Hacked servo for more power.
Gramps
Modify a standard servo by cutting the stop out of the gear box to make it continuous running.
Remove the pot from the servo and reconnect with 6 inch wires.
Connect the servo to a threaded shaft and move heavy stuff at much slower speed but with more torque.
Connect the pot to a lever on the threaded shaft for feed back.
Gramps
'What is your life?"
"It is even a vapor that appears for a
little time and then vanishes away."
Saint James 61 A.D.
Gramps
Saint James 61 A.D.
Use LOTS of lubricant. Dry leadscrews (especially allthread) have tons of friction and will cut your useful load in half. Also, make sure your applied load is in-line with your leadscrew and doesn't twist your threaded follower. Any binding of the follower is suicide!
Do you have a source for 5k slider pots?
Or could a 100k pot (i have 5 ) be converted to 5 k?
I'm thinking a Wheatstone bridge would work........
Actually the cables coming from my robot fingers tie to this ground bar shown in the photo, which has to rotate 90 degrees either side of center when the wrist turns, so we're hoping we can keep everything in alignment.
Gramps
Saint James 61 A.D.
hehehe [noparse]:)[/noparse]
"puff"...... Smile, there went another one.
Saint James 61 A.D.
Will look for 5K sliders.... that's the right way to do it.
Saint James 61 A.D.
http://www.mouser.com/search/ProductDetail.aspx?qs=8YYpzd7qSxKID6GqcS4NQA==
$1.65, not bad!
Have to copy & paste·that link WITH the == on the end, it didn't hyperlink properly here
Saint James 61 A.D.
Saint James 61 A.D.
I don't see a minimum order, is it listed someplace? $25?
Saint James 61 A.D.
Post Edited (Gramps) : 7/8/2010 10:47:27 PM GMT
www.mouser.com/ProductDetail/Alpha-Taiwan/RA2043F-20-10EB1-A5K/?qs=8YYpzd7qSxKID6GqcS4NQA%3d%3d
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Gramps
Saint James 61 A.D.
