Brutal advice needed — Parallax Forums
whiteoxewhiteoxe Posts: 794
edited 2010-07-10 02:18 in Propeller 1
I havent touched elecronics for near 3 years . I started out with picaxe in 2007 and had too much fun. I was controlling things from my computer using both the serial and parallel ports. Iwrote a few programs in VB and C# to help.
WelIm starting all over again. I never really understood what all the different electronics partsdid i just followed directions, from manuals and forums.
I would like to have a mch better understanding. I bought the prop, thinking id never get to understanding but with forum help Imanaged some fun experiments.
Could I ask for a few different opinions?, Should I buy the new new Prop book and continue working withthat multi cog chip or do you thinkI should go back to basics and say buy the Basic Stamp Kit and the two books that come with it it along with lots of experiments.
Thats going to cost around $160 USmore in aussie dollars, whereas the new prop book is only$30or $40 US.
Is only money [noparse]:)[/noparse] , maybe I can speed through the Basic StampKit and get back rightback into spin !
What do you fellows think. I hold your opinions in the highest regard. I just think the Basic stamp kit might be the best way to understand al the different components?Maybe im wrong and I should just keep going with the multi prop ???? Any thoughts much appreciated. Thanks, mike.
Mike.
ps.I was enrolled in Electrical engineering and microprocessor programming but they withrew the course for 2010. I hope its back up for 2011.
Post Edited (whiteoxe) : 7/9/2010 5:46:29 AM GMT
  • LeonLeon Posts: 7,620
    edited 2010-07-09 06:03
    Stick with the Propeller. You can do much more interesting things with it than you can with the Basic Stamp, even if it seems harder to use at first.
    Leon Heller
    Amateur radio callsign: G1HSM
    edited 2010-07-09 06:16
    The basic stamp has much to recommend it.
    For a newbie I doubt you could do better.
    You could of course just start with the propeller.
    It is not so difficult to use. You will not get any
    experience with interrupt code though. But if
    you only want to do personal hobby type work
    than I say who needs interrupts! If you want to
    do this sort of thing for a living though I would
    suggest getting experience with several different
    controllers....most shops code them in C so that
    could be important for you to learn if you want
    to get a job working with controllers.
    Lots of fine people here on this board will help
    you however they can, this is a great resource
    and I really don't think the group here would let a
    newbie fail. Just ask for help whenever you need it.
    Welcome back and welcome aboard!
    edited 2010-07-09 06:55
    fi you talk about electronic parts - which kind of parts do you mean?
    logical sections inside the microcontroller like counter, IO-directionregister, io-state-register COG-RAM, HUB-RAM?
    or do you mean things like resistors, diodes, transitsors, Operational Amplifiers?
    This makes a big difference.
    For the first I would recommend the What's a microcontroller
    It is based on the basic stamp and as you have to learn about microcontrollers you should use it with the basic stamp
    But stop stop no hurry to order a basic stamp !
    Take a look into the Propeller Education Kit Labs Fundamentals
    If you understand that stay with it
    If you don't understand it come back to the forum with questions
    and test if you can understand it with the support of the forum
    If you find it too hard buy a basic stamp2 and go with the what's a microcontroller
    for the second I recommend lessons in electric circuits
    lot's of material starting at the lowest base and going up from there
    best regards
    Stefan
  • Kevin WoodKevin Wood Posts: 1,266
    edited 2010-07-09 07:06
    If you're talking about the new book "Programming & Customizing the Multicore Propeller Microcontroller: Official Guide", then I would say yes, get it. It is very well written, and will definitely make it easier to learn the Propeller. Parallax also includes this book with the demo board as a starter kit, which is a very good deal (especially if you catch it on sale). If you want more info on it, you can get a good preview of it on Google Books.
    That said, since you asked about learning electronics, I suggest that you find a copy of a good electronics text such as Grob's Basic Electronics. You can find older editions (current edition is 11) of the book used (ebay, alibris, amazon) for not much money, or spend some serious cash for a new edition. But it will help you to learn electronics as opposed to microcontrollers.
    Another decent beginner book is the recent Make: Electronics book. It's not as detailed as Grob, but it isn't designed to be (Grob is a college text). You can also check out the Art of Electronics, which is very good, but not strictly for raw beginners. Combined with one of the above books + google, you would be fine with it.
  • whiteoxewhiteoxe Posts: 794
    edited 2010-07-09 07:36
    StefanL38 said...
    best regards
    Stefan
    Buy partsI meant , diodes, resistors, ransstorsand dozensofother components !!!! Also Igave away my two basic stamps, I had hrdly used them as I was still into picaxe chips.
    I thinkIll bight the bullet(hope its not a hollow point [noparse]:)[/noparse] and continueon with the prop. Illorder the book tonight. Thanks for your help.
    edited 2010-07-09 07:39
    Thanks very much to all of you.I am going to stay with the prop.With this forum I think I can make it !
    I think I am going to buy a book on basic electronics, writers name is Forrestwhittaker or similar.Its on amazon and has very good reviews, even old hands say they sometimes still refertoit !
    Post Edited (whiteoxe) : 7/9/2010 7:44:52 AM GMT
  • heaterheater Posts: 3,370
    edited 2010-07-09 08:09
    whiteoxe. I think you will be very happy with the Prop.
    The Spin language is just as easy to learn/use as any BASIC I have seen.
    When you have the need for speed the PASM assembler language is about the easiest to learn/use I have come across.
    Having multiple cores, can lead you to all kinds of "interesting" programming but from a beginners point of view makes life very easy with drop in objects for serial, SPI, I2C, SD cards etc. Just find a ready made object from OBEX or elsewhere and it's "plug and play".
    The Propeller Tool is dead easy to use.
    On the hardware/electronics side the Prop is great because you can get it running with almost nothing. A DIP Prop, a power supply, a few decupling capacitors and a Prop Plug and you are programming already. I started with no PropPlug just the two transistor circuit to use with a serial cable.
    After that you can start to add circuits and gadgets to the Prop step by step as your you electronics knowledge grows.
    And finally, but most importantly, there is this forum. Not sure I've ever seen such a large group of enthusiastic, smart and helpful people. No question is to stupid to be answered here, trust me I know[noparse]:)[/noparse]
    With all that experience in place you will be ready to tackle any other micro, the only downside being that with them you will be frustrated at how hard they are to use. What with needing interrupts, and the C language, a clumsy IDE, and understanding a billion special purpose registers, and peripheral hardware blocks, and dedicated pins for this and that etc etc etc.
    Have fun.
    edited 2010-07-09 14:35
    Deffo stick with the prop. Have you located your local surplus store? If there is one, those are great and inexpensive and fun places to get parts for projects. On average, I've stocked up for a few dollars per project at the one where I live. When things go badly (and they do), it's not too big of a deal to get replacements.
    8x8 color 80 Column NTSC Text Object
    Wondering how to set tile colors in the graphics_demo.spin?
    edited 2010-07-09 15:08
    If you want to learn a little bit about basic components such as diodes and such, you might have a look at this website:
    www.allaboutcircuits.com/
    I would look at and consider "Make: Electronics Learning Through Discovery" by Charles Platt over "Getting Started with Electronics" by Forrest Mims.
    IMO the Platt book is easier to understand, better composed, and more up to date than the Mims book. Both follow a hands on approach, and are similarly priced. You can preview each on Amazon. The Mims book may be in your local Radio Shack, and if you have a Barnes & Noble nearby, they might have the Platt book, if you want to see them first hand.
