking forward to seeing how you implement it for my education. I have a lot to learn, and I am excited I want to learn it all as fast as possible [noparse]:)[/noparse]
Parallax Inc.
Follow me at http://twitter.com/ParallaxKen for some insider news.
Propeller + Picaxe = Romeo & Juliet
Still working on translating the wheel kit position controller from C (on the ATTiny) to a spin object, then hope to make it work in PASM. Jeff Martin and Kevin McCullough spent a lot of time helping me at UPEW, and yes I know I could probably just compile the C code with Catalina or such, but I am learning so much about passing pointers to pointers. My main focus is to keep it compatable with the original API so others may use it easily (not so easy).
I am in the process of moving house so now I'll be 46 minutes away from parallax instead of just 40 minutes (but not much spare time for working on piggyBot right now with moving and all).
My son just got me an RC Tx/Rx for fathers day and I bought a pan and tilt from servo city ST200 and I have a video cam mounted on that. I want to mount two cams a couple of inches apart and count pixel difference on blob centers to get depth perception for distance. Got the XBee pros talking good at 250kbs. Working on interProp communications 'cause 8 cogs aint enough. GPS is working too. Got some lasers from HomeDepot for leveling pictures on the wall and thought I might use a pair as "light houses" rotating at different rpms on Bot drop tripods and detectors on the Bot on servos with encoder wheels to see angles and triangulate position. Might be a good use of the sine tables in the Prop ROM.
So, no, not much going on since UPEW. I remember they had parties after "Burning Man" called "AfterBurn".... Is this "AfterPEW"?
rpdb
"I built this a while ago and had it walking quite nicely" - and I thought all along the twins were your little robots under construction
Ravenkallen,
"Slaving away night and day to create the prop 2 must be hard work" - yes, but I truly enjoy it! ... attached is a view of just one I/O pin ; the project I have been working on.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 7/13/2010 5:38:19 AM GMT
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
New robots? Yes, lots of Penguin variants and a new version
Toddler Humanoid (posted in the Projects Forum).
http://forums.parallax.com/showthread.php?p=912126
There's a robot brain being grown and tested here:
http://forums.parallax.com/showthread.php?p=921524
The robot brain is actually the UltraSpark 40, a small project with
40 props for 320 computers with 1,280 ports and 6,400 MIPS
to 8,320 MIPS speed.
This stack fits nicely on top of BoeBot, making it very smart.
The smartest BoeBot is seen here:
http://forums.parallax.com/showthread.php?p=922262
The smartest BoeBot is expanded
with a skyscraper of 20 loaded
Propeller boards.
I also have a small space program, for launching robots into space and
analyzing the data.
humanoido
*Stamp SEED Supercomputer *Basic Stamp Supercomputer *TriCore Stamp Supercomputer
*Minuscule Stamp Supercomputer *Tiny Stamp Supercomputer *Penguin with 12 Brains
*BASIC Stamp Supercomputing Book *Three Dimensional Computer *StampOne News!
*Penguin Tech *Penguin Robot Society *Humanoid Toddler Robot
*Ultimate List Prop Languages *Prop-a-Lot *Propalot Stuff *Prop SC Computer
*Prop Super Mini Computing Machine *Hobby Space Program *Smartest BoeBot at
http://forums.parallax.com/forums/default.aspx?f=6&m=469004
Post Edited (humanoido) : 7/14/2010 6:52:19 AM GMT
I just noticed that the LEDs on your bots face side is not lighting up on the far left "Bots left that is". Did you not connect these up or is it a program error? BTW I love the way you build it and added detail work as well.
Jax
If a robot has a screw then it must be romoved and hacked into..
@Ken: Agreed, outdoor activities·are good inspiration! Sorry I missed UPEW, but I had a 200-mile bike ride·that day. One of my few remaining streaks!
I may get to make visit to Parallax though - jealous?
Whit+
I've been catching up on my "other" business since UPEW.. [noparse]:)[/noparse] Always pay for being out of town.
Back in the shop now working on several projects for UPENE '10
The party is in Norwalk, OH on August 28th! Be there! [noparse]:)[/noparse]
OBC
Propeller Feature Projects: PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
Speaking of which, thank goodness, BP finally capped their oil leak today. I had been modifying a Scribbler 1 to go down there and do the job once and for all. Now at least I can get back to making Waste-bot walk again.
Waste-bot, want not.
Hey OBC, will you have a video feed there?
rpdb
Nice bot.
I've been working on porting my hexapod walking program from the BS2sx to the propeller. This new hexapod uses a prop protoboard to control two propeller servo controllers. The program translates the direction that the "head" is looking to the legs so that it walks in the direction that it's looking. If it detects an object then it looks left and right until it finds an opening. The body itself never turns. The whole thing walks the same way that the BS2sx did, but now I have a lot more room to program.
New videos:
in the "woods"
Children attacking
Now that I have my PropHex walking around I'm working on getting the rest of it ready for the UPENE.
My wife is very, very understanding
