TLMM: Threaded LMM - four, nine or even 19 drivers in one cog! - Page 2 — Parallax Forums
2»
  • jazzedjazzed Posts: 11,803
    edited 2010-07-09 20:23
    Yea, I think 4 total cog longs are required for C & Z save/restore [noparse]:)[/noparse]
    Propeller Pages: Propeller JVM
  • pjvpjv Posts: 1,903
    edited 2010-07-09 20:55
    @Bill & Jazzed;
    Just as a point of reference, I am presently running a test program to check the performance of the scheduler, and I find it can simultaneously run three 115,200 channels transmitting continuously, while also receiving one 115,200 stream. These are NOT bursts but continuous. I believe this to be about the limit of what I can muster. At somewhat slower speeds, say 38,400, I expect it will handle considerably more, probably 8 transmitters, or 4 simultaneous streaming transmitters and receivers.
    I have not delved into the details of keyboard or mouse protocols, but at the 10KHz-ish speeds you mention, they would have negligible impact. It would be a fun thing to see how much could be pushed into a single cog. I would bet that keyboard, mouse, I2C, (100KHz), LCD driver, 7seg LED mutiplexer, OneWire comms could all readily be done in one cog. Since I have not messed with the video (no need for it), I'm unsure what impact that would have, but I have some ideas I'd like to try.
    For me the Holy Grail would be to drive Ethernet directly..... no PHY chip.... again, I have some ideas but not enough lab time!
    Cheers,
    Peter (pjv)
    edited 2010-07-09 21:26
    Hi Peter,
    WOW! That is very impressive!
    I can't wait to try your scheduler.
    Keyboard / Mouse is a piece of cake compared to receiving 115,200 [noparse]:)[/noparse]
    re/ Eth
    I believe someone managed 10Mbps transmission, but could not manage reception due to the overhead of Manchester decoding.
    I think 10Mbps reception might be possible for small packets by throwing several cogs at it.
    Two cogs for reception - one listens for a packet, then writes it to the hub ... and while #1 was writing to the hub, #2 listens for the next packet. if 100% wire rate reception at 10Mbps is not required a single "raw" receiving cog may barely suffice.
    Then have several cogs (I suspect at least two) to Manchester decode and error check the received "raw" packets.
    Fun intellectual exercise.
    Bill
    pjv said...
    @Bill & Jazzed;
    Cheers,
    Peter (pjv)
    www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
    My products: Morpheus / Mem+ / PropCade / FlexMem / VMCOG / Propteus / Proteus / SerPlug
    and 6.250MHz Crystals to run Propellers at 100MHz & 5.0" OEM TFT VGA LCD modules
    Las - Large model assembler Largos - upcoming nano operating system
    Post Edited (Bill Henning) : 7/9/2010 9:32:32 PM GMT
  • wjsteelewjsteele Posts: 697
    edited 2010-07-09 21:35
    Peter, please do share your com scheduler code... it's just what I need!!! smile.gif
    Bill
    edited 2010-07-09 21:56
    Hi Bill;
    I would prefer to hold off until I can do a proper write-up as the intended method of using the scheduler requires some insight or knowledge on the part of the user. I would not say that its unfriendly, just that there are a bunch of implications for your application code. Just to give you an idea, it took me three months of experimenting and tinkering, trying at least a dozen different approaches to come up with this result of a 20 (optional features 25) instruction scheduler. It seems pretty rock solid, and performs like a dream, but you can screw it up royally if you don't write your application in a compatible manner. Of course that is also dependent on how much you are trying to squeeze out of it.
    So let me know if you can wait -I'm off to China the week after next, maybe I can write it on the plane.... 13 hours UGGG- otherwise I will send you a copy on a "user beware" basis.
    Cheers,
    Peter (pjv)
    P.S. My 2010 contest entry has an earlier, less elegant·version, but it does work. Perhaps you would read, dissect and·absorb that. The current version·takes a bit more "twisted thinking".
    Post Edited (pjv) : 7/9/2010 10:02:15 PM GMT
    edited 2010-07-09 22:11
    I'll wait... we've got Oshkosh coming up anyway... this would just be a diversion that I don't need right now. [noparse]:)[/noparse] But it is definitely something that we could use and I'd love to help test it out for you.
    Bill
    edited 2010-07-09 22:42
    Hi Peter,
    No worries!
    I won't have time to look at it for two-three weeks. I have to finish testing the new PropCade board, and I have five other large designs to build and test!
    Yeah, I remember when I flew to HK it was a 14 hour ride squished like a sardine...
    pjv said...
    Hi Bill;
    Cheers,
    Peter (pjv)
    P.S. My 2010 contest entry has an earlier, less elegant version, but it does work. Perhaps you would read, dissect and absorb that. The current version takes a bit more "twisted thinking".
    edited 2010-07-09 23:42
    Bill Henning said...
    I am pretty sure it is exactly the same (or functionally the same) as the code posted in the original threads that talked about saving/restoring flags... which I could not find!
    Not entirely sure if that's the right thread as the one thing it doesn't define is saving both flags [noparse]:)[/noparse] Direct flag manipulation in assembler
    edited 2010-07-10 00:19
    @kuroneko, can you do C&Z save/restore in 3 longs?
    I didn't see Bill's save/restore. Best I can do is this (not tested):
    ' save/restore C&Z
    muxc czsave, #1 ' save C
    muxz czsave, #2 ' save Z
    shr  czsave, #1 wc,wz ' restore C&Z
    czsave long 0
    edited 2010-07-10 00:44
    jazzed said...
    Provided there is one single point of failure^wrestore, yes [noparse]:)[/noparse] I had a look a while back when I updated Phil's macros but couldn't be bothered. May have some ideas later today ...
    ' save/restore C&Z
            muxc    restore, #%00001    ' save C
            muxz    restore, #%10000    ' save Z
    restore shr     $, #%01110 wc,wz,nr ' restore C&Z
    test code (demoboard)
    VAR
      long  storage
    PUB null | n
      dira[noparse][[/noparse]16..23]~~
      repeat n from 0 to 3
        storage := n
        cognew(@entry, @storage)
        repeat until storage > 3
        outa[noparse][[/noparse]16..23] |= (storage & 3) << (n * 2)
      repeat
    DAT             org     0
    entry           rdlong  outa, par
                    test    outa, #%01 wc           ' force carry
                    test    outa, #%10 wz           ' force zero (inverted)
    save            muxc    restore, #%00001        '
                    muxz    restore, #%10000        ' save flags
    not_z           muxz    $, $ wz,nr              '
    not_c           muxnc   $, $ wc,nr              ' scramble current flags
    restore         shr     $, #%01110 wz,wc,nr     ' restore flags
                    muxc    outb, #%01
                    muxnz   outb, #%10              ' inverted
                    or      outb, #128
                    wrlong  outb, par
                    cogid   cnt
                    cogstop cnt
                    fit
    edited 2010-07-10 01:11
    thanks kuroneko, jazzed
    edited 2010-07-10 01:19
    Yes as far as I found, saving takes 2 instructions. Restoring can be done in 1, plus of course the long. Chip's code in the interpreter works for restoring and uses the lower 2 bits. I found a way to use the top 2 bits which could mean you could use another variable. Just at the moment I cannot recall which program I used it in. IIRC the restore is shr xxx,#31? wz,wc,nr
    edited 2010-07-11 18:36
    @Cluso, the PS/2 keyboard does indeed send different codes depending on whether it's in num lock mode -- it's not just a light. The particular keyboard which caused the problem was a Storm numeric-only stainless steel hardened keypad which has no num lock annunciator. I had to detect the alternate codes (arrows, pgup, pgdn, etc.) and translate them to the numerics on the same key in case the operator didn't have it in the right mode. When I switched to the prop I was able to send it commands to force it into num lock mode and lock it so the mode couldn't be changed.
    edited 2010-07-12 03:08
    @localroger: Thanks for the info. I must confess as you have now pointed out, when I did the 1pin code I did not test the numlock mode and presumed it was the same. However, as you said, it could be controlled from the prop code. Since others have numlock lights on their laptops, it is curious I don't on the one with the numeric keypad. Of course my other 2 laptops don't have numeric keypads anyway. Anyway, it was a thought to save pins since we are nearly always short of them.
